monowheel repair,Is the diode the problem?
  • NicRac
    • Jul 2024
    • 9
    Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
    First of all, I am new here. Therefore I will shortly introduce myself.
    I am Nico and currently I study Physics.
    In my freetime I like to build and repair stuff. Especially big battery's.
    A few years ago I got myself an electric unicycle, monowheel or however you call that.
    The battery bms was broken so I replaced and resolder that. Nothing big.
    I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything should be sealed but accidentally some water came inside. But I think at that time it was already to late. It was turning on but it blinked weird and I could realise some electronic smell from inside. I immediately opened everything and cleaned it. I realised, that there was no real water inside the electronics compartment only some moisture and corroison from the long use. I cleaned everything up but still nothing. I found out that the region in the picture (Coil and Diode) got really hot and emit that smell. Also there was a short circuit in the capacitor region. I measured the Diode and found out that there is a connection from both sides. The multimeter beeped. I am not an expert in electronics so I unsoldered the Diode. The Short circuit disappeared at the capacitors but still it seems like I have not solved the problem.
    What do you guys think?
    What could be the problem?
    And will a Diode replacement solve it?
    Thanks in advance for any help☺️
    • 31262
    be very carefull handling high current battery packs!
    https://vidmax.com/video/228647-grap...ng-him-on-fire
      • 31262
      it's a P6SMB18A
      https://www.littelfuse.com/products/.../p6smb18a.aspx
      • truclacicr
        • Apr 2019
        • 352
        • australia
        The diode is protecting the IC from overvoltage.
        Here is the datasheet for the IC:
        https://www.monolithicpower.com/en/d...n/sku/MPQ2315/
        • NicRac
          • Jul 2024
          • 9
          Hello, thanks for the answers☺️
          Therefore the IC is broken aswell?
          But why should there be an overvoltage? Because of the water damage, the short circuit, or maybe the coil? Could this be enough reason to overload the IC?
          The Diode itself is not broken, right?
          • petehall347
            • Jan 2015
            • 4447
            its a tvs diode .it should be quick enough to protect the ic .
            • NicRac
              • Jul 2024
              • 9
              So the IC might be okay?
              So is the diode, even there is a short from both sides?
              And why the diode or the coil are getting that hot? Where exactly is the power coming from?
              From the big capacitors on the left side, right?
