evershine TL3000-10 inverter problem
  • snipersquad100
    • Nov 2013
    • 330
    I found this inverter in the skip and as I cant get my sma sunny boy working I decided to take it home. After opening it up to make sure it's safe to power up I plugged in the 240ac and 270dc and it started running self diagnostic, after 30 secs it displayed relay-check fail. Would this be as simple as sucking out a relay and replacing it with a new one.
    Got some pics if anyone got any idea's
    Thanks.
  • petehall347
    • Jan 2015
    • 4451
    • United Kingdom
    Re: evershine TL3000-10 inverter problem
    Turn off the SOLAR SUPPLY MAIN SWITCH located at your switchboard or the Inverter AC Isolator.
    Turn off the PV Array DC Isolator located at the inverter.
    Wait for approximately 1 minute.
    Turn on the AC Isolator and / or Solar Supply Main Switch.
    Turn on the PV ARRAY DC Isolator.
    See if the inverter successfully starts up after the reboot.
    • snipersquad100
      • Nov 2013
      • 330
      No still the same Petehall347
        • 31304
        is there a relay missing in that foto?
        • snipersquad100
          • Nov 2013
          • 330
          I dont think so, just looks like its unpopulated.
          • petehall347
            • Jan 2015
            • 4451
            • United Kingdom
            what is the relay for ?
            • snipersquad100
              • Nov 2013
              • 330
              I have found a fault with this Relay, even thou the coil was ticking when I give it 12v the mains side was not switching.
              This relay was a real pain in the butt to suck out, I lifted 2 pads up so ended up cutting it open and pulling the pins one by one.
              I cant find a replacement relay in the uk and digikey wants $12 and $10 postage so going to have to look for an alternative.
                So you applied 12VDC to the coil and the contacts moved but still not closing the contacts (0 Ohm reading between Common and N.O. pins of the relay)?
                • snipersquad100
                  • Nov 2013
                  • 330
                  There was OL on the ohms setting on the mains side with the coil energised or not.
                  • petehall347
                    • Jan 2015
                    • 4451
                    • United Kingdom
                    try rs ..http://uk.rs-online.com/web/c/relays...6431322D313226
                    and farnell and cpc
                    • snipersquad100
                      • Nov 2013
                      • 330
                      Thanks petehall347, I'll try a lower amp relay i got laying around first just to see if it clears the fault, If it does ill buy one from rs cheers.
                      • petehall347
                        • Jan 2015
                        • 4451
                        • United Kingdom
                        just noticed you have to buy 120 to get them cheap ..at least its free postage
                        i get most components from there . free next day delivery .once had a load of capacitors flown overnight from germany as they wasnt in stock here . phoned them at 8pm and they got here earlier than a regular order .
                        • snipersquad100
                          • Nov 2013
                          • 330
                          Found something a bit strange about the relay I pulled out of this unit. The package say it's a T92P7D12-12 which had 4 pins on the mains side. The Data sheet shows it to have 6 pins on the mains side. I found a relay T92P7D22-12 which is the same rating as the T92P7D12-12 but only has the 4 pins on the mains side which matches the one I took out of my unit. Could this relay I took out be a T92P7D22-12 with a T92P7D12-12 case on it???? Would they do that.
                          Also the T92P7D22-12 is less than half the price.
                            The one in your unit is DPST (Double Pole Single Throw) which has two Common (C) contacts and two Normally Open (N.O.) contacts and 2 pins for the coil and it use the case form factor for the DPDT (Double Pole Double Throw) version which has 2 Common (C) contacts, 2 Normally Closed (N.C.), 2 Normally Open (N.O.) contacts, and 2 pins for the coil.
                            So you just have to look at the P/N closely which will show what the contacts configuration will be.
                            • snipersquad100
                              • Nov 2013
                              • 330
                              Thamks budm, I'll order the T92P7D22-12, Whats the worst that can happen.
                              • valvashon
                                Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                by valvashon
                                For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                01-04-2024, 01:44 PM
                              • theone111
                                by theone111
                                3. Problem: TV shuts down
                                07-22-2024, 10:36 AM
                              • Zeonalbasta
                                Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                by Zeonalbasta
                                i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                09-13-2024, 01:17 PM
                              • stomanata
                                Problem with power inverter emc18aecn1 of washing machine AEG L6FBA674
                                by stomanata
                                on my previous post with help from this forum i found short circuit GIF5CH60TS-X
                                I replace it but again give me error for current over 16A.
                                I measure again and found short circuit between #15 and #16 (Cin and GND).
                                On PCB i remove R121 to check in which direction is short circuit. But this pin goed
                                to big copper piece on back side.
                                So i try to measure over every resistor and capacitor
                                But i can`t find any short circuit,
                                On example circuit of GIF5CH60TS-X is labaled that Cin can goes to GND in some cases:
                                1. Through CSF (i don`t know...
                                09-15-2024, 02:06 AM
                              • Gibon378
                                Problem with stopping audio and video for no reason
                                by Gibon378
                                PC Specs:
                                • CPU: Ryzen 5 1600
                                • GPU: GTX 1080 Palit JetStream
                                • MOBO: ASRock ab350 PRO4
                                • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                • PSU: XFX 650W (don't remember what model)
                                • OS SSD: ADATA SP920
                                • OS: Windows 10 21H2
                                Problem description:
                                Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                11-19-2022, 09:41 AM
