LED light power supply board what do you think about it
    • Jul 2011
    • 6069
    I bought three of these little lights
    I would like to know what you think of this power supply board
    • Jul 2011
    • 6069
    Re: LED light power supply board what do you think about it
    I am going to hack two so they can run on battery power supply
    Or at least that the plan for now
      • 31247
      maybe - the leds may use a pretty high voltage.
      go watch some teardowns by big clive - he shows how to calculate the voltage etc.
        Did you measure the Vf of the LED to see if they are 3V or 6V dual-LED?
        Since the LEDs are connected in series then it will be easy to find out what the total Vf of the LED string is.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8703
          I'm surprised you got a transformer... thought that newer cheap non-dimmable LEDs have no transformer, just effectively has a series pass IC regulator like a LM317 in CC mode... ?
          It is tempting to get one to work with low voltage, but with the LEDs usually wired in series, rewiring the heatsink board for parallel sounds no fun...
          • Stefan Payne
            • 1267
            That's a non isolated buck converter, is it not?
              • 31247
              watch your fingers, some of those led boards run 70-90v or even higher.
              there are led's with 6 or more dies in series in them specially for mains lamps.
                • Jul 2011
                • 6069
                UpDate
                The voltage is 17 v@50 mill amps I check it while the LEDs were ON then power them use an adjustable power supply set 17 volts it was showing 50 millimeters
                I going to get some voltage/current regulars from eBay very soon and set up the same reading or maybe a little bit lower than that
                One note
                I do not like the way that power board is set up for one thing I do not see a fuse on or I have not found one
                I will use this power supply with some add on
                A while back GoldMine Electronic had a sale on LEDs strip lights 20 pieces for $20.00
                they do not run this sale very often when I look on there site the other day and they did not list them any more which means that they are out of right now
                I have about 10 bags of them
                  It uses fusible resistor, the gray one right at the AC input feeding the bridge.
                  It does look like non-isolated buck converter, look up the IC next to the inductor.
                    Just get boost converter board that can convert 2V or 3V input to higher Voltage to the feed the current regulator to drive the LEDS.
                      • Jul 2011
                      • 6069
                      Ok thanks
                        • Jul 2011
                        • 6069
                        I will look it up with a more powerful magafing glass than one I have in the shed I will post the part when i can read it
                        I saw the resistor but do not like that I want a real fuse and a fast acting fuse at that
                        I seen real **** happen when there are fuses in power supply’s I seen some damage when a power supply has a main fuse but it not bad from what I have seen
                          • 31247
                          resistors can be faster.
                            • Jul 2011
                            • 6069
                            Could you please explain how this could be
                            • mariushm
                              • May 2011
                              • 3799
                              FFS just get a fricking led driver, either boost (to power from 1-2 batteries) or a buck (step-down) to create 17v from some higher voltage like 18.5v (laptop adapter) or 24v (common and cheap power supply).
                              Here you go, around 8000 entries for led driver : https://www.digikey.com/products/en/...ed-drivers/745
                              Some examples
                              MIC2287 2.5v to 10v (good for a 18650 battery or non-rechargeable AA batteries) : https://www.digikey.com/product-deta...6-1-ND/1821816
                              Diodes Incorporated ZXSC400E6TA 1.8v to 8v in, up to 50mA on leds : https://www.digikey.com/product-deta...TACT-ND/463845
                              ON Semiconductor CAT32TDI-GT3 2v to 7v, up to 40mA current output : https://www.digikey.com/product-deta...SCT-ND/5213207
                              All super easy to use, datasheets on each page, example circuits in datasheet
