LG 47LC7DF PSU dead
  • farmtech
    • Jan 2014
    • 14
    LG 47LC7DF PSU dead
    Hello, wondering if anyone has a schematic for the LG 47LC7DF power supply board, PN EAY36781301. I replaced the usual bad caps 2 years ago but now the supply is completely dead, the only thing I can find is 5VSB reads about 1.9V. No parts read open or shorted that I can find, was hoping to find a schematic to troubleshoot the standby section of the supply board. Any help would be greatly appreciated.
    Thanks,
    Nick
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: LG 47LC7DF PSU dead
    Post some pictures of your power supply here. That way we can see what you are seeing.
    Also, what brand and series of caps did you use for your replacement caps?
    • farmtech
      • Jan 2014
      • 14
      There is not much to see but I have attached some pics. The PSU is more or less dead, I am just hoping someone can point me to a schematic.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Heres a tip you should replace all the smaller capacitors as well they can cause no standby symptoms when they fail.
        • farmtech
          • Jan 2014
          • 14
          I guess I will remove the rest of the electrolytics and see how they test. I will also remove and test the fets. Other than that I will be out of ideas without a schematic.
          Are LG PSU schematics really this hard to find? I can't seem to find it anywhere.
            If you get the spec of the SMPS IC used in the STBY PS, you will see the application notes circuits showing how the IC is used, that is what I do when I do not have the diagram of the board, it does sound like bad startup-running caps.
            Is the STBY Voltage low without the main board connected to the power supply board?
            • farmtech
              • Jan 2014
              • 14
              Yes, I get about 1.9 - 2.0V whether it is connected to anything or not. I will try to identify the SMPS IC but I have not been able to trace things very well without the schematic. Thanks.
                Which one of these matched your board? Look at the barcode sticker.
                Up load good clear straight shot of both sides of the board so I can clearly see the parts and the traces on the board.
                  I would replace those small caps in the primary side.
                  • farmtech
                    • Jan 2014
                    • 14
                    I will check those out, thanks for the drawing.
                    • farmtech
                      • Jan 2014
                      • 14
                      One of those small caps did not read on my capacitance meter but it was not shorted or open either, anyway I replaced it with no luck.
                      Today I replaced the rest of the small caps even though they tested good or at least close on my meter and sure enough the standby 5V was back. After re-assembly the TV is running again. Thanks for the help Budm.
                        Thanks for the follow-up, more likely they have high ESR.
                        Did you test the ESR or just capacitance testing?
                          • 31304
                          this may be the blindspot of most meters - lack of ripple current handling.
                          • Don Brotherson
                            • Jul 2018
                            • 3
                            Well, after reading the posts, it seems unlikely that a schematic exists. That really makes it hard to identify ZD100, which broke in half probably when Q103 shorted. Or it could have been when I was trying to remove it. Either way, I can't identify the value of this ZD. Does anyone out there know this value ? Sure would appreciate it. Thanks !
                              https://www.badcaps.net/forum/showthread.php?t=65334
                              • Andreas_de
                                Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                by Andreas_de
                                Hello!
                                i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                04-12-2025, 10:38 AM
                              • Gentian
                                Please help me find 7 pin smd ic 901 part number in Delta DPS-300AB-76 LED Display Power Supply
                                by Gentian
                                I have a 5V 55A led Delta power supply with no output. I found this 7 pin IC 901 damaged as in the photo. All other elements look ok. I checked and every other surrounding componets diodes, resistors and capacitors look ok. I have 2 identical power supplies removed from a led wall which have the same defect with this ic burned but not a working one for reference. I founded by measurements that pin 7 goes to positive hot 450V 220uF electrolytic capacitor primary side. Pin 1, 2, 3, 4 connected together to pcb cooper trace. These four pins goes to negative side of 10uF 50V electrolytic capacitor...
                                09-27-2025, 11:03 PM
                              • kevin_allein
                                Samsung QE 75 Q 7 FGMTZG Power Supply dead
                                by kevin_allein
                                Hi, have this Samsung QE 75 Q 7 FGMTZG TV with no function. First analysis shows the power supply board is dead and fuse blown. Power Supply has the number BN94-11439A. I did short circuit test transistor and diodes and those do not appear to have shorts. I must admit I did not look at every single data sheet.
                                In the TV was some black dust residue, so probably one of the electrolytic caps blew, but they do not show short either.
                                Does anyone have schematics for that board ?
                                Any good tip, what could be the issue ?
                                02-27-2025, 12:15 PM
                              • khalillll
                                maxipower 400W Dead power supply repair
                                by khalillll
                                The power supply was completely dead. Voltage reached the main capacitors, but nothing after that.
                                After checking, I replaced the UTC7606D IC to restore the 5VSB.
                                I using SDC606U as a replacement, but it didn’t work — possibly the IC itself was faulty.
                                Replaced it again with another UTC7606D.
                                Result: 5VSB came back, but still nothing — no 12V, 5V, or 3.3V.
                                After checking again, I think the issue was with the UTC7520D IC.
                                Replaced it with a WT7520.
                                Result: PSU fully working again
                                09-27-2025, 05:06 AM
