stop electricity meter method
Re: stop electricity meter method
This 2- LED infrared light captured hours of work we want to do the work I wanted to work on the deviceComment
search for all info on IEC 62056
like so.
https://duckduckgo.com/?q=IEC62056&k...t-wt&kv=1&kh=1Comment
open this counter open a control circuit made as to close off Biliran during the day as at nightComment
There are counter to the laser light in the LED holding syac the stroke rate dropped 2 units bilirmiyim counterComment
When the electric meter running, it will not work against yapılazm of a circuit that will interfere with the operation of this circuit runs counter counterComment
When an electrical engineer put in a place close to the rev counter has made a rev counter does not work when trying to counter this has been the opportunity to cut our electrical circuit in such a transaxleComment
The AC adapter is used in the video above volts AC or DC volts but because timer stopsComment
That box looks like some kind of RF generator.Never stop learning
https://www.youtube.com/watch?v=aDFUNUYECiYrf modülatörine benzeyen tip bişi yapabilirmiyiz çünkü işimize çok yarayacak ben bunu ac adaptöre benzetin kablo ucu 2 adet var sanki manyetik alanla sinyali öldürüyor bunu yapabilirmiyizComment
=https://www.youtube.com/watch?v=aDFUNUYECiYrf modülatörine benzeyen tip bişi yapabilirmiyiz çünkü işimize çok yarayacak ben bunu ac adaptöre benzetin kablo ucu 2 adet var sanki manyetik alanla sinyali öldürüyor bunu yapabilirmiyiz
it help us a lot because we can make something that looked like what the modulator to simulate the AC adapter if you have 2 pieces of the end of the cable that is killing the signal magnetic field can we doComment
It would be very better if you make this circuit I have only used the google translation sometimes missing wordComment
by chth96I read EBOOK of Testing Electronic Component and found that
"In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
Is it really possible to test small ceramic disc capacitor with analogue...-
Channel: General Capacitor Questions & Issues
by x_orange90_xI don't know if anyone here has experience with Japanese slot (pachislo) machines, but I sure hope so. I bought this machine last week in semi-working order. It would play and the reels would spin, but the stop buttons would not stop them at all. I found that the high-frequency filtering tantalum capacitor was bad on the reel stop board, along with the fuse being blown. I replaced the fuse and removed the capacitor. I haven't replaced the cap yet because I didn't have one on hand, but it's not necessary for the operation of the machine.
The issue now is the Stop buttons are intermittently... -
by sam_sam_samI have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery... -
by jorpecHi
I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
I wonder how i can accomplish this so the meter would be precise at any temperature ?
Thnaks -
by howardc64I've done a few of these. Using Samsung Service Manul method always result in some broken bits and the snap lock metal wire always gets bent and not reinstall as nice as original. After reinstall often have some pops and clicks. This is the best method I found so far. Pull the wire out instead
https://youtu.be/paYZAc1rcWs?si=GHdTOv5ySIJgjZOC&t=82
Here is a pic of how the hook on the wire locks
Stil ended up with a couple of small broken bits on the bottom haha. But the wire stayed perfectly straight and seems easier/less forceful. Fishing...10-12-2025, 07:52 PM - Loading...
