Any idea what's wrong with a PSU that runs with a tester but not a motherboard?
+ More Options
Posts
  • myaccount
    • Sep 2017
    • 7
    I have a Fortron FSP400-60PFN power supply that ran for 11 years before it died recently.
    Actually, I didn't think it had died because I tested it with a cheap PSU tester and it powered on fine. So I thought it was the motherboard that had died. Well turns out the motherboard is fine, and the PSU died.
    So if the PSU works when it's hooked up to the cheap tester, but it doesn't work at all when it's hooked up to a PC, what does that mean? Any guesses as to what's wrong with it, and if it'd be simple to repair?
    I opened up the PSU and didn't see any bulging or leaking caps.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Any idea what's wrong with a PSU that runs with a tester but not a motherboard?
    Well, it's worth repeating those cheap PSU testers are merely a quick go/no go test with really light loads that are nowhere near characteristic of an actual motherboard. So a lot of them really mean nothing other than basic functionality. It does not tell how the PSU responds to heavy or transient loads, nor tests whether your power supply produces noise that wreaks havoc on data integrity.
    You'll need more sophisticated tools to tell what's wrong with it, such as an oscilloscope. If you have an ESR meter, it can expose some bad capacitors that you can't tell by simply looking at it.
    A lot of the times even though capacitors may look good, they really aren't. The ESR meter or oscilloscope can sniff out a bunch of these.
    • Stefan Payne
      • 1267
      First guess would be +5VSB circuit.
      Put the ATX connector onto the Motherboard and measure the +5V Standby Rail.
      If it is too low, nothing will happen.
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        Just yesterday (at the time of writing this), I managed to fix 5 PSUs with this same exact symptom and I can definitely say the capacitor(s) on the 5VSB bus are faulty. Replace them and you should be good to go. Cheers
        Wattevah...
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          at 11 years all the caps in that unit should be replaced.
          they were junk new and it gets worse with age.
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Of course, that would be true if it hypothetically was a mid-2000s CWT-based Antec.
            (Especially 2003-2005) (Ironically, earlier Fuhjyyu caps were less likely to take a shit.)
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8179
              That gets my vote too.
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                The question now is SHOULD you bother to invest in a PSU like this ?
                Wattevah...
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  if the op needs such a unit yes.
                  you should see some of the old oddball stuff i repair because its the only type that fits and the machine needs to be kept going forever.
                  how about a packard bell 100w?
                  yes i repaired one in an industrial application.
                  say what you will about them but it has been running since early 90's and simply failed to start after a power failure.
                  it didnt owe its owner anything at this point.
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    I'm not the one to talk, since I too often (try to) salvage theoretically useless pieces of junk that nobody in their right mind besides us techies would ever give them second thought...
                    Wattevah...
                      • 31044
                      this is no junk, it's a good design.
                      i have a few FSP units in my spares box, and wont scrap them.
                      they arent re-capped, because i dont need them yet - but i will re-cap them if i need one.
                      no point re-capping psu's that may sit for a year or 2 afterwards!
                      • Quaddro
                        Tukang Kentu
                        • Nov 2010
                        • 141
                        • Indonesia
                        FSP usually lose PG signal.
                        I have dozens of fsp/amacrox/any psu based fsp with no PG signal, and until now i still can't find the culprit.
                        Btw, old psu is always useful.
                        i still running 9 years old tagan pipe rock tg1100-bz for my main system.
                        And well, i got it for free last year. Dead 5vsb circuit. Get it the ic from benq monitor.
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          I too came across several PSUs which have PG 0ms on my tester....can't track it down :|
                          Wattevah...
                            • 31044
                            some help:
                            http://www.danyk.cz/s_atx_en.html
                            • double_DD
                              Why does my ISP router hate my "homemade" power supply??
                              by double_DD
                              It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                              So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                              For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                              07-12-2025, 03:09 AM
                            • madan1
                              555 based power supply getting too hot
                              by madan1
                              Good day.
                              I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
                              The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
                              After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
                              When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
                              06-23-2025, 04:38 PM
                            • Hondaman
                              Hardware firewall to block ad servers?
                              by Hondaman
                              I found an interesting summary on a wiki that Youtube "right to repair" enthusiast Louis Rossman put up. He suggested I could use a hardware firewall and pfSense as a firewall, and use pfSenseNG as an ad blocker. Or use OPNSense as a similar alternative. Seems like it would be easy to set up, but it only runs on the hardware supported by BSD. (I'm sure the developers and maintainers of BSD are super-busy and cannot support every single piece of hardware out there, so I can't fault them.)
                              The trick, apparently, is to "assign IP address lists from sites like I-blocklist...
                              02-05-2025, 05:04 AM
                            • CuriousJohn
                              Burco boiler power problem
                              by CuriousJohn
                              Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
                              Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
                              This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
                              12-22-2024, 10:25 AM
                              Component tester which one is worth the money from it capability to test and identify
                              I am thinking of buying a component tester but I want to get the most out of the device for the money that I am going to spend
                              Any idea but I would prefer actual use of the device it good points and it short comings be completely truthful about the review of the device
                              There are so many versions of this type of device and I do not have enough information to make a good decision at this point
                              When I bought my battery testing machine I had some information to go by because of electrical experience with auto electrical experience in this field job wise (...
                              06-30-2022, 08:23 PM
