Electric lawnmower...purpose of diode...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8704
    I was looking at an old battery powered electric lawnmower I picked up as the previous owner didn't want to buy a new board to replace a ruined old board. Tried to study how it was designed - it appears it has a huge 80A contactor...or rather, a 80A relay. It appears to be SPDT to control the motor. A 30A relay protects the circuitry.
    The weird thing I don't quite get is how this thing is connected. The common contact is connected to the motor. The NO contact is connected to the battery, which is expected, so when the relay is activated, the common is connected to the NO contact and runs the motor.
    The weird thing is that the NC contact of that relay also has a connection - it's connected to (apparently) a diode's anode! The cathode of the diode appears to be connected to ground. This is a BIG diode... a stud diode.
    While this appears to also provide faster slowing of the blade when the motor is shut off, couldn't a resistor or simply connecting the NC contact to ground do, instead of an "expensive" diode? Would the diode really protect the relay contacts that much better than just using a resistor?
    • 31262
    Re: Electric lawnmower...purpose of diode...
    it kills the reverse transient pulse and provides static breaking.
    most electric stuff with blades has to stop within a very short period to meet safety standards
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8704
      Yeah but why a diode and not a resistor?
        • 31262
        a resistor wont kill the pulse.
        i'm surprised they didnt just short it with a relay - thats a common method
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8704
          A low ohmage resistor would eat the pulse (it's a brushed DC motor, there isn't much of a pulse, voltage there would be mostly dependent of the RPM at the time of cut off)...why not just use a 0 ohm resistor (i.e. short)!
          Instead there's this fancy shmancy diode...
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8342
            Nope, it won’t.
              • 31262
              a resistor would have to be solid metal oxide- and very expensive.
              a cheap wirewound resistor would be a broadcast antenna!!!
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8704
                Actually, still... there is no real (large) pulse. Yes it's inductive but most of the energy that's stored is not in that magnetic field, but rather rotational energy of the blade. Besides, if there really is that much energy, why are car starter motors not treated the same way?
                  • 31262
                  cars have a diode-pack in the alternator.
                  also, newer cars are stuffed with MOV's and reverse-protection diodes in every electronic module
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8704
                    diode pack in the alternator is not for protection.
                    Shutting off a starter motor does not generate a reverse pulse.
                    Not all cars have MOVs.
                    So... keep guessing?
                      • Jul 2011
                      • 6070
                      I would think that if you used a resistor for this it would have to be huge to do the same thing that the diode does but that is just a guess
                      But yea it is mandated by government that the blade has to stop with in a certain time to supposedly protect the user from being injured so who really knows
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8704
                        Diode needs to be equally huge, both need to dissipate the same amount of energy to dissipate energy slowing down the blade!!!
                        Come on guys, think! So far it looks like all theories that have been presented have counterexamples.
                        So far the only possible reason I can think of is that the package of the diode (which is a stud diode so it has a nut to hold it onto a bracket) is so convenient that they can consistently mount it and not have it vibrate off from all the shaking as the mower turns and rolls over uneven terrain, versus some PCB mount power resistor. That's all I can think of, else a resistor seems like the better option.
                        Any counterexamples for this reasoning, other than the diode is not cheap which was the original concern?
                        BTW:
                        Nope, it won’t.
                        Yes a short or low ohm resistor would eat the pulse - if there was much of one to begin with. This is more mechanical energy than inductor di/dt energy here. Note that you are not restricted to the same solutions for this situation as for flyback transformers and relay windings due to the nature of this circuitry.
                        I just thought of another possible advantage of a diode:
                        You can spin the blade with your hand if there's a diode there up to a certain speed. If you have a short or resistor, at 0 RPM it will always give resistance to spinning. I'm not sure of the practical reasoning for this but if someone could give a good explanation for having this functionality (perhaps to reduce returns "hey my motor is jammed I want a refund!") then this would be a good reason for a diode!
                        • redwire
                          • Dec 2010
                          • 3912
                          For safety reasons- circular saws, cutoff saws, lawnmowers etc. have to brake when switched off, rather than slowly spin down.
                          They are brushed universal motors in most power tools.
                          With a PM motor in a lawnmower, you get generator-action it acts like a dynamo with the momentum of the spinning blade(s).
                          Which means braking makes full voltage and current for a short time - too much for a cheap switch or N.C. relay contact.
                          Add a resistor? Let's say for 50A. A typical wirewound is maybe 10-30x power for short overloads. A 10W 0.02ohm part seeing 50W pulse is OK but maybe not reliable enough?
                          I think using a diode, it's a cheap resistor in the sense that it can take very high surge currents, has some heatsinking, they like to fail short (safe).
                          If you started/stopped the lawnmover 10 times it would cook the braking resistor.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8704
                            if you start/stopped the lawnmower 10 times it would cook the diode too! I still see no benefit with a diode than a resistor, if it fails short, it'd be no different than a resistor.
                            Also how often can one really make a surge, once per second at most? If you don't let it spin up all the way, you'll get less energy to dissipate. And again the amount of energy that needs to be dissipated is the same whether it's a diode or resistor.
                            Not only this, the resistor here can be ±100% and still be useful in braking.
                            BTW if someone is curious the diode looks like a MUR5010 but I didn't look at the part number. I'm sure a slow recovery unit would work just fine here too so it's probably not a MUR5010, but you can get almost two 50W 0.02Ω±1% resistors for the price of one MUR5010 ...
                            • petehall347
                              • Jan 2015
                              • 4447
                              is the proposed resistor in parallel when the motor is running ? if so it likely won't even run because power will shut off . if its only parallel when switched off normally its a safety issue in case of loss off power say through a bad motor connection etc ..a diode can sit there right across the motor and be fine . yes i know the resistor can be switched in electronically but would cost more and be not as reliable .
                              anyway i am probably talking crap again .
                              on another note i don't suppose you know who makes the motors for stihl battery equipment . ? bloody expensive with their name on the sticker .
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8704
                                The proposed resistor is only in parallel with the motor when the relay is off, in the exact same position as the diode - just swap it straight out. The contactor/relay prevents the diode from eating power.
                                They indeed are for stopping the motor rotation as quickly as possible when the "operator detected" switch is lost...
                                • redwire
                                  • Dec 2010
                                  • 3912
                                  That second 30A relay does not make sense, I wonder if we have the whole picture.
                                  We don't know the peak current for braking. It depends on the motor winding resistance, magnets etc. and likely ramps down to zero in a second or two. What does the motor put out/consume for peak power?
                                  A relay has a weaker current rating for the N.C. contact, compared to the N.O. contact. This is because contact pressure is only from the return spring. So an 80A relay might only be rated 40-60A for the N.C. contact. Check the datasheet to see what its limit is.
                                  I know a braking resistor is technically right here but there's a risk of it fusing open if it's small and cheap. DO-5 diode is small 15-17mm, extra labour to wire in. MUR5005 can take 50A for 1sec. and blows the doors off a resistor for surge current and not failing open. I think it's the ratio of average to peak current a part can take.
                                  Or the diode is perhaps a zener or it's doing something else.
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8704
                                    whoops. I made a mistake in the OP - it's not a 30A relay, it's a 30A circuit breaker.
                                    My guess is that the motor is ⅓HP, and the steady state current is about 10A. However the total rotating mass and RPM is needed to know how much total energy the device needs to dissipate...
                                    The DO-5 is a fairly large diode IMHO and can actually deal with 50A continuous with proper heatsinking. The actual diode is not on a heatsink but on a small metal bracket.
                                    I wouldn't think that one could use a 1% resistor but just use a wad of nichrome to dissipate the energy?
                                      Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                      I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                      The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                      Found shorted diodes on main controller relays there are 3 of them that...
                                      01-07-2023, 05:43 PM
                                    • InsertCoin
                                      Relay Satronic MMI 810.1 bad diode & Transistor
                                      by InsertCoin
                                      Hello and happy new year ,
                                      my Analog Combustion Machine Honeywell gone bad and I don't know what type of diode is utilized.
                                      There is no mark around the body of the diode. The Schematics are general referred only, without any electronics components and values.
                                      The two contacts (2),(5) of the Relay Coil need 48 Volts DC to begin operating. Between these two contacts in series is the bad diode and near of contact (5) is the bad pnp (bc856b) Transistor that can be easily replaced.
                                      I have made a diagram of the PCB and some measurements along some...
                                      01-16-2024, 05:47 AM
                                    • redwire
                                      Exploding motor cap on Ryobi electric pressure washers - product recall
                                      by redwire
                                      Exploding motor cap on Ryobi electric pressure washers.
                                      Recall is for 764,000 units and 16,000 sold in Canada.
                                      "TTI Outdoor Power Equipment has received 135 reports of capacitors overheating, including 41 reports of explosions, resulting in 32 injuries and/or fractures to the fingers, hands, face, and eyes."
                                      Broken bones? Shrapnel In your face? Never reach for the on-off switch, just run away!
                                      Found this pic on Reddit, cap looks like a plastic housing electrolytic? with big rubber bung at the end.
                                      Safety vent too expensive! DELETE DELETE
                                      08-31-2025, 11:03 AM
                                    • SolomonMan
                                      Electric Motor Question....
                                      by SolomonMan
                                      All,
                                      Yesterday in the morning the fan was fine. Its approximately 10 years old. Its one of those high Velocity types.
                                      In the afternoon I noticed it was not running any longer.
                                      During the investigation, I confirmed the wiring, confirmed the 3 way switch is fine, the Capacitor measures the correct Microfarads. So I went to the Motor;
                                      No smell of burnt and it spins very easily. I started to measured the continuity between the 6 wires.
                                      I have included a diagram from a YouTube video I found but basically the wiring is identical. The only exception...
                                      10-29-2023, 08:02 AM
                                    • BOSCHNJAK
                                      by BOSCHNJAK
                                      ABOUT ME INTRODUCTION FILE
                                      2
                                      024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                                      2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                                      2022 BEV, PROJECT ?
                                      2021 BEV, PROJECT ?
                                      2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                                      2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                                      12-28-2023, 02:09 PM
