Denon AVR-X2000 no audio after blown channel, no bias current.
  • FrozenHaxor
    • Jun 2015
    • 260
    • Poland
    I'm repairing a Denon AVR-X2000 that has blown both FR channel output stage transistors. Upon replacing the transistors (Q416 and Q422) witch a matched pair and replacing both burnt 22Ohm base resistors (R458 and R483) the unit powers up and I was able to set idle current to spec (8mV on test points) across all channels except for the FR channel that had a problem, it tests 0V and I'm unable to adjust that at all. The transistor (Q421) which regulates the bias current tested okay (it sits between the big transistor pair). Also I'm unable to produce any audio from any channel. I have tested all main power rails and they check out fine, output transistors are getting their positive and negative ~40V rails as well.
    Has someone came across such issue? I would assume that audio would come out of any other channel except the one that still doesn't fully work. Could something upstream that produces the low level signal be blown? Never came across that. Any hints appreciated, apart from amplifier block, the rest of the unit is pretty much impossible to test due to joined board construction that pretty much make a full box with no access.
    I have uploaded service manual to my private server due to attachment size limit: https://cdn.badcaps-static.com/pdfs/...93f58c610d.pdf
    Thanks!
  • R_J
    • 9594
    Re: Denon AVR-X2000 no audio after blown channel, no bias current.
    If the base resistors were open, I would check all the other resistors and transistors in the drive circuit, also are the output emitter resistors ok?
    Check the voltage at the common point of the output resistors (dc offset) this should be near 0 volts, if it is not it will not allow any of the speaker relays to connect to the speakers, so no audio from any channel.
    • tibimakai
      • Jan 2012
      • 3680
      I'm pretty sure, that there are more components that are bad.
      • FrozenHaxor
        • Jun 2015
        • 260
        • Poland
        Thanks, turns out I missed one emitter resistor pair. Not sure how, must have measured only one pair by mistake. Everything works fine now, bias current is set and regulating properly with temperature. Audio output is good.
        If I didn't know that, I wouldn't be posting
        • R_J
          • 9594
          Glad to here you have it working.
          • gvse
            • Jan 2021
            • 12
            I have a similar no audio problem on the AVR-X2000. But in my case the unit powers up and i get audio on the zone2 speakers (SBR and SBL). It works only for analog audio inputs and FM on zone2. On the main zone all the channels are not working (including test tone). On the hdmi path the video works. But no audio.
            Looking at the service manual the main zone uses the ADSP21487.. however the zone2 doesnt do any digital conversion.. is it possible something is wrong in that path ?
            • falcontech
              Denon Mc6000 channel 1 completely non-functional
              by falcontech
              Hello
              I need your help with a non-functioning channel on this Denon controller. I noticed the problem because, with the mixing software, the channel appears completely off and none of its controls work. At the top of the channel, like the others, there's a selector switch that moves between MIDI and external audio inputs. I also tried connecting an audio source (since it's also a standalone mixer) and I got no input. The flat cable connecting this panel to the sound card is fine. I'm attaching a photo and the service manual. I hope someone can help me resolve the issue. Thanks....
              09-04-2025, 09:03 AM
            • eccerr0r
              old X58 triple channel board... memtest86 memory speed?
              by eccerr0r
              Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
              Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
              Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
              06-28-2025, 09:06 AM
            • re-atari
              Repair Denon AVR-X2600h power amp SBL and SBR channel
              by re-atari
              A few weeks ago I bought a defective Denon AVR-X2600h receiver, wanted to use this one to find and fix a fault in my X2400h. This last part is already successfully done (turned out to be a defective TOP268VG in the X2400h's STBY PSU). So far so good.
              As I like a challenge, I now want to try to fix the X2600h. According to the serial nr. the receiver is built in june 2020. The seller wrote in his ad, that he had bought the receiver in a defective state, and wanted to fix it himself, but could not find the time to do so. The receiver would jump to DC protect mode when switched on...
              08-13-2022, 07:34 AM
            • AudioGuy88
              How to bias a Plinius Odeon 6 channel amplifier
              by AudioGuy88
              I am working on a Plinius Odeon 6 channel amplifier. Not much wrong with it, but I replaced some caps (20 years old) and decided to check the bias current.
              The manual says
              1.
              Code:
              [1] Check the right DC servo is set within its operating window.
              Use VR2 to set TP5 to within –3.0 to +3.0 volts.
              [2] Check the bias current is correct once the amplifier has warmed up, typically 15 minutes.
              Use VR1 to adjust the rail current to 140mA or 52.5mV across any emitter resistor (35mA per
              device).
              I am assuming...
              01-28-2023, 09:30 PM
            • spleenharvester
              Reverse engineering of 18650 4-channel tester
              by spleenharvester
              Hi friends
              I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
              05-04-2025, 02:43 AM
