HX750 can't turn ON
  • frogz81
    • Oct 2012
    • 31
    • Indonesia
    HX750 can't turn ON
    I need help. I have HX750,
    the problem is when turn ON PSU, the fan only spin a moment.
    before the issue occur, the PG signal is 4.5 V.
    need help, where i must started to check?
    Thx
  • frogz81
    • Oct 2012
    • 31
    • Indonesia
    Re: HX750 can't turn ON
    Adding attachment from http://www.hardwaresecrets.com/ since i don't have good camera.
    • Viperel
      • May 2016
      • 34
      • Romania
      Are there any visual defects present on the board? Some photos of YOUR psu would really help...
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3266
        • Singapore
        your symptoms seems to indicate a short circuit. it could be on the motherboard or in the psu.
        • frogz81
          • Oct 2012
          • 31
          • Indonesia
          Already checked Output and no short circuit ,
          the pin 5Vsb is normal 5,04 V
          • frogz81
            • Oct 2012
            • 31
            • Indonesia
            Help
              • 31246
              check for shorted diodes on the outputs
              • frogz81
                • Oct 2012
                • 31
                • Indonesia
                up date,
                change Cap in 5vsb 1000uf/10v NCC KY wilt ruby zlh 2200/16 and it's works
                strange thing is the NCC capacitance is in spec, and esr 0,4
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Originally posted by frogz81
                  up date,
                  Sounds like the cap possibly had bad solder joints...
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                    • 31246
                    or high leakage, or low ripple capacity - a lot of testers dont show that.
                    • Clutchbox
                      Cap Clutcher
                      • Sep 2011
                      • 41
                      • The Netherlands
                      up date,
                      NCC KY 10v 1000uF according specsheet:
                      1,000 8x20 0.069 Ohm 1,050A
                      1,000 10x16 0.060 Ohm 1,210A
                      An ESR of 0,4 Ohm (400 mOhm) is much to high for this capacitor, maybe it was the culprit.
                      • jiroy
                        • Jun 2016
                        • 2416
                        • Lebanon
                        100 % and it's better if he resolder whatever stressed joints he can check ...
                        • pajdek
                          Lenovo Y700-17ISK turn on and off
                          by pajdek
                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                          09-20-2023, 02:49 AM
                        • RdeveLabs
                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                          by RdeveLabs
                          To all the members here...
                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                          05-05-2025, 04:59 AM
                        • robante15
                          Acer Aspire 4520 won't turn on after reboot
                          by robante15
                          Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                          It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                          The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                          If I remove the...
                          04-06-2024, 06:50 PM
                        • masoksian
                          Dell latitude e7470 not turn on .power buton on off and Run Power problem
                          by masoksian
                          I am dealing with the problem of turning on and off my Dell e7470 notebook.
                          The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                          The system does not turn on, there is no post.
                          I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                          The problem continues in the same way.
                          I tried to turn on the Fn key, nothing came to the screen....
                          02-15-2025, 12:08 PM
                        • dqtech
                          lenovo x240 nm-a091 wont turn on
                          by dqtech
                          i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                          board number VIUX1 NM-A091 REV:1.0...
                          02-07-2024, 01:57 AM
