Can you test a silicone rectifier with a MM?
  • mikay786
    • Aug 2014
    • 765
    Re: Can you test a silicone rectifier with a MM?
      Originally posted by mikay786
      orange red
      yellow black
      Correct, see edited post 79.
      Basically connecting the two secondary windings in SERIES to form center tap winding.
      • mikay786
        • Aug 2014
        • 765
        Alright only one thing to do, power it up without speaker and see if it blow, goggles on and step back!
        • mikay786
          • Aug 2014
          • 765
          And she lives!! Yay
          I think you guys need to start charging for your advice, geniuses. Thank you
          Not a bad sounding sub considering its size, tiny especially compared to that monitor audio one ive got.
            Great work, it will not have the same power output but I am sure it will be good enough.
            So how much is the transformer? And now you learn how we go about to narrow down and find out that it is the transformer that caused the the main fuse to blow not due to MOSFETs or the bridge.
              • 31163
              first time i'v heard of a toroid going short!
                I have seen many.
                • mikay786
                  • Aug 2014
                  • 765
                  I think it's powerful enough as when you crank it full it starts to struggle as to say turn me down a little.
                  Definitely and it makes sense to break things down instead of jumping randomly into the deep end. Break things down into sections and follow a set course where you can starting from the power in then through different sections of the board.
                  I went straight away to mosfets which was as it turns out to be a waste of time. To be honest I didn't really know what a transformer did nor had I encountered a faulty one before but it is a lesson learned.
                  Transformer was about £19
                    You should build a fixture to put the lamp in series with what you are testing, the lamp will light up brightly if there is shorted circuit, it saves me lots of good fuse and power devices.
                    https://www.badcaps.net/forum/showpo...&postcount=112
                    • mikay786
                      • Aug 2014
                      • 765
                      I'll look into it.
                      Just a quick query so I understand the shorted toroid.
                      Transformer is copper wire wrapped around a donut shaped thing. Wires are kept spaced for 1 full wrap. Before second wire wrap a plastic layer is wrapped around insulating the first layer coil. Then 2nd wire wrap and so on.
                      So for a short to appear, one of them internal insulating wraps may have melted allowing 2 layers of coils to make contact?
                        • 31163
                        no, the wire has an insulating coating on it, so it's just wrapped tightly around the ring.
                        if it gets too hot or there is a scratch or anything on the coating it can arc across.
                        why not take a look at your old one?
                        • mikay786
                          • Aug 2014
                          • 765
                          Ah that makes sense, I peeled back the old one down to the copper. Tried a continuity test and didn't beep but didn't clue on it was coated
                          Do they output in AC, just smaller values. And then a transistor can convert that to DC.
                            TOROID transformer is just another form factor of transformer. It is transformer.
                            It can be step-up, step-down or 1:1, etc.
                            http://www.amgistoroids.com/toroidal...lications.html
                            https://toroid.com/
                            You need rectifier o converter AC to DC.
                            • chth96
                              Is it possible to test small ceramic disc capacitor with analogue meter?
                              by chth96
                              I read EBOOK of Testing Electronic Component and found that
                              "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                              Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                              It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                              Is it really possible to test small ceramic disc capacitor with analogue...
                              03-09-2024, 10:03 PM
                            • tvguy12012012120
                              by tvguy12012012120
                              02-07-2025, 05:13 PM
                            • chth96
                              How Can I test PWM DM0365R?
                              by chth96
                              Hello
                              I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                              So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                              I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                              I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                              06-18-2025, 04:14 PM
                            • howardc64
                              QN75QN85BAFXZA no backlight
                              by howardc64
                              2+ year old TV with many (720? 65" version has 720) mini LED dimming zones. TV boots, has sound, panel picture can be seen with flashlight. No backlight. No TV model sticker on rear panel (Maybe Samsung service removed it, read below). Found the model # through the PSU and zoned LED driver board numbers.
                              PSU has a click near LED output circuit at 1 second interval, sounded like the 4x barrier rectifier area. Protective pastic liner under PSU shows heat signature on the Schottky Barrier Rectifier in this circuit. Found a shorted diode (2 diode per rectifier, failed rectifier labled...
                              07-03-2025, 05:08 PM
                            • bauto601
                              KDM 480W PSU upgrade succes! (opinions?)
                              by bauto601
                              Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                              A "nice" YoungYear unit? - Badcaps
                              The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                              12-26-2023, 03:05 PM
