VStanby (V SB) question ?
  • bianchi77
    replied
    Re: VStanby (V SB) question ?
    so the most possible faulty part is SBL2040 or SG6105, but I'm not sure for this PWM controller ...could be still good only shutting down the PSU because of no voltage from SBL2040..
  • bianchi77
    replied
    what I've done with FET CEP603...
    I connect DMM on diode test...black lead to S and Red to D....it's OL...
    then I touch red probe to G to make it ON and I got 0.247V....is it good enough....
    then I touch black probe to G to make it OFF and I got OL again...
    I reckon this FET is ok....any opinions ?
  • bianchi77
    replied
    is there any quick way testing FET with DMM ? I see the D S diode connection 0.546V looks like this FET is ok...
  • bianchi77
    replied
    test with SBL2040...correction from SBL1040...
    and some capacitor photos I've replaced...
  • bianchi77
    replied
    here's the photo :
  • bianchi77
    replied
    correction, I got 0.447V on Vf diode test for brand new FR302...
    replied
    If you look at how the Common Cathode SBL1040 is connected to produce 5V, it is connected in parallel, so it is still can handle 20A (if both internal diode Vf are matched and has proper heat management), but not at 35A
  • bianchi77
    replied
    I'll show you the photo when I test it later on....for information sharing..
  • bianchi77
    replied
    is it possible that my DMM battery low ?sometimes it can not start quickly....the voltage on DMM supply is 2 pcs AA batteries, which is 3V...
  • bianchi77
    replied
    this power supply is writing a wrong spec...it's written 5V 35A on its lid....but the real ability is 5V 10A.....what a marketing strategy to take a lot of profit from constumer....10A and 35A diode is different...like you said between 3A and 10A just now...
  • Khron
    replied
    That sounds really low, even if it was a Schottky.
    When's the last time you looked into a diode datasheet?
    https://cdn.badcaps-static.com/pdfs/...d12d739f56.pdf
    Page 2, bottom left. Depending on the current passing through the diode (vertical axis), the forward voltage drop will vary.
    That being said, we can't know how (in)accurate your DMM is, though...
    https://cdn.badcaps-static.com/pdfs/...3aa0426335.pdf - A healthy FR302 should be showing at least 0.5-0.6v at the really low test-current a DMM uses.
  • bianchi77
    replied
    I'm going to use it for a testing only...
    I check from my DMM FR302 brand new, it's 0.17V....is it right ?
  • Khron
    replied
    What exactly are you hoping to use this power supply for?
    SBL1040 = 10A 40V
    FR302 = 3A 100V
    2x 3A = 6A, which is considerably lower than 10A, wouldn't you say?
    Also, keep in mind that (ultra)fast rectifiers will have about 1-1.1v drop at rated current, as opposed to 0.6v or so, in the case of Schottky rectifiers (hint-SBL1040-hint).
  • bianchi77
    replied
    They do it with 12V rectifier, 2 FR302 diodes are joined together to rectify...
  • bianchi77
    replied
    Ok, the step I'll change the major caps first then replace SBL1040....the issue is, I need to wait for SBL1040 coming.....will be long 1 month or so....or can it be replaced with a pair of FR302 join together ?
  • Khron
    replied
    Originally posted by bianchi77
    so it can't be seen bulge if it's failed ....only measuring ESR and capacity off board for testing them ?
    hmm....I'll replace them then...thanks there are 4 of them I haven't replaced...
    https://www.badcaps.net/forum/showthread.php?t=388
    It's easier to explain to you guys, if there's a schematic available, but I can't find it, anyone knows ?
    Nope, you won't find (exact) schematics anywhere. On the bright side though, especially these cheapo PSU's all follow the same basic structure.
    https://www.badcaps.net/forum/showthread.php?t=1238
    another think in my mind, for example SBL1040 for 5V main is faulty....SG6105 will detect it and it will lock down the circuit, do you reckon ?
    Yes, most likely the chip senses the under-voltage on the 5V line, and turns itself off (or at least the PWM side).
  • bianchi77
    replied
  • bianchi77
    replied
  • bianchi77
    replied
    I rest my case
    Although, aren't Fuhjyyu's known for also failing without visible signs?
  • bianchi77
    replied
    Yes, that 0.1Vf reading is not right, I do not believe the Vf can be that low.
    It is in BOTH directions so it is bad. Same readings off the board? But it is for sure the rectifier diode for the 5VSTBY?
    So the bottom line right now is that the 5VSTBY is steady at 5V with and without the load?
    0.1Vf for another diode beside 5VSTBY, I have replaced 5VSTBY....and it's stable on 5.02V now.
    There is another one, it's 5V main power supply rectifier SBL1040 (3pins)
    on 12V rectifier it's 0.467V Vf.....but on 3.3V I can see it's using FET CET603...
    Is there any possibiity that my PWM is faulty already ? it's SG6105
    Because it has 3 functions : Power Supply Supervisor + Regulator + PWM
    and it's not responding anymore to PSON anymore..
    anyway to test this SG6105 ?
  • Baste
    MBR3045CT and SR3045LCT Schottky diode testing help.
    by Baste
    Hello experts,
    Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
    Aneng ST182 Meter.
    Diode mode.
    MBR3045CT:
    Diode mode
    Pin 2-1 - 0.150v
    Pin 2-3 - 0.150v ...
    10-21-2025, 06:14 AM
  • caprider
    FCL30A015 diode reverse biased shows 35 Ohm, 0.05V forward. Is it gone?
    by caprider
    I am troubleshooting a power supply.
    When measuring a FCL30A015 diode it shows 35 Ohm when reverse biased and 0.05 forward voltage.
    See attached.
    The datasheet does say "Extremely Low Forward Voltage Drop": https://www.alldatasheet.com/datashe...FCL30A015.html
    But 0.05V seems to low.
    Is it gone?
    Should I perform some other test?...
    04-28-2022, 01:45 PM
  • asr
    Finding replacement diode iPad Pro 3rd gen A1701
    by asr
    Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
    Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
    07-09-2024, 06:24 PM
  • unimatrix93
    TV backlight zener diode
    by unimatrix93
    Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
    So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
    Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
    The led strips has 9 6V leds.
    02-10-2025, 12:13 PM
  • NicRac
    monowheel repair,Is the diode the problem?
    by NicRac
    Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
    First of all, I am new here. Therefore I will shortly introduce myself.
    I am Nico and currently I study Physics.
    In my freetime I like to build and repair stuff. Especially big battery's.
    A few years ago I got myself an electric unicycle, monowheel or however you call that.
    The battery bms was broken so I replaced and resolder that. Nothing big.
    I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
    07-26-2024, 06:13 AM
