Any practical examples of success repairs
  • Jane
    • Aug 2010
    • 189
    Are there available( anywhere) any successful repairs of switched-mode power supplies?
    I found a few on YouTube but they were rather simple( e.g.changing dried capacitors ). I would like to see( and learn)how to solve more serious faults and not those trivial ones that can be seen at the first look.
    Thank you.
    • 31304
    Re: Any practical examples of success repairs
    shorted diodes or fets are common.
    cracked soldering is also common.
    • retiredcaps
      • Apr 2010
      • 9271
      Some of these channels have SMPS repair beyond the simple bloated capacitor, but none that are dedicated.
      https://www.youtube.com/user/TheSignalPathBlog/videos
      https://www.youtube.com/user/norcal7...ow=grid&view=0
      https://www.youtube.com/user/Maxxarcade
      https://www.youtube.com/user/ATVVideoProductions/videos
      https://www.youtube.com/user/FFcossag/videos
      https://www.youtube.com/user/JonnyFixy/videos
      https://www.youtube.com/watch?v=NoGl7oeh7eU
      http://www.repairfaq.org/sam/smpsfaq.htm
      Sorry, I don't recall which exact episodes, but you can look and read through the titles for yourself.
      --- begin sig file ---
      --- end sig file ---
      • CapLeaker
        Leaking Member
        • 8352
        to add to sti's comment:
        open resistors, or resistors that changed value outside the tolerance. PWMs that don't switch. Blown up gate drive circuit (when the Mosfet is shorted).
        • Jane
          • Aug 2010
          • 189
          Thank you for the replies but this thread is not closed :-)
          So if you find an interesting repair ( preferably describing a procedure from the beginning to a successful repair)
          It would be appreciated.
          • Marianelforum
            Dj Marik
            • Jul 2016
            • 26
            • Romania
            I do not know of repair stories on youtube ( did'nt searched for any ), but speaking from my own experiance, there are sometimes psu's that suffered too much damage to be worth fixing, just a few days ago i gave up fixing a rather interesting PC power supply because of the extensive damage, many thin copper traces practicly vaporised, traces that lead to many very small SMD components ( you can imagine the damage ), many power semiconductor's exploded, even some "coocked" power traces... So i have decided that it is not worth fixing it.
            Many well designed psu's have built in fail-safe's that can limmit the damage they can suffer from normal use especially when caps die ( and often they are the cause ), or even on some abuse. So you can end up sometimes with an easy fix.
            • zx8401
              Phantom Fiddler
              • Aug 2013
              • 49
              I would say a basic knowledge of the typical blocks used in power supplys is very helpfull, there are many schematic diagrams on the outernet, look at most and you will see common designs/patterns.
              Pattern recognition is built into all of us, wear it out looking at schematics .
              Basic knowledge can get you a loooooooong way lol.
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                I would start with something like this http://www.learnabout-electronics.org/PSU/psu30.php and learn each section and how they work. If you are unable to understand something then post it as there are many people on this sight that have a good understanding. Once understood, then you will need to have equipment to help you troubleshoot the power supply.
                  Hers is one of many on BADCAPS.
                  https://www.badcaps.net/forum/showthread.php?t=51797
                  Post #1~28.
                  Here is the success repair with 64 cents part, no visual sign of damage.
                  The common test that I always request the OP is to find out if we have DC on the main filter cap or not after the visual inspection and simple fuses testing.
                  But the the bottom line is that you need to know the basic electronics, about the components, how the power supply functions (in this case since you want to learn how to go about fixing the power supply), and lots of on hand experience. You have to at least be able identify each section of the power supply board even if you have never seen the board before, when you have been doing long enough you will see the pattern.
                  Originally posted by budm
                  OK, it is the same board.
                  You need to do resistance test on the Diodes D10, D21 (mounted on the heatsink), D22, and D23 to see if any of them show low resistance in both directions.
                  You probably wonder how I come up with that question for the OP about checking those particular 3 diodes but not ALL the diodes on the board.
                    • 31304
                    i changed a fuse.
                    • everell
                      • Jan 2009
                      • 1514
                      You asked for it, so here is the story of a smps power supply that was "burned up".
                      https://www.badcaps.net/forum/showthread.php?t=9660
                      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                      • CapLeaker
                        Leaking Member
                        • 8352
                        There are some I posted too. Also look at the NT5B01, there were a couple of funny behaving PSU's in there, that worked for a bit, then shut off.
                        • Jane
                          • Aug 2010
                          • 189
                          Thank you ALL for the links
                          What measure equipment do you use to check transformer's windings?
                          Only LCR bridge? I also read about Anatek Blue Ring "Q" Meter Kit .
                          Does anyone use it?
                          Is it worth buying it?
                          Thanks again
                            I do not have the Blue ring tester, I use SENCORE LC-75.
                            http://preher-tech.com/documents/tes...ormersinlcdtvs
                            • Jane
                              • Aug 2010
                              • 189
                              @budm: Thanks for the reply.But can you please explain why LCR bridge is not enough?
                              I still do not know why someone uses a device like a blue ring tester( or similar) and not LCR bridge instead.
                              Thank you
                                If you want to use LCR then you need to know the inductance of a known good transformer to see what inductance you get and compare it to the suspect bad transformer that has some shorted turn.
                                You can try that experiment with two transformers with same spec., then make one with shorted turn and one without and see what reading you get on the LCR.
                                  BTW, what tools do you have right now?
                                  And what kind of experience and knowledge base do you have?
                                  Able to read schematic?
                                    • 31304
                                    Does anyone use it?
                                    Thanks again
                                    blue-ring?
                                    that's the bob parker design.
                                    i made my own on stripboard.
                                    http://members.ozemail.com.au/~bobpar/fbt.htm
                                    • michael dranfield
                                      • Jan 2016
                                      • 232
                                      • England
                                      I made this 16 years ago before the importance of effective series resistance had been fully appreciated.
                                      • Jane
                                        • Aug 2010
                                        • 189
                                        @budm: I have DMM, LCR bridge with ESR meter, oscilloscope. I work with a company that repairs satellite receivers and mobile phones.Yes, I can read schematic.
                                        @stj: Thanks for the pdf file
                                        • blues_spirit
                                          practical courses for troubleshooting pc motherboards
                                          by blues_spirit
                                          Hello from France,
                                          mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                                          Do you think this is feasible for me? I...
                                          12-18-2022, 12:56 PM
                                        • valvashon
                                          Repair Success! Middle Atlantic UPS2200R-IP
                                          by valvashon
                                          Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                          Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                          02-06-2024, 12:54 PM
                                        • zomi
                                          Manual cof bonding success rate ?/ feedback wanted
                                          by zomi
                                          Just wanted to get some feedback,
                                          whats peoples' success rate with cof bonding repairs.....
                                          09-23-2024, 12:45 PM
                                        • Mess
                                          Motherboard diagnostic beginner advice
                                          by Mess
                                          To save you some time: the most important bits are in bold.
                                          Some further examples/explanations or to the side & in grey - you can probs skip them if it's TLDR for you. Sorry, I've got ADHD & tend to over-explain stuff - just like I'm doing right now 😅 Briefness is for poets not me 🙈
                                          Please help!! 🎶I'm just a girl in a world that wants to scam me out of lots of money for any tech stuff/repairs 🎵 Seriously tho, I'm poor&I can't afford to get laptop diagnosis, especially if it ends up needing a new motherboard. Where I live, all the tech shops are run by very...
                                          09-12-2024, 07:02 PM
                                        • Valtekken
                                          Lenovo IdeaPad 3 15ADA05 (model name 81W1) - Trying to flash the correct serial number, machine type and UUID without success
                                          by Valtekken
                                          Specs:
                                          • CPU=AMD Ryzen 5 3500U
                                          • GPU=(integrated) Radeon Vega Mobile
                                          • RAM=8GB (2x4GB, a 4GB set is soldered), DDR4; 1x4GB Ramaxel, 2400MT/s, RMSA3310MJ86H9F-3200; 1x4GB Micron, 2400 MT/s, no part number (soldered)
                                          • Storage=512GB, NVMe SSD, hfm512gdhtni-87a0b
                                          Hello everyone.
                                          My issue isn't massive, but I'd like to get this solved since I'm trying to fix a friend's laptop.
                                          A botched BIOS update by Lenovo bricked this laptop, so I used my BIOS programmer to reflash the BIOS on it and saved it from an early demise. All is good now, but the BIOS reports the S/N, MTM and UUID...
                                          09-10-2025, 04:14 PM
