Blown 104 ceramic caps enough to knock out a channel?
  • mikay786
    • Aug 2014
    • 765
    Just looking at this prosound 1600 amp which from initial testing has a fully dead output (2 channel amp) and another that works but no bass.
    Anyhow there's two ceramic caps 104 100v right next to the main filter caps and internal fuses. Was wondering if these have the potential to be the culprit or are they too insignificant?
    I ask as if I remember correctly on the gale sub that I repaired which had the same ceramic caps blown, I remember folk saying it would still work without them.
    Re: Blown 104 ceramic caps enough to knock out a channel?
    Those two fuses would have blown if they are shorted out, but you must be getting the Voltages from the filter caps otherwise none of the channel should be working so the caps are not shorted out.
    • mikay786
      • Aug 2014
      • 765
      They don't look blown, but I'll check them.
      Correction
      One channel is noisy and very very low volume
      Other has loud volume but no bass what so ever
      I'm guessing the ceramic caps are to reduce noise? Decoupling
        • 31050
        ceramics can short, but if they are across the power they will explode or blow a fuse or something.
        • mikay786
          • Aug 2014
          • 765
          I see what you mean, the fuses inside are good but they have been replaced by former owner so probably blew and replaced. Although they are 15a but should be 10a.
          I've got some 104 100v ceramics from last time so will replace and see if that helps.
          There's also a 120ohm 3w resister on the output board that was a bit worse for wear but removed and measured and seems ok. Will replace anyhow
          • mikay786
            • Aug 2014
            • 765
            Can you test main filter caps with a multimeter or that eBay jobby esr meter?
            I've tried before with other filter caps but couldn't get a reading with multimeter. Was thinking it didn't have enough oomph to charge then?
            • mikay786
              • Aug 2014
              • 765
              Got both channels to works without any noise, and the low channel is now at the same volume of the other.
              Still no bass, but ive got a sneaky feeling that might be to do with my input which is a 3.5mm jack from back of pc to full size jack into amp.
              Going to try with a dedicated cd player using the amps xlr inputs.
              • mikay786
                • Aug 2014
                • 765
                Yep going through XLR inputs and working a charm (Phono out from CD player to XLR in on amp), wondering if the full size jack inputs are faulty or just not compatible / playing nicely adapted from PC.
                Cant believe just two tiny 100nf caps was the problem!
                • eccerr0r
                  old X58 triple channel board... memtest86 memory speed?
                  by eccerr0r
                  Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                  Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                  Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                  06-28-2025, 09:06 AM
                • spleenharvester
                  Reverse engineering of 18650 4-channel tester
                  by spleenharvester
                  Hi friends
                  I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                  05-04-2025, 02:43 AM
                • FrozenHaxor
                  Denon AVR-X2000 no audio after blown channel, no bias current.
                  by FrozenHaxor
                  I'm repairing a Denon AVR-X2000 that has blown both FR channel output stage transistors. Upon replacing the transistors (Q416 and Q422) witch a matched pair and replacing both burnt 22Ohm base resistors (R458 and R483) the unit powers up and I was able to set idle current to spec (8mV on test points) across all channels except for the FR channel that had a problem, it tests 0V and I'm unable to adjust that at all. The transistor (Q421) which regulates the bias current tested okay (it sits between the big transistor pair). Also I'm unable to produce any audio from any channel....
                  10-28-2020, 07:10 AM
                • mikey5791
                  Help on car amplifier only one channel works
                  by mikey5791
                  Hi all forum members,
                  Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                  My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                  08-06-2025, 10:36 PM
                • NuclearSpartan
                  Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
                  by NuclearSpartan
                  I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
                  The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
                  I don't see any other visible damage anywhere else on the board....
                  11-14-2024, 02:32 PM
