VStanby (V SB) question ?
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: VStanby (V SB) question ?
    PS: In the first post i see that the 5VSB rectifier diode MIGHT be shorted...
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
      Yes, that 0.1Vf reading is not right, I do not believe the Vf can be that low.
      It is in BOTH directions so it is bad. Same readings off the board? But it is for sure the rectifier diode for the 5VSTBY?
      So the bottom line right now is that the 5VSTBY is steady at 5V with and without the load?
        • 31247
        i think if it was shorted the caps would explode.
        • bianchi77
          • Jun 2016
          • 1121
          I have replaced 5VSB diode, now I got 5.02V on VSB..
          • Khron
            • Sep 2006
            • 1350
            • Finland
            I rest my case
            Although, aren't Fuhjyyu's known for also failing without visible signs?
            • bianchi77
              • Jun 2016
              • 1121
              0.1Vf for another diode beside 5VSTBY, I have replaced 5VSTBY....and it's stable on 5.02V now.
              There is another one, it's 5V main power supply rectifier SBL1040 (3pins)
              on 12V rectifier it's 0.467V Vf.....but on 3.3V I can see it's using FET CET603...
              Is there any possibiity that my PWM is faulty already ? it's SG6105
              Because it has 3 functions : Power Supply Supervisor + Regulator + PWM
              and it's not responding anymore to PSON anymore..
              anyway to test this SG6105 ?
              • bianchi77
                • Jun 2016
                • 1121
                I rest my case
                so it can't be seen bulge if it's failed ....only measuring ESR and capacity off board for testing them ?
                hmm....I'll replace them then...thanks there are 4 of them I haven't replaced...
                • bianchi77
                  • Jun 2016
                  • 1121
                  It's easier to explain to you guys, if there's a schematic available, but I can't find it, anyone knows ?
                  • bianchi77
                    • Jun 2016
                    • 1121
                    another think in my mind, for example SBL1040 for 5V main is faulty....SG6105 will detect it and it will lock down the circuit, do you reckon ?
                    • Khron
                      • Sep 2006
                      • 1350
                      • Finland
                      #30
                      https://www.badcaps.net/forum/showthread.php?t=388
                      Nope, you won't find (exact) schematics anywhere. On the bright side though, especially these cheapo PSU's all follow the same basic structure.
                      https://www.badcaps.net/forum/showthread.php?t=1238
                      Yes, most likely the chip senses the under-voltage on the 5V line, and turns itself off (or at least the PWM side).
                      • bianchi77
                        • Jun 2016
                        • 1121
                        Ok, the step I'll change the major caps first then replace SBL1040....the issue is, I need to wait for SBL1040 coming.....will be long 1 month or so....or can it be replaced with a pair of FR302 join together ?
                        • bianchi77
                          • Jun 2016
                          • 1121
                          They do it with 12V rectifier, 2 FR302 diodes are joined together to rectify...
                          • Khron
                            • Sep 2006
                            • 1350
                            • Finland
                            #33
                            What exactly are you hoping to use this power supply for?
                            SBL1040 = 10A 40V
                            FR302 = 3A 100V
                            2x 3A = 6A, which is considerably lower than 10A, wouldn't you say?
                            Also, keep in mind that (ultra)fast rectifiers will have about 1-1.1v drop at rated current, as opposed to 0.6v or so, in the case of Schottky rectifiers (hint-SBL1040-hint).
                            • bianchi77
                              • Jun 2016
                              • 1121
                              I'm going to use it for a testing only...
                              I check from my DMM FR302 brand new, it's 0.17V....is it right ?
                              • Khron
                                • Sep 2006
                                • 1350
                                • Finland
                                #35
                                That sounds really low, even if it was a Schottky.
                                When's the last time you looked into a diode datasheet?
                                https://cdn.badcaps-static.com/pdfs/...d12d739f56.pdf
                                Page 2, bottom left. Depending on the current passing through the diode (vertical axis), the forward voltage drop will vary.
                                That being said, we can't know how (in)accurate your DMM is, though...
                                https://cdn.badcaps-static.com/pdfs/...3aa0426335.pdf - A healthy FR302 should be showing at least 0.5-0.6v at the really low test-current a DMM uses.
                                • bianchi77
                                  • Jun 2016
                                  • 1121
                                  this power supply is writing a wrong spec...it's written 5V 35A on its lid....but the real ability is 5V 10A.....what a marketing strategy to take a lot of profit from constumer....10A and 35A diode is different...like you said between 3A and 10A just now...
                                  • bianchi77
                                    • Jun 2016
                                    • 1121
                                    is it possible that my DMM battery low ?sometimes it can not start quickly....the voltage on DMM supply is 2 pcs AA batteries, which is 3V...
                                    • bianchi77
                                      • Jun 2016
                                      • 1121
                                      I'll show you the photo when I test it later on....for information sharing..
                                        If you look at how the Common Cathode SBL1040 is connected to produce 5V, it is connected in parallel, so it is still can handle 20A (if both internal diode Vf are matched and has proper heat management), but not at 35A
                                        • bianchi77
                                          • Jun 2016
                                          • 1121
                                          correction, I got 0.447V on Vf diode test for brand new FR302...
                                          • Baste
                                            MBR3045CT and SR3045LCT Schottky diode testing help.
                                            by Baste
                                            Hello experts,
                                            Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
                                            Aneng ST182 Meter.
                                            Diode mode.
                                            MBR3045CT:
                                            Diode mode
                                            Pin 2-1 - 0.150v
                                            Pin 2-3 - 0.150v ...
                                            10-21-2025, 06:14 AM
                                          • caprider
                                            FCL30A015 diode reverse biased shows 35 Ohm, 0.05V forward. Is it gone?
                                            by caprider
                                            I am troubleshooting a power supply.
                                            When measuring a FCL30A015 diode it shows 35 Ohm when reverse biased and 0.05 forward voltage.
                                            See attached.
                                            The datasheet does say "Extremely Low Forward Voltage Drop": https://www.alldatasheet.com/datashe...FCL30A015.html
                                            But 0.05V seems to low.
                                            Is it gone?
                                            Should I perform some other test?...
                                            04-28-2022, 01:45 PM
                                          • asr
                                            Finding replacement diode iPad Pro 3rd gen A1701
                                            by asr
                                            Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                                            Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                                            07-09-2024, 06:24 PM
                                          • unimatrix93
                                            TV backlight zener diode
                                            by unimatrix93
                                            Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                                            So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                                            Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                                            The led strips has 9 6V leds.
                                            02-10-2025, 12:13 PM
                                          • NicRac
                                            monowheel repair,Is the diode the problem?
                                            by NicRac
                                            Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                                            First of all, I am new here. Therefore I will shortly introduce myself.
                                            I am Nico and currently I study Physics.
                                            In my freetime I like to build and repair stuff. Especially big battery's.
                                            A few years ago I got myself an electric unicycle, monowheel or however you call that.
                                            The battery bms was broken so I replaced and resolder that. Nothing big.
                                            I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                                            07-26-2024, 06:13 AM
