badcaps in a ATX PSU
  • RukyCon
    A Fake Rubycon
    • Jan 2017
    • 816
    Re: badcaps in a ATX PSU
    tho i just made a note
    now that's just for the big caps
    I'm not a expert, I'm just doing my best.
    • RukyCon
      A Fake Rubycon
      • Jan 2017
      • 816
      i just desolder the camicon 3300uf 10v cap and it tests at
      5229uf
      0.18ESR
      2.2%Vloss (not sure what that means)
      it looks to be a badcap
        • 31283
        Vloss looks o.k. - if it's over about 4% it's not looking good.
        but yes, that's a very bad cap
        • RukyCon
          A Fake Rubycon
          • Jan 2017
          • 816
          ok i will put it in my badcaps bin
          • RukyCon
            A Fake Rubycon
            • Jan 2017
            • 816
            i tested it again and now the Vloss is 3.3%
              • 31283
              it will change a bit over time & temperature.
              when you test enough caps, you get an idea of the range for a good cap.
              polymers have higher loss btw.
              • RukyCon
                A Fake Rubycon
                • Jan 2017
                • 816
                that's good to know for the future
                BTW this is the first PSU i've ever repaired
                tho like i said at the start
                Originally posted by ruky con
                i have a good PC PSU which i got from HSC Electronics used for $6 on sale.
                now i say the PSU is good but it's not 100% good because i wanted to open the power supply up (just to see how it work) but then i spotted 3 bulging capacitors
                tho this is still technically a repair even if the caps were not 100% dead 'cause i'm still changing out faulty components "before they die"
                  • 31283
                  not yet.
                  you can only say that when you power it up and it runs.
                  • RukyCon
                    A Fake Rubycon
                    • Jan 2017
                    • 816
                    not yet.
                    i meant it's the first PSU i'm attempting to repair
                    • RukyCon
                      A Fake Rubycon
                      • Jan 2017
                      • 816
                      UPDATE
                      the order has been placed now time to wait
                      • RukyCon
                        A Fake Rubycon
                        • Jan 2017
                        • 816
                        UPDATE
                        1/14/17 2:16pm
                        the order was upgraded from fedex ground to fedex 2nd day for no extra charge
                        • Behemot
                          • 4845
                          • CZ
                          #72
                          ok now all the caps in my cart are
                          chemi-con
                          2200uf 10v KY
                          680uf 16v KY
                          2200uf 16v KYB
                          3300uf 6.3 KYB
                          1000uf 16v KY
                          I carry most of those much cheaper…plus 3300/16 D10 caps.
                          • RukyCon
                            A Fake Rubycon
                            • Jan 2017
                            • 816
                            update
                            the capacitors have arrived today
                            • RukyCon
                              A Fake Rubycon
                              • Jan 2017
                              • 816
                              UPDATE
                              I successfully repaired the PSU
                              thanks for helping me do i first repair
                              • Pentium4
                                CapXon Be Gone
                                • Sep 2011
                                • 3741
                                Sweet deal, good job man POST PICS! Also, don't forget to put a drop of oil in the fan
                                • RukyCon
                                  A Fake Rubycon
                                  • Jan 2017
                                  • 816
                                  will WD-40 work for the fan
                                  and i did not do all of the small caps since some are in hard to reach parts of the PSU and because i accidentally burned my hand trying to desoder one but it feels better now
                                  ok here are the pictures you want
                                  and it does run
                                  • Pentium4
                                    CapXon Be Gone
                                    • Sep 2011
                                    • 3741
                                    Good work, sir! Looks beautiful. Take a gander at all those nice Japanese quality caps... No, don't use WD40 for the fan
                                    • RukyCon
                                      A Fake Rubycon
                                      • Jan 2017
                                      • 816
                                      ok thank you
                                      oh and out of all of the bigger caps i replaced [500UF+] only 2 of the 9 caps tested within specs for capacity
                                      them being a 1000uf 16v canicon
                                      and a 680uf 16v GL [or gold-link]
                                      • RukyCon
                                        A Fake Rubycon
                                        • Jan 2017
                                        • 816
                                        oh make that 4 of 10 [canicon 2200uf 16 and a other GL 680uf 16v]
                                        • kc8adu
                                          • Nov 2003
                                          • 8832
                                          • U.S.A!
                                          #80
                                          shipping more than offsets any savings though.
