VStanby (V SB) question ?
  • bianchi77
    • Jun 2016
    • 1121
    Guys,
    If V Standby (V SB) on ATX PSU is less than 5V,
    Is it the cause of Power Supply can not be turned on ?
    I see the diode on 5V SB is 0.1V on Vf diode test on DMM diode test...even I reverse the polarity....suppose to be OL on reverse and about 0.3V-0.7V normally..
    Any clues ?
    • 31055
    Re: VStanby (V SB) question ?
    what voltage are you seeing?
    • bianchi77
      • Jun 2016
      • 1121
      2.5v can it be a bad coupler? I replace diode and now it's 5v I can hear high pitch tone when it turns on. The cause is a short FET on motherboard...do u reckon? Can it be the secondary rectifying diode is faulty?
        • 31055
        could be the capacitors on the standby output - they fail a hell of a lot because they run 24/7 and there is no cooling in standby because the fan stops.
        • bianchi77
          • Jun 2016
          • 1121
          ok I'll have a look on it...if this caps fail...everything shuts down ?
          • bianchi77
            • Jun 2016
            • 1121
            I've found 2 bulge capacitors 2200uF/16V on the secondary side...could be this one is the major problem ?
            I haven't checked which one is connected to 12V / 5V...
            I'll replace it and see...
            • bianchi77
              • Jun 2016
              • 1121
              I've replaced them, no avail, can it be the rectifying diodes ? it's SBL1040 and when I measured it on diode test I got 0.1V...and there's one FET on 3.3V rail...
              any ideas or schematic for it ? or it's faulty SG6105 PWM buck controller ?
              I've tested the opto as well, all good...25 ohm when LED is on..
              • bianchi77
                • Jun 2016
                • 1121
                Photo of the PCB, I 've taken out the secondary rectifier...
                PCB serial code :
                LEC-011
                REV:1.2
                Any ideas for the schematic ?
                • bianchi77
                  • Jun 2016
                  • 1121
                  The case :
                  Ritmo LPF2SS
                  • Khron
                    • Sep 2006
                    • 1350
                    • Finland
                    Those two black caps near the top of the board, near the small transformer - are they Fuhjyyu? Either way, if the 5VSB is low, those would be my first suspects.
                    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
                    • bianchi77
                      • Jun 2016
                      • 1121
                      are you talking about these caps ?
                      • bianchi77
                        • Jun 2016
                        • 1121
                        Let me take close up picture so you can see what exactly it is...
                        • bianchi77
                          • Jun 2016
                          • 1121
                          Capacitor photos
                            You have already found two bad caps with bulging top, you might as well replace the whole set of the caps since bad caps may not show any sign of bulging on top, otherwise you need to check the Capacitance and the ESR of the caps.
                            • bianchi77
                              • Jun 2016
                              • 1121
                              does it mean that I should desolder all the electrolityc caps and check, or just replace 'em ?
                              • bianchi77
                                • Jun 2016
                                • 1121
                                Will a bad caps make the PSU completely shut off ? from I can see there's no problem with the diodes, I have check one by one....
                                  Bad cap will cause the power supply not to run properly: I.E. will not run, low Voltage, cycling on and off, etc.
                                    You already have bad brands of caps being used so just replace them with the good and correct type of caps, it wastes a lots time unless you want to buy the test equipment and analyze each caps OFF the board.
                                    • bianchi77
                                      • Jun 2016
                                      • 1121
                                      ok, so do you reckon there's no problem with SG6105 PWM chip ?
                                      This PSU is completely off, was on before, but suddenly off...
                                      and I got only V Sb 5V on.....
                                        Was on before what? Before you are working on it?
                                        You indicated the 5VSTBY is less than 5V and the power supply cannot be turned ON, so how did you get it to turn on then?
                                        Also now you indicate "This PSU is completely off," So now you have nothing period, no STBY, none?
                                        Very confusing.
                                        • caprider
                                          FCL30A015 diode reverse biased shows 35 Ohm, 0.05V forward. Is it gone?
                                          by caprider
                                          I am troubleshooting a power supply.
                                          When measuring a FCL30A015 diode it shows 35 Ohm when reverse biased and 0.05 forward voltage.
                                          See attached.
                                          The datasheet does say "Extremely Low Forward Voltage Drop": https://www.alldatasheet.com/datashe...FCL30A015.html
                                          But 0.05V seems to low.
                                          Is it gone?
                                          Should I perform some other test?...
                                          04-28-2022, 01:45 PM
                                        • asr
                                          Finding replacement diode iPad Pro 3rd gen A1701
                                          by asr
                                          Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                                          Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                                          07-09-2024, 06:24 PM
                                        • unimatrix93
                                          TV backlight zener diode
                                          by unimatrix93
                                          Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                                          So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                                          Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                                          The led strips has 9 6V leds.
                                          02-10-2025, 12:13 PM
                                        • NicRac
                                          monowheel repair,Is the diode the problem?
                                          by NicRac
                                          Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                                          First of all, I am new here. Therefore I will shortly introduce myself.
                                          I am Nico and currently I study Physics.
                                          In my freetime I like to build and repair stuff. Especially big battery's.
                                          A few years ago I got myself an electric unicycle, monowheel or however you call that.
                                          The battery bms was broken so I replaced and resolder that. Nothing big.
                                          I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                                          07-26-2024, 06:13 AM
                                        • eccerr0r
                                          Electric lawnmower...purpose of diode...
                                          by eccerr0r
                                          I was looking at an old battery powered electric lawnmower I picked up as the previous owner didn't want to buy a new board to replace a ruined old board. Tried to study how it was designed - it appears it has a huge 80A contactor...or rather, a 80A relay. It appears to be SPDT to control the motor. A 30A relay protects the circuitry.
                                          The weird thing I don't quite get is how this thing is connected. The common contact is connected to the motor. The NO contact is connected to the battery, which is expected, so when the relay is activated, the common is connected to the NO contact and...
                                          08-27-2022, 12:54 PM
