This tutorial I will write for fun ...designed to cover any cap replacement of any computer power supply..for advanced users..I hope will be useful
OK
When you dismantle any computer ' Power supply you will found lots of caps inside..small and bigs
here is the list of caps you will found
* 2 big caps 200v rated between 220uf and 630uf (never fail)
* small caps (never fail)
*the problematic high capacitance caps: you will found between 5 and 8
these high capacitance caps are there to ripple all voltages of the ATX or AT Power supply
there one for each voltage...5v 12v -12v 5vsb 3.3v -5v
*but sometimes on the 5v line there are 2 or 3 in parallel to ripple the most problematic line
how many capacitance is commonly used:
on the 5v line: between 2200uf and 4700 uf
on the 12v line: between 1000uf and 2200uf
on the 3.3v line:between 1000uf and 2200uf
on the -12v line: between 470uf and 1000 uf
on the +5vsb line: 1000 uf
on the -5v line: between 470uf and 1000 uf
*The 5v line
This is the most problematic line:it power ups the vcore of the cpu, the ps2 and usb ports and powerups lot of things.....very often you will found bulged caps there,if not bulged...they can be wasted and can offer low capacitance (check always the caps on this line) cause is the line of undesirable crashes and errors and it can fry your motherboard if there are not good capacitance there
*The 12v line
this is the second most problematic line...it power up hardisks,dvd and cdroms
If you have lot of this things...the cap of this line can be very stressed
*The -12v line
This is the third most problematic line....used only for the motherboard...sometimes you will found a bulged cap..but it not causes mayor problems
*the 3.3v line
this line will power up ram modules......it's very rare found bulged caps or wasted caps there....unless you overclock the computer and you raise the memory voltage
*+5vsb
this line is always ON even if the computer is off....never used and never stressed unless you select with a jumper on the motherboard power up PS2 and USB ports...(I don't recommend that)
also this line power up some things in the bios
I will continue later
OK
*The 5v line
*The 12v line
*The -12v line
*the 3.3v line
*+5vsb
