APC UPS troubleshooting
  • gitco
    • Feb 2008
    I have a problem with an APC Back-UP 500 LS UPS.
    The ups started by beeping with the "replace battery" led on. The beeping and lit led were not constant.
    I replaced the battery with a new one but the beeping did not stop.
    Then I installed the Powerchute software to silence the alarm but instead I discovered that the reason for the beeping was the UPS sometimes thinks the battery is disconnected. The software keeps showing "battery disconnected" and "battery connected" messages in a cyclic way.
    When the UPS detects the battery, the monitor shows battery charge is OK.
    Does anybody have a similar problem and know how to solve or any hints where to look?
    Thanks in advance.
  • starfury1
    • May 2006
    • 1256
    Re: APC UPS troubleshooting
    Hi welcome
    No direct answer for you, but if it is an electronics fault and your got some electronics training (in the mean time too)
    You may want to have a squizz through this thread UPS and inverter questions
    You may get an answer from someone here familiar with these.
    I don't know much about them.
    With a bit of luck it might be a common type thing that happens.
    HTH
    Cheers
    You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
    • andrew77
      • Jan 2008
      • 81
      Welcome gitco,
      You've come to a good place for asking people about all things electric.
      I'm no expert, but I've been playing with these devices for the past month and I've run across lots of information on them.
      It sounds to me like the charger isn't charging the battery all the time. If you have a volt meter you could check the volts on the battery. Usually they have 12 volt batteries, sometimes like in my case, there are two 12 volt batteries connected in series. You should see 13 volts if it's a 12 volt battery and it's been charging.
      Looking up your unit on google, I see yours uses the same batteries as mine, but just a single battery.
      If you see less than 12.5 volts, it's probably not charging completely. If it's a whole lot lower than that, the charger is probably not working at all. I'm not so sure I could walk you through what you'd have to fix if the charger is totally dead, you'll have to wait for the people that really know how those things work to be online.
      Sorry couldn't help you more, but at least it's a start.
      Andrew
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        did you get a new fresh battery?
        the replace battery detection depends on the fact that a worn out battery will draw little current at float.
        it monitors this along with watching voltage under a test load.
        i load test ups batts with a car battery load tester to be sure.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          You also may simply have a bad connection, bad wire, or loose wire in a connector.
          Mann-Made Global Warming.
          - Dr Seuss
          • mkdj
            ASUS X571 no power : battery issue?
            by mkdj
            Mark and model: ASUS X571
            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
            Tests already made:
            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
            - I have removed...
            07-14-2025, 09:16 AM
          • techfreak9356
            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
            by techfreak9356
            I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
            09-14-2023, 11:10 PM
            NVDC charger configuration...
            11-05-2024, 03:28 PM
          • ferah831208
            Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
            by ferah831208
            Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
            03-18-2025, 01:18 AM
          • huzo
            HP ELITE X2 1013 G3 weird battery issue
            by huzo
            Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
            01-31-2025, 12:09 AM
