badcaps in a ATX PSU
  • RukyCon
    A Fake Rubycon
    • Jan 2017
    • 816
    Re: badcaps in a ATX PSU
    Originally posted by Pentium4
    Click on the link from the original post, not the quote.
    You also don't need 10V caps for 5V and 3.3V rails. Since you want to get d10mm caps and want to keep 3300, get these:
    http://www.digikey.com/product-detai...840-ND/4843650
    thank you these look like they should work
    I'm not a expert, I'm just doing my best.
    • RukyCon
      A Fake Rubycon
      • Jan 2017
      • 816
      ok now all the caps in my cart are
      chemi-con
      2200uf 10v KY
      680uf 16v KY
      2200uf 16v KYB
      3300uf 6.3 KYB
      1000uf 16v KY
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Looks good. Since they're so cheap, might as well get the little caps too At least get a startup cap. Can you read the values of the other small caps in there?
        • RukyCon
          A Fake Rubycon
          • Jan 2017
          • 816
          [22uf 50v] [2.2uf 50v] [10uf 50v]
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            2.2uF 50V: https://www.digikey.com/product-deta...1887-ND/589628
            10uF 50V: https://www.digikey.com/product-deta...852-ND/3562878
            22uF 50V: https://www.digikey.com/product-deta...7-1-ND/4319987
            There aren't any 1uF 50V, 4.7uF 50V, or 47uF 50V in there?
            • RukyCon
              A Fake Rubycon
              • Jan 2017
              • 816
              that is what i can see i will try to look deeper
              new ones 0.22uf 50v - 1uf 50v
              i look at all the yellow caps and that's all i can find
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                0.22μF 50V: http://www.digikey.com/product-detai...1330-ND/589071
                1μF 50V:
                http://www.digikey.com/product-detai...4-1-ND/4319975
                • RukyCon
                  A Fake Rubycon
                  • Jan 2017
                  • 816
                  my cart is now
                  chemi-con
                  2200uf 10v KY
                  680uf 16v KY
                  2200uf 16v KYB
                  3300uf 6.3 KYB
                  1000uf 16v KY
                  Nichicon
                  2.2uf 50v UPW
                  22uf 50v UPW
                  0.22uf 50v UVZ
                  1uf 50v UPW
                  rubycon
                  10uf 50v YXF
                  thanks to all that help me find new caps for my ATX power supply unit
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    Looks good. You're welcome. Keep us updated
                      • 30941
                      oh hell no, that's not true.
                      the 1.5x rule exists for a reason.
                      a psu output after rectification is high enough for the 5v line to blow 6.3v caps.
                      you can use them on the 3v3 line and on motherboards where the power is already stabilised.
                      but NOT on the output of a diode or rectifier!
                      • RukyCon
                        A Fake Rubycon
                        • Jan 2017
                        • 816
                        ok i will do so
                        fun fact
                        i had a 100% dead PSU from a gateway computer that was sadly unfixable
                        tho it was a crummy PSU
                        i saved all of the caps
                        all of the cap brands [that i got out of the dead PSU are]
                        OST
                        Ltec
                        elite
                        and
                        Capxon
                        • RukyCon
                          A Fake Rubycon
                          • Jan 2017
                          • 816
                          i did not place the order yet so i can go back and change the order
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            Huh, I've never had 6.3V caps bulge on the 5V or 5VSB rails. Isn't that why the caps have a surge voltage rating?
                            • Wester547
                              • Nov 2011
                              • 1268
                              • USA.
                              #34
                              Not sure where the "1.5x rule" stems from. It doesn't make sense. And according to Panasonic:
                              The life of the aluminum electrolytic capacitor is influenced by an ambient temperature, a ripple current, and an applied voltage. Especially, the ambient temperature and the ripple current are the main factors that causes wear-out failure. Applied voltage does not influence life time too much if an applied voltage to the aluminum electrolytic capacitor is below0.9x the rated voltage.but can be a factor of sudden failure.
                              I realize that the endurance tests have the caps in series with 10-1000Ω resistors so as to make certain the peak voltage does not exceed the applied voltage, but if the 1.5x rule really held true, there wouldn't be so many PSUs that would get away with using 6.3V rated capacitors on the +5V output or 16V rated capacitors on the +12V output (same goes +12V input capacitors on motherboards). Many have gone by a "1.2x" rather than "1.5x" ruling with no issues. Quality capacitors will be able to handle their rated voltage (and even the surge voltage for a few seconds) with no issue (as they do for thousands of hours at 105ºC, with the rated ripple current applied in the endurance tests).
                              • RukyCon
                                A Fake Rubycon
                                • Jan 2017
                                • 816
                                so should i use a 6.3v cap or a 10V cap?
                                  • 30941
                                  use a 10v cap
                                  for everybody else:
                                  remove the caps on the 5v line of a psu and scope the output voltage - you'l be surprised.
                                  and to re-use a quote:
                                  unsmoothed 5v can in theory be 7.05v
                                  now that looks like a lot more than 0.9 x 6.3v to me!
                                  • RukyCon
                                    A Fake Rubycon
                                    • Jan 2017
                                    • 816
                                    ok i will do that
                                    • RukyCon
                                      A Fake Rubycon
                                      • Jan 2017
                                      • 816
                                      so far all of the 3300uf 10v cap i found are 12.50mm wide i need a cap that's 10mm wide.
                                      i found a rubycon PX cap that's 10mm wide but i don't know if the rubycon PX caps can be used in a PSU
                                      can someone help me
                                      thank you
                                        • 30941
                                        i see what you mean, closest i can see is panasonic FK 2700uf
                                        • Wester547
                                          • Nov 2011
                                          • 1268
                                          • USA.
                                          #40
                                          use a 10v cap
                                          for everybody else:
                                          Well, electrolytic capacitors work such that the thickness of the anode oxide layer is proportionate to the voltage applied to the plates. So if you apply 5V to a 5V capacitor, it is essentially a 5V capacitor and no longer a 6.3V capacitor. I'm pretty sure the magamp circuit (toroidal output inductor) in a PSU before the caps play a part in regulating and smoothing the rectified output voltage (the function of the larger inductors is similar to that of smaller coils in motherboard buck regulators, but if the capacitors go open circuit or high-ESR, that can mess up the output voltage). In discontinuous flyback topology (and continuous, which is less stressful but complicates the design of the control loop), the output inductor is part of the transformer secondary.
                                          And PX is a general purpose Rubycon series. Probably best to stick to entry-level low-impedance parts such as those mentioned (LXZ, FC, PW, KY, KYB, HE, etc). This is a half-bridge PSU so the output frequency will be lower, and the need for very low impedance parts on the output is lesser (capacitance matters more, especially since it goes down with frequency). Panasonic FK could work too.
