DALI SUB E-12F class D, fluctuating power rail
  • madan1
    • Nov 2016
    • 726
    • Bulgaria
    Good day everyone.
    I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
    The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
    The normal value of the positive and negative power rails is +/- 43V.
    The positive rail stays stable at +43V (+/- few volts when the bass kicks), but the negative rail goes down to -70 -80V on heavy bass and that triggers the protection. With no sound output both rails stay stable. The filter caps on that rails are 1000uF 63V. Out of the board they measure ~970/~950uF with .0 ESR. Switched the caps between the rails and still the same behavior.
    The rectifier diodes and the amp mosfets were tested out of the board with a component tester and they seem to be fine and with identical values.
    Any ideas what might be causing the negative rail to go down? If there was an excess load I would expect it to go up, close to reference, but can't figure out where that extra negative power is coming from.
    Unfortunately I could not find schematics. Also, the amp seems to be using discrete class D amp circuit (no specialized class D driver IC like IRSxxxx, ICE.. or similar is used), one sound output and common ground for speaker and board. Also there is something that I haven't seen in other class D amps - there is a significant capacitance (~190uF) on the output - 4 electrolytes (68uf @ 160v) after the inductor. They are installed in two parallel series. Each couple is connected on the positive side and negative sides are connected to the amp output and ground (see attached doodle).
    Click image for larger version  Name:	dali doodle.jpg Views:	0 Size:	21.5 KB ID:	3745647
    p.s. adding a couple of photos for visual aid
ID:	3745672 Click image for larger version
  • madan1
    • Nov 2016
    • 726
    • Bulgaria
    Right, so after I started removing components, I found a broken transistor (q212 - ksp92), which I guess is part of the driver group. After replacing it, now I have a well working sub amp.
    Still, I'm confused how tf the negative rail was getting that low and why the amp was producing sound at all. Yes, indeed the waveform (at least according to my cheap scope kit) had offset to the positive side, but yet a waveform good enough to produce sound.
    Most likely the damage to the transistor was caused by me, when I was removing the black goo years ago.. and all that time it has been "working" like that as a part of my living room audio system.
    Looking for dali schematics turned out to be dead end, so I'll be grateful if anyone can share schematics for a similar class D amp (discrete mosfet driver circuit with lots of capacitance on the filter side).
    • Nagy Daniel
      Lowest possible resistance on laptop motherboard rail - Guide Table request
      by Nagy Daniel
      Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
      I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
      I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
      So, I generated a table with AI so I can...
      03-04-2025, 08:24 AM
    • Victor Moreira Silva
      Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
      by Victor Moreira Silva
      I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
      Well, my decice specs are the following:
      Model: Acer Nitro 5 AN517-54-55T5
      CPU: Intel Core i5-11400H
      GPU: NVIDIA GeForce GTX 1650
      Motherboard: GH51G LA-L181P Rev:1c
      The symptom:
      When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
      05-26-2025, 10:49 AM
    • lefetylorant
      Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
      by lefetylorant
      Hello Everyone,
      Long story short, I got this unit for very cheap.
      I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
      I've performed some measurements:
      - 20V rail perfectly...
      09-14-2023, 05:05 AM
    • Cemal Odabasioglu
      MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
      by Cemal Odabasioglu
      I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
      Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
      Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
      Observations...
      01-14-2025, 03:54 PM
    • bimole
      Weird behavior on 3.3V rail of a CORSAIR CX600
      by bimole
      A colleague gave me an apparently ill CORSAIR CX600.
      He told me that he heard a banging noise, and smelt the magic smoke.
      After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
      I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
      It's another story on the 3.3V rail...
      I have some devices to test deeply PSUs (scope, AC source, electronic load)...
      02-13-2025, 04:49 AM
