Varistor for Bestec ATX0300 D5WC
  • docchan2000
    Okidoki
    • Dec 2015
    • 11
    • Ph
    I got a blown up varistor ( vr44) located bet the two big capacitors.I don't know what is the value of it or what voltage to replace it?.Pls.help. can I just put any varistor there like 100.v?
    Re: Varistor for Bestec ATX0300 D5WC
    Can we see the pictures? Are the caps connected in series or parallel? Voltage rating of the caps, 250V? 450V? The more information you provide the better we can help you.
    • docchan2000
      Okidoki
      • Dec 2015
      • 11
      • Ph
      Thanks for the reply. I don't know what voltage to put but it looks like this picture which I screen shot from hkqq2010.
      • docchan2000
        Okidoki
        • Dec 2015
        • 11
        • Ph
        Here is the specs of my atx
          You are going to have to remove the board and take hi-res pictures of the whole top side and the bottom side of the board, and then good closed up pictures around the VRxx.
          Or you will have to locate the same power supply to see what the print on the VR are.
          Right now I cannot tell how those VRs are connected to the circuits.
          • fzabkar
            • Mar 2009
            • 772
            If there is no other fault with the PSU, then power it up (without varistors) and measure the voltages at the varistor pins.
              master hoarder
              • May 2008
              • 12164
              • Bulgaria
              I think the varistors should be across each cap. I looked at pictures of two ATX-300 units I have (12E and 12Z), and they both have the varistors across the primary caps. Probably 180V or 200V-rated varistors. These Bestec PSUs don't have APFC, so the primary caps are rated for 200V. You should see half of the AC rectified voltage across each - i.e. about 162V.
              If the PSU is not in a mission critical PC or you don't care whether it gets killed from a voltage surge, then remove those varistors and run the PSU without it.
              By the way, this thread should be in the Power Supply Design and Troubleshooting forum.
              • docchan2000
                Okidoki
                • Dec 2015
                • 11
                • Ph
                Thanks for all your reply.I am new in this site and not quite familiar in posting.
                Is it OK if I just put a 300v varistor there?I'm using this PSU for my HP desktop.I'll try to take some nice pictures tomorrow.
                • fzabkar
                  • Mar 2009
                  • 772
                  Here is an ATX PSU schematic:
                  http://www.pavouk.org/hw/en_atxps.html
                  Here is the manufacturer's original circuit diagram:
                  http://web.archive.org/web/200901051...power/2038.zip
                  Here are lots more DTK PSU schematics:
                  http://web.archive.org/web/200901051.../circuitp.html
                  • docchan2000
                    Okidoki
                    • Dec 2015
                    • 11
                    • Ph
                    Here are the pictures. The red Varistor is the new one, it is a 100v varistor but I'm not sure if i should replace it with a 200v or 300v one. Thanks
                      master hoarder
                      • May 2008
                      • 12164
                      • Bulgaria
                      No point in doing that.
                      The two varistors in your PSU are installed across each 200V capacitor. The idea behind a varistor is to clamp any power surges that go beyond the 200V rating of the primary caps. If you put a 300V varistor, then it won't protect the capacitor. However, you can't use a 100V varistor either, because the voltage on each cap will be around 165V and may go up to 170 V when your line is 5% high. So that's why you need a varistor rated between 180-200V.
                      I would say just don't bother putting it in there. It won't destroy your PC. It's just that *IF* the line voltage to your house goes high due to lightning/thunderstorm or other technical issues (both of which are very rare events), then your PSU will likely fail and blow a fuse. Since this is a Bestec PSU, chances are nothing else will blow when the PSU blows up, because Bestec PSUs tend to be well-engineered. So again, I just wouldn't worry about that varistor.
                      • docchan2000
                        Okidoki
                        • Dec 2015
                        • 11
                        • Ph
                        Thanks for the immediate reply momaka. If the varistor serves nothing in powering up my unit when it exploded...why can't it power up my Desktop?does this mean that there is more than the varistor that got messsed up?
                        So I need to remove that red varistor that i just put and check on the other parts?
                        • fzabkar
                          • Mar 2009
                          • 772
                          Make sure the 120V/240V selector switch is in the correct position. If you are in a 240V locale and you have selected the 120V position, then this will cause the varistors to explode.
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            The 300v varistor is still better than nothing.
                            And besides most caps have a voltage surge rating.
                            I.e. they may be ok with a short over voltage of 50% for a couple milliseconds.
                            Check the datasheets
                            • fzabkar
                              • Mar 2009
                              • 772
                              What would happen if one of the capacitors were slow to charge up? If the two capacitors are not perfectly balanced, wouldn't one of them have a higher voltage than the other, and could this be a possible failure scenario for the varistor?
                                master hoarder
                                • May 2008
                                • 12164
                                • Bulgaria
                                Yes, it's possible there are other bad components. I explain below.
                                Most caps have a surge rating of 25%, not 50%. That would make these 200V caps being able to handle up to 250V for a very short period of time. So the 300V varistor still wouldn't do anything useful here.
                                If that is 100 V -rated varistor, then most definitely remove it. Otherwise it will blow up as soon as you plug in the PSU in the wall.
                                Since the original varistor exploded, as you noted, then that means other parts could have been damaged as well.
                                The first things to check would be the fuse, bridge rectifier (black rectangular box with part number "GBU..."), and thermistor (that green, disk-shaped thing next to the bridge rectifier).
                                You will need a multimeter to troubleshoot these (and the rest of the PSU). May we ask how familiar you are with using one? Reason I want to know is so that we can give you troubleshooting instructions accordingly.
                                I think that could happen only if one of the two balancing resistors across each cap went open. But they are usually in the range of 150 KOhms and up, so they are very unlikely to go open circuit due to an overload.
                                • docchan2000
                                  Okidoki
                                  • Dec 2015
                                  • 11
                                  • Ph
                                  I just do some you-tubing and readings in the net.I know not much about this things but I like doing things on my own because of the self fullfilment aside from saving a lot of money. I got to have that multimeter and test those parts you mentioned momaka. Many thanks and more POWER💪
                                  • docchan2000
                                    Okidoki
                                    • Dec 2015
                                    • 11
                                    • Ph
                                    Many thanks to all those who contributed to this thread...budm,fzabkar, Per Hansson and momaka.Greatly appreciated jt.��
                                      master hoarder
                                      • May 2008
                                      • 12164
                                      • Bulgaria
                                      Good. Let us know what you find with the testing.
                                      - The fuse should ideally read 0-1 Ohms across it (depending on how good your multimeter is).
                                      - ^ Same goes for the the thermistor, except anything between 0-10 Ohms is generally acceptable. Make sure there are also no physical cracks or missing pieces in its body, as that might indicate a pending failure.
                                      - Bridge rectifier is basically 4 diodes connected in a special way.
                                      Between the two AC (~) legs, you should get infinite resistance (i.e. open-circuit, or OL on your meter), regardless of how you connect your multimeter probes.
                                      With red (+) multimeter probe on positive leg (+) of bridge rectifier and black (-) multimeter probe on negative leg (-) of bridge rectifier, you should get infinite resistance again. Reversing the probes should give you approximately two diode voltage drops (800 - 1600 mV) on diode test mode on your multimeter.
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        thread moved.
                                        btw last time i saw these fail the customer lost a lcd tv too.
                                        i went over to check things out after i repaired the power supply and tv and found my hunch to be spot on.high neutral.it was loose at the pole.
                                        • chth96
                                          How can I identify varistor which have been blew up?
                                          by chth96
                                          I mistakely pluged 100v japanese retro game console to 220v outlet.
                                          So It seems that glass fuse and varistor have been blew up.
                                          I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                                          Is there any way to identify varistor type in my sega saturn PSU?
                                          Any reply would be appreciated.
                                          EDIT:
                                          It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                                          11-26-2023, 08:52 AM
                                        • Guest
                                          A noob needs help for Apple Macbook Air M1 2020 A2337 - logic board short circuit
                                          by Guest
                                          Hello all!
                                          Recently I've got a broken Macbook Air M1 2020 A2337 of eBay with a broken screen and not turning on issue.
                                          After some tinkering I've found C5201 capacitor to be blown. This is where I hit a wall since I am a total noob in this area and have no idea what else to look for. C5201 is on one line with 3 more capacitors which visually seem ok, but beep on continuity mode and also both sides of all capacitors beep when tested with ground from the board. This to me sounds like a short, but I am not able to find what component is before the capacitors to test it....
                                          09-26-2024, 03:31 AM
                                        • ten-d
                                          Nippon Chemi-con 100uf 100v BP electrolytic cap
                                          by ten-d
                                          Hi all!
                                          I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to...
                                          01-30-2024, 05:18 PM
                                        • iusar
                                          varistor indentify xbox one s
                                          by iusar
                                          i need to identify the burned varistor RV001
                                          line voltage 220Vac
                                          smps model: 1921
                                          code on pcb: PA-1181-18M1
                                          REV:A...
                                          06-13-2023, 03:35 PM
                                        • Doesronnieevenlift
                                          Help a noob! Wson8 Pogo/Needle Adapters to read/Write
                                          by Doesronnieevenlift
                                          I had recently tried to reflash the bios on a dell latittude that has a Wson8 Chip however to no avail.
                                          My question is, Has anyone had much success using the Pogo/Needle adapters to read and write bios without removing the chip from the main board?
                                          I seem to struggling with the solder process wofh my reflow station and currently have 4 machines waiting for a bios mod/reflash.
                                          For context I have just ordered a EZP2019 SPI flash so this is what I would be using alongside the Pogo Adapter.
                                          Apologies if this is the wrong subcategory....
                                          Yesterday, 04:51 AM
