Sayce friends here, this is very expensive electricity from outside or light herkang a frequency counter slowing stop state laws Does such a circuit made of BiliranThis is the electric meter
stop electricity meter method
Tags: None
Re: stop electricity meter method
Do not have to wonder if such a circuit given gift of judgment has to slow down or stop the timer technique -
As I think the counter in front of the counter circuit in the logistics of putting this circuit should stop or slow down the counter or frequency when a high light that wonderComment
it's not a counter.
it's a microcontroller that monitors the current flowing through the meter and then display's it.
if you want to mess it up without opening the case then all i can think of is using a strong radio transmitter against the case.Comment
attached house counter that shows how many kvatt oil counter this counter month we HAVE USED TV refrigerator washing machine 150TL will stop burning less fuel or electricity How we do these devices that we run counteComment
What we need to do to stop it for this device do you have anyThis counter circuitAttached Filesif you find these attachements useful please consider making a small donation to the site
The purpose of modifying this meter so you can use lots of power but pay less money to the Electric company?
http://urunler.makel.com.tr/index.ph...-sayaclar.htmlLast edited by budm; 06-24-2015, 08:51 AM.Never stop learning
Excuse me but what's the point here? To get free electric power? I am sure there are laws against that in Turkey.Comment
It sounds like it to me, trying to pay less to the electric company.Never stop learning
"it's fair, they rob us - so why not rob them!" LOL, why not just remove it then and tell them you want free electricity, free food, free housing, free cars, free computers, free TV, etc.?Never stop learning
well it *was* free in Libya.
btw.
http://www.euronews.com/2015/06/23/a...ns-of-arrests/
everybody is getting sick of these corporate terrorists exploiting them.Comment
Yeah, the Russian corporate terrorist.Never stop learning
We know how to reduce the speed of the electric meter you burn fuel to make such a circuit 30kwatt to 100kwatt bilirmiyimComment
There are two LEDs here one day and one night in a schedule to stop sending these LEDs signal bilirmiyimComment
so you want to lock it into "night tariff" ?
you would need to use an ultrasonic probe to break the clock crystal during the night.
but to do that you would need the cover off.
or you may be able to reprogram it using the infrared interface on the front - if it is badly designed!Comment
by chth96I read EBOOK of Testing Electronic Component and found that
Is it really possible to test small ceramic disc capacitor with analogue...-
by x_orange90_xI don't know if anyone here has experience with Japanese slot (pachislo) machines, but I sure hope so. I bought this machine last week in semi-working order. It would play and the reels would spin, but the stop buttons would not stop them at all. I found that the high-frequency filtering tantalum capacitor was bad on the reel stop board, along with the fuse being blown. I replaced the fuse and removed the capacitor. I haven't replaced the cap yet because I didn't have one on hand, but it's not necessary for the operation of the machine.
The issue now is the Stop buttons are intermittently... -
by sam_sam_samI have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery... -
by jorpecHi
Thnaks -
by howardc64I've done a few of these. Using Samsung Service Manul method always result in some broken bits and the snap lock metal wire always gets bent and not reinstall as nice as original. After reinstall often have some pops and clicks. This is the best method I found so far. Pull the wire out instead
https://youtu.be/paYZAc1rcWs?si=GHdTOv5ySIJgjZOC&t=82
Here is a pic of how the hook on the wire locks
Stil ended up with a couple of small broken bits on the bottom haha. But the wire stayed perfectly straight and seems easier/less forceful. Fishing...10-12-2025, 07:52 PM - Loading...
