Help a noob! Wson8 Pogo/Needle Adapters to read/Write
  • Doesronnieevenlift
    • Jun 2025
    I had recently tried to reflash the bios on a dell latittude that has a Wson8 Chip however to no avail.
    My question is, Has anyone had much success using the Pogo/Needle adapters to read and write bios without removing the chip from the main board?
    I seem to struggling with the solder process wofh my reflow station and currently have 4 machines waiting for a bios mod/reflash.
    For context I have just ordered a EZP2019 SPI flash so this is what I would be using alongside the Pogo Adapter.
    Apologies if this is the wrong subcategory. I'm a new member to badcaps however have spent a long time reading through the website.
    Thanks in advance!
    • 31635
    if the board has a programming header like some MSI boards then it can work,
    but usually you have to lift the chip because of other parts connected to it that mess with the programming.
      • Jun 2025
      Thankyou for your response. Iv got a donor motherboard so I might have to try and test my solder skills with my reflow station 🤣 Practice makes perfect!
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        I do use pogos for wson8 in some cases. But never to read out or write the whole chip. I just read out a certain small section, automatically modify it and write back, so it takes just seconds. And even in that case, it's kinda unstable.
        So for most cases, soldering is the way to go. It is not hard. Correct temperature and never apply any force on tweezers. Atleast that's what beginners tend to do wrong. It should come off easy.
          • Jun 2025
          Thankyou for your reply!
          I had previously tried to desolder a chip and replace it with a preprogrammed one however to no avail. It was a 11th Gen Dell Latittude, However up-on installing the new chip the machine wouldn't boot. I do have 3 more laptops too attempt however moving forward I'm going to try and modify the current bin file as opposed to replacing the whole chip. Could I ask, When replacing the bios chip with a pre-programmed one, Should I have replaced the EC chip? I'm truing to workout where I went wrong. I did resolve the original chip back however the laptop still wouldn't boot 😑
          Thankyou for taking the time to reply! Your knowledge is highly appreciated.
          • langbaobao
            DIY 3D-Printer WSON8 Pogo Pin Adapter
            by langbaobao
            Hi.
            I'm posting this here in part as a memo to self as well as to describe the procedure I used in case anyone else found it useful. I found a lot of the necessary information to make this work on this forum and I figured I would give something back. If this is not the appropriate place to post this, I don't mind it being deleted but I hope it can help other people.
            I got an admin password locked HP Elitebook 840 G5 recently that I wanted to unlock. I'm a relative newcomer to reprogramming and unlocking firmware. The only previous experience I had was unlocking a BIOS...
            01-08-2024, 05:58 PM
          • TopPop
            Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
            by TopPop
            Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
            I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
            12-14-2025, 09:40 PM
          • ahmedtou
            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
            by ahmedtou
            help me please
            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
            I will share all the details with you, including the disc information.
            Code:
            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
            Current Profile: BD-R
            Disc Information:
            Status: Empty
            State of Last Session: Empty
            Erasable: No
            Free Sectors: 12,219,392
            Free Space: 25,025,314,816 bytes
            Free Time: 2715:27:17 (MM:SS:FF)
            Next
            08-27-2025, 08:49 AM
          • Tesla
            Basic Questions about using XGecu-T76 with pogo-tool to fix motherboards
            by Tesla
            I was wondering if you more experienced technicians could help answer some basic questions I have ... and help me build a reliable work-flow for using my new XGecu-T76 Chip Programmer (running XgPro v13.17). I like being able to leave the chips soldered-in (when possible) and read/write them with pogo-tool.
            As instructed, for more reliable operation with pogo-tool, I have backed the SPI-Clock Frequency down to 16-Mhz (and that seems to be working fine so far for reading/erasing/writing/verify).
            So, let's say I have a MB that soft-bricked itself after a common BIOS-Firmware...
            03-27-2026, 12:59 PM
          • pirati
            by pirati
            10-27-2025, 04:20 PM
