This appears to be working and came out of a Medion PC with an MD5000 mobo.
The T.C states it is thermally controlled - haha!
I have changed the PSU in this box and intend to sell this one
as a Medion spare to any buyers.
I use two PSU testers for go/no go.
The most recent has the LCD readout. Whereas this PSU reports all
ok with the first tester, the second, beeps but reports all the voltages
as being present.
Rail O/P as found on PSU label
+12.0V : 13.0 A max.
+ 5.0V : 25.0 A max.
+ 3.3V : 14.0 A max.
- 5.0V : 0.5 A max.
-12.0V : 0.5 A max.
+ 5.0V SB : 1.5 A max.
As the ATX specification details
+12.0V : +/- 5 % readings between 11.40 to 12.6
+ 5.0V : +/- 5 % readings between 4.75 to 5.25
+ 3.3V : +/- 5 % readings between 4.75 to 5.25
- 5.0V : +/- 10 % readings between 4.5 to 5.5
-12.0V : +/- 10 % readings between 10.8 to 13.2
+ 5.0V SB : +/- 5 % readings between 4.75 to 5.25
Tester 2 readouts;
+12.0V : 11.7 V ok
+ 5.0V : 5.3 V out of regulation
+ 3.3V : 3.3 V ok
- 5.0V : Unknown
-12.0V : 11.6 V ok
+ 5.0V SB : 5.2 V ok
PG : 240 mS
Seems the +5V rail at 5.3 is out of regulation and the tester beeps.
I opened up the PSU and find in the O/P filter
1 of Black 1650 uF 16 V Fuhjyyu TNR 105 deg C - H 25.4 mm x Dia 10 mm is +12V rail (yel),
2 of Blue/Purple 1000 uF 10 V Fuhjyyu TNR 105 deg C - H 20.0 mm x Dia 10 mm is +5V rail (red) ,
1 of Black 220 uF 10 V Fuhjyyu TNR 105 deg C - H 10.0 mm x Dia 5.0 mm is +3.3V rail (ora), C38
1 of Black 220 uF 16 V Fuhjyyu TNR 105 deg C - H 10.0 mm x Dia 7.5 mm is -12V rail (blu), c34
1 of Black 220 uF 16 V Fuhjyyu TNR 105 deg C - H 10.0 mm x Dia 7.5 mm is -5V rail (whi),
2 of Black 470 uF 16 V Fuhjyyu TNR 105 deg C - H 15.0 mm x Dia 7.5 mm is +5VSB rail (vio), c32 and?
These are all bad caps.
Note the can for +3.3V and current O/P - must be a mistake surely?
Bad quality control at production?
Seems to me should be 6.3V, 1800 uF or so to meet amps O/P at 14.0A relative to PSU O/P claims, not as it is 220uF 10V?
Would this be indicative of bad regulation reading on +5V rail?
Next, tested the ESR and establish if any caps s/c to gnd
1 of Black 1650 uF 16 V Fuhjyyu TNR 105 deg C - H 25.4 mm x Dia 10 mm is +12V rail (yel), ESR 0.06, goes high Z
2 of Blue/Purple 1000 uF 10 V Fuhjyyu TNR 105 deg C - H 20.0 mm x Dia 10 mm is +5V rail (red), ESR 0.05, goes high Z
1 of Black 220 uF 10 V Fuhjyyu TNR 105 deg C - H 10.0 mm x Dia 5.0 mm is +3.3V rail (ora), C38, ESR 0.28, stays s/c
1 of Black 220 uF 16 V Fuhjyyu TNR 105 deg C - H 10.0 mm x Dia 7.5 mm is -12V rail (blu), c34, ESR 0.22, goes high Z
1 of Black 220 uF 16 V Fuhjyyu TNR 105 deg C - H 10.0 mm x Dia 7.5 mm is -5V rail (whi), ESR 0.26, goes high Z
2 of Black 470 uF 16 V Fuhjyyu TNR 105 deg C - H 15.0 mm x Dia 7.5 mm is +5VSB rail (vio), c32 and?, ESR 013-0.15, stays s/c
Am I missing something here?
Any insight, advice and help appreaciated
as being present.
- 5.0V : 0.5 A max.
-12.0V : 0.5 A max.
Tester 2 readouts;
+12.0V : 11.7 V ok
+ 3.3V : 3.3 V ok
- 5.0V : Unknown
-12.0V : 11.6 V ok
PG : 240 mS
