Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Nippon Chemi-con 100uf 100v BP electrolytic cap
  • ten-d
    • Jan 2024
    • 9
    • United States of America
    Hi all!
    I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to the mids and woofers.
    So I pulled out the crossover and found that it has quite the robust crossover. 4 inductors, 4 film capacitors and 1 bipolar electrolytic capacitor. I have attached some photos in case they would be of any help.
    I haven't tested the film caps as I did some research online and read that the film caps that ADS used were very high quality and shouldn't be going bad. The electrolytic on the other hand could be suspect. I pulled it out and tested it with my LCR meter. This is a 100uf 100v bipolar cap and when I tested it on the LCR meter (which I zeroed out prior to testing the cap), it showed these numbers:
    @ 1 kHz = 99.33 uf / 0.03 esr
    @ 10 kHz = 96.1 uf / 0.00 esr
    @ 100 kHz = open line
    @ 100 Hz = 103.68 uf / 0.5 esr
    I tried finding the original specs of this Nippon Chemi-con CE04P capacitor but couldn't find anything on it.
    As I said before, I am still learning and am only just starting to scrape the surface of understanding the theory behind these things, so please take that into consideration when reading this post.
    So I have a few questions:
    1. Why would it show zero esr at 10 kHz and and open line at 100 kHz but showed pretty high esr readings at 1 kHz and at 100 Hz?
    2. I'm guessing that the esr is bad since it's reading 0.5 at the high end - am I correct in thinking this?
    3. What would be a good replacement cap if this is indeed a bad cap?
    Thank you very much! I look forward to learning and to also helping others once I get better!
    Cheers
    • Jul 2011
    • 6079
    I found some of them from an EBay seller I can not tell you if they are genuine or are fake but they are bipolar type of capacitors do not use the normal type capacitors they will not work in this situation
    https://www.ebay.com/itm/153740556084
    • ten-d
      • Jan 2024
      • 9
      Interesting that they are making replacements. I just went over to mouser and checked for a new equivalent but having trouble finding one. I'll keep looking for a bp cap.
      Do you think that the cap I have and tested is bad?
      • redwire
        • Dec 2010
        • 3912
        That capacitor is for the woofer, it can only affect low mids if it goes low value. I would say it is good.
        What make/model ESR meter do you have, it seems to be crapping out at 100kHz - not that a crossover network is a SMPS, totally different things- no need for low ESR at 100kHz here.
        Most important is polarity of the drivers and loudspeakers - you can use a 1.5V battery to bump and watch the cone go out or in and confirm (+) and (-) when jumpered to a driver. Some speakers reverse the mid polarity. Make sure all drivers are alive and the right polarity. There are no L-pads? They can go dirty or open.
        You can check Parts Express or Madisound or Solen for parts.
        If you change over to big film capacitor, they usually end up rattling around inside the box because mounting them is a bear. Not really needed unless you are running big power.
        • ten-d
          • Jan 2024
          • 9
          Thanks for the reply redwire. I appreciate it.
          Ahhh. Okay. I was wondering why it was such a high capacitance. So the 4.7 uf film caps are for the tweeters then? I was trying to find a crossover schematic but there doesn't seem to be one online for my version of the L810's and I'm so not experienced enough to figure this stuff out quite yet.
          I've got a DER EE DE-5000 LCR meter. I have the tools but still am learning how to interpret what these things mean.
          No L-pads on this set. The person I bought them from was the original owner and was not tech savvy so my assumption is that no one has ever been inside those speakers until I did. This is totally a guess though. But I will check the polarity nonetheless!
          Also - prior to reading your reply, I did purchase these. Since the replacement is an axial I was planning on mounting it to the circuit board sideways. But if you think that the cap is okay, I may not end up replacing it. I'll run the replacement through the same tests on my LCR meter just to check as well to compare the two.
            • 31482
            the esr is too low, it may indicate leakage.
            use film caps instead of BIpolars.
            old bipolar caps used in tv's and crossovers can handle more current than the modern ones.
            • ten-d
              • Jan 2024
              • 9
              Thanks stj - I would love to learn this but how would you be able to determine at which frequency is the correct frequency to test the cap's ESR at without being able to look at the data sheet for this particular cap? The esr is all over the place for this cap at different frequencies so how do you know which one is the correct esr? Thank you!
              • spiros.p
                • Dec 2020
                • 89
                • Greece
                The capacitance is not normal for 40+ years cap even new capacitor don t measure like this.It is for low frequency there and the best is to replace with indentical value new cap same or better quality.For the film caps is all ok but if you like to upgrade with new better audio capacitors go on.
                  • 31482
                  the common frequencies to read esr are 10KHz for old stuff - really old i mean, and 100KHz for stuff from the 80's onward.
                  the figure to look at in datasheets is ripple current - the current the cap can charge and discharge.
                  thats what is needed for audio or driving deflection coils in a crt.
                  not that there is any difference - the speaker is still a high frequency coil.
                  • redwire
                    • Dec 2010
                    • 3912
                    Wondering if OP's DER EE DE-5000 LCR meter is working properly? I would see how it reads with some vanilla parts like a polarized 100uF cap.
                    • ten-d
                      • Jan 2024
                      • 9
                      Quick update. I received the new Jantzen BP caps and they had the exact same readings as the ones I took out of the crossovers. So it looks like the original electrolytic caps are still good. I may still replace the old caps since I have new ones of the same specs just to help extend the life of the crossovers.
                      I’ll test my LCR meter with some normal caps too just to make sure it’s reading them accurately.
                      • jojo88
                        LG LED (LCD) TV 50LN5600-UI flashes logo, red LED 3x blink
                        by jojo88
                        This 50 inch LG LED (LCD) TV was given to me not working. Powering it on, the logo flashes once for 1/4 second then black. Front panel red LED blinks 3x (I think... see below) then the LED turns off. TV stays on until I press the Power button again. There is an image on the LCD panel--I press the "Settings" button on the TV and this brings up menus I can see with a flashlight / torch.
                        (The front panel red error code LED blink sequence is a bit confusing to me. The LED is on when the TV is off. I press the Power button and the LED *very briefly* goes off--maybe 1/10 second--then...
                        03-29-2023, 11:20 AM
                      • Adenitz
                        Replace electrolytic cap with bipolar one
                        by Adenitz
                        can I use this cap:
                        https://www.tme.eu/en/details/ues1h4...tors/nichicon/
                        Capacitor: electrolytic; bipolar; THT; 47uF; 50V
                        to replace this capacitor: Electrolytic Radial E 47uF/50V 6.3x11 RM2.5 105°C Jamicon
                        What exactly I can expect to install bipolar electrolytic cap instead a regular one?
                        Thanks.
                        02-02-2022, 07:44 AM
                      • madscientist750
                        Replacing electrolytic caps by solid caps on old motherboards
                        by madscientist750
                        I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                        I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                        I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                        10-19-2025, 06:10 AM
                      • Perry Babin
                        Electrolytic cap endurance
                        by Perry Babin
                        From what I've found, the endurance of a liquid electrolytic cap is determined by the loss of electrolyte. If a cap is rated for 1000 hours. That's typically for a straight run test. How would the life vary if the cap is intermittently heated to its rated temperature (105C). Maybe for an hour at a time then cooled back to 30-40C (just a random number). Would the life still be 1000 hours?
                        Does it make a difference in the life expectancy if the cap is heating from ripple current (internal heating) instead of from the external ambient temperature?
                        Why do polymer capacitors...
                        10-18-2025, 05:21 PM
                      • nheather
                        Help with Faulty Dell U2312
                        by nheather
                        I have two Dell Monitors that I use with my PC, as 2311 and a 2312.
                        The 2312 has developed a fault as follows.
                        It started off with occasionally not being able to power on, after a few attempts it would work and then fail again weeks or days later. Eventually it stopped altogether.
                        I watched videos suggesting the 3.3V regulator on the logic board but it seemed fine, although I did replace the electrolytic capacitors around it - not convinced that was the problem though.
                        But now it will power on every time without fail, look like it is working...
                        02-26-2022, 11:17 AM
