Should a transformer live/neutral pins have continuity?
  • mikay786
    • Aug 2014
    • 765
    Just a quick question.
    Was wondering why the two pins on this transformer have continuity between them for live and ground. Is this normal? If not why would it be doing so?
    • 31054
    Re: Should a transformer live/neutral pins have continuity?
    it's not "ground", it's negative.
    and it's normal because it's just a long coil of wire inside.
    • mikay786
      • Aug 2014
      • 765
      Thanks I thought I may have shorted it out somehow.
      bought a Sony mini hifi thing today, it all powers up but no sound from speakers. Just trying to figure out what's up with it.
        • 31054
        sound from headfones / any audio hum?
        • mikay786
          • Aug 2014
          • 765
          No hum or hiss, not tried headphones
          • mikay786
            • Aug 2014
            • 765
            sony mhc-s7av Nice little 4 stack system. Got some goodmans q70 speakers last week which i was hoping to pair with
              • 31054
              try with phones incase it's the switch in the socket.
              then check all the soldering on sockets,pots etc and anything stuck on a heatsink.
              • SteveNielsen
                Retired Tech
                • 2327
                Phones will tell you if the preamps and EQ circuits are working in case the problem is in the power amp only. If there's AC hum in the phones could also indicate bad filter caps in the power supply.
                  Service manual:
                  http://elektrotanya.com/sony_mhc-sv7.../download.html
                  • mikay786
                    • Aug 2014
                    • 765
                    Just getting a hum in headphones no music. When I push in half way hum in right earbud and when pushed in all way moves over to left ear.
                    I think ive identified a bad cap also
                    Rubycon 100v 100uf 85c YK Series - Theres a pair of them side by side located as per pic with red box
                    Filter caps are the bigs expensive one up front?
                    Could it be just these rubycon bulgers?
                      • 31054
                      if those are inline with the speaker outputs it could mean there was a bad speaker connected.
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        From the pic I don't see any bulging on the 100uf Rubycons but that doesn't mean they are good or bad. Yes the power supply filters are the big caps at the top of the 2nd pic. I'd test them and the rectifiers, resistors and fuses in the power supply section where the big caps are.
                        • mikay786
                          • Aug 2014
                          • 765
                          They are close to the terminals
                          behind the heatsink
                          Would some Panasonic FC series be suitable replacements?
                          • mikay786
                            • Aug 2014
                            • 765
                            Its definitely bulging the 2nd one and has got a little crust on it. Ill try to get a better pic
                            • mikay786
                              • Aug 2014
                              • 765
                              Bulging right in the middle of the K with a small deposit there too on the cap with the red line
                                You have three speaker relays, do you hear any one of them click on?
                                Those two caps are for the +/-VCC filter for the preamp of the STK audio IC.
                                • mikay786
                                  • Aug 2014
                                  • 765
                                  When you turn it on it clicks once I think
                                    Did you download the service manuals?
                                    • mikay786
                                      • Aug 2014
                                      • 765
                                      Have done now that ive installed chrome.
                                      Removed main board and looks like someones already been in here and made a bit of a mess.
                                      That relay has been wrapped in black tape for some reason plus a bit of a bodge on solder side.
                                        • 31054
                                        someone probably opened the relay to clean the contacts and broke the clips on the shell.
                                        those coils dont look so good either!
                                        • cathoderay
                                          Miele cat and dog hs05 vacuum power supply
                                          by cathoderay
                                          Bear with me as this is getting interesting.
                                          Not a lot as the saying goes but it may help someone to decide on throwing it in the landfill or rescuing it.
                                          Symptom no go.
                                          WARNING THIS STUFF CAN BE FATAL IF WORKED ON LIVE. PLEASE DO NOT WORK ON THIS LIVE UNLESS YOU KNOW WHAT YOU ARE DOING
                                          YOU NEED A GOOD VARIAC AND AN ISOLATING TRANSFORMER AND SKILLS. IF YOU DO NOT HAVE DONT TOUCH.
                                          A LOT OF THIS CAN BE FAULT TRACED USING CONTINUITY METER ONLY.USE A 12V CAR BATTERY FOR THE MOTOR TEST WITH AN IN LINE FUSE. 10A.
                                          I'LL RUN THROUGH THE CONTROL BOARD TEST...
                                          05-05-2022, 04:11 PM
                                        • Tarot Superstars
                                          trying to fix a 6V 0.5A T1 (Transformer) AD050120T2 power supply
                                          by Tarot Superstars
                                          Hi. I am trying to fix a 6V 5A power supply that would was used a lot.
                                          I want to fix it partly for learning, and part because I don't want to buy a new one.
                                          It has distinctive smell of burning but not seen obvious burned components yet. I'm not sure where the fuse is.
                                          I tested the only slightly bulged capactitor (out of circuit) and it measured normal capacitance and ESR.
                                          Everything else was tested in circuit with a multimeter.
                                          In circuit tests
                                          I tested the large diodes underside and they seem fine.
                                          I tested...
                                          08-14-2023, 12:45 PM
                                        • mikey5791
                                          Is it possible for transformer substitution?
                                          by mikey5791
                                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                          My questions are
                                          1. How do i test to see if the transformer is in good working condition?
                                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                          Hope you guys understand what i was asking. My intention is...
                                          11-03-2022, 02:11 AM
                                        • pandrew
                                          Thinkpad T490 doesn't detect NVME
                                          by pandrew
                                          I have a Thinkpad T490 (NM-B901 Rev 1.0) that cannot detect an NVME M.2 SSD,
                                          but it works fine with a SATA M.2 SSD.
                                          When connecting an NVME M.2 SSD I get while booting:
                                          "2101: Detection error on HDD0 (Main HDD)"
                                          I can continue and boot a live linux distro from a USB stick, but it doesn't show up in lspci,
                                          and I don't notice any relevant error messages in dmesg.
                                          I have tried two different M.2 NVME SSDs (both working fine on a different machine),
                                          and the behavior is the same.
                                          I am pretty sure that all the important...
                                          11-13-2023, 03:04 PM
                                        • spleenharvester
                                          Brother DCP-L2500D - completely dead
                                          by spleenharvester
                                          Hi everyone
                                          I have quite a bit of experience with low voltage circuits but basically none with high voltage circuits outside of recapping. So if anyone could point me in the right direction I would appreciate it very much!
                                          This printer, history unknown, has no signs of life when plugged into 240VAC. It has the LT2988-001 board common to many Brother HL-2XXX series printers. The only physical abnormality observed is a green tint to the positive leg on the main 400V filter capacitor. This model is prone to shorts across the four Schottky diodes but all are testing OK by...
                                          03-01-2025, 08:58 AM
