Crs-atx 250 T.c (250w)
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    This appears to be working and came out of a Medion PC with an MD5000 mobo.
    The T.C states it is thermally controlled - haha!
    I have changed the PSU in this box and intend to sell this one
    as a Medion spare to any buyers.
    I use two PSU testers for go/no go.
    The most recent has the LCD readout. Whereas this PSU reports all
    ok with the first tester, the second, beeps but reports all the voltages
    as being present.
    Rail O/P as found on PSU label
    +12.0V : 13.0 A max.
    + 5.0V : 25.0 A max.
    + 3.3V : 14.0 A max.
    - 5.0V : 0.5 A max.
    -12.0V : 0.5 A max.
    + 5.0V SB : 1.5 A max.
    As the ATX specification details
    +12.0V : +/- 5 % readings between 11.40 to 12.6
    + 5.0V : +/- 5 % readings between 4.75 to 5.25
    + 3.3V : +/- 5 % readings between 4.75 to 5.25
    - 5.0V : +/- 10 % readings between 4.5 to 5.5
    -12.0V : +/- 10 % readings between 10.8 to 13.2
    + 5.0V SB : +/- 5 % readings between 4.75 to 5.25
    Tester 2 readouts;
    +12.0V : 11.7 V ok
    + 5.0V : 5.3 V out of regulation
    + 3.3V : 3.3 V ok
    - 5.0V : Unknown
    -12.0V : 11.6 V ok
    + 5.0V SB : 5.2 V ok
    PG : 240 mS
    Seems the +5V rail at 5.3 is out of regulation and the tester beeps.
    I opened up the PSU and find in the O/P filter
    1 of Black 1650 uF 16 V Fuhjyyu TNR 105 deg C - H 25.4 mm x Dia 10 mm is +12V rail (yel),
    2 of Blue/Purple 1000 uF 10 V Fuhjyyu TNR 105 deg C - H 20.0 mm x Dia 10 mm is +5V rail (red) ,
    1 of Black 220 uF 10 V Fuhjyyu TNR 105 deg C - H 10.0 mm x Dia 5.0 mm is +3.3V rail (ora), C38
    1 of Black 220 uF 16 V Fuhjyyu TNR 105 deg C - H 10.0 mm x Dia 7.5 mm is -12V rail (blu), c34
    1 of Black 220 uF 16 V Fuhjyyu TNR 105 deg C - H 10.0 mm x Dia 7.5 mm is -5V rail (whi),
    2 of Black 470 uF 16 V Fuhjyyu TNR 105 deg C - H 15.0 mm x Dia 7.5 mm is +5VSB rail (vio), c32 and?
    These are all bad caps.
    Note the can for +3.3V and current O/P - must be a mistake surely?
    Bad quality control at production?
    Seems to me should be 6.3V, 1800 uF or so to meet amps O/P at 14.0A relative to PSU O/P claims, not as it is 220uF 10V?
    Would this be indicative of bad regulation reading on +5V rail?
    Next, tested the ESR and establish if any caps s/c to gnd
    1 of Black 1650 uF 16 V Fuhjyyu TNR 105 deg C - H 25.4 mm x Dia 10 mm is +12V rail (yel), ESR 0.06, goes high Z
    2 of Blue/Purple 1000 uF 10 V Fuhjyyu TNR 105 deg C - H 20.0 mm x Dia 10 mm is +5V rail (red), ESR 0.05, goes high Z
    1 of Black 220 uF 10 V Fuhjyyu TNR 105 deg C - H 10.0 mm x Dia 5.0 mm is +3.3V rail (ora), C38, ESR 0.28, stays s/c
    1 of Black 220 uF 16 V Fuhjyyu TNR 105 deg C - H 10.0 mm x Dia 7.5 mm is -12V rail (blu), c34, ESR 0.22, goes high Z
    1 of Black 220 uF 16 V Fuhjyyu TNR 105 deg C - H 10.0 mm x Dia 7.5 mm is -5V rail (whi), ESR 0.26, goes high Z
    2 of Black 470 uF 16 V Fuhjyyu TNR 105 deg C - H 15.0 mm x Dia 7.5 mm is +5VSB rail (vio), c32 and?, ESR 013-0.15, stays s/c
    Am I missing something here?
    Any insight, advice and help appreaciated
  • yanz
    • Nov 2004
    • 910
    Re: Crs-atx 250 T.c (250w)
    You sure you check them correctly? 220uF of capacitance for 3.3v is a joke. At least there should be 1000uF one(s) there at the pi filter...
    Would like to see the pics if you have some...
    • Super Nade
      • Jun 2006
      • 294
      I think he means 2200uF not 220.
      Q6700 @ 3.6 GHz
      Zippy GSM-6600P
      Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
      Abit IP35Pro
      ATi HD4870
      • Sparky
        High voltage
        • Jan 2007
        • 234
        Originally posted by JEWilson
        Fuhjyyu [...]
        Fuhjyyu [...]
        Fuhjyyu [...]
        Fuhjyyu [...]
        Fuhjyyu [...]
        • JEWilson
          • Sep 2007
          • 369
          Seriously guys....
          220uF 10v on the 3.3V rail!
          Sorry, I do have a hi-res pic to prove it and
          I have repaced it with a salvaged but in vgc Panasonic FL 6.3V 1800uF
          Problem with +5V rail regulation is still present!
          BTW regulation for 3.3v rail should read;
          + 3.3V : +/- 5 % readings between 3.135 to 3.465
          Must be a short somewhere on 3.3V rail as well as short on the +5VSB
          as these reading remain the same even after replacing the cap above.
          Any suggestions?
          • JEWilson
            • Sep 2007
            • 369
            It appears severach has made a point, these go/no-go testers
            do not outline PSU problems when Power Good shows less than 270ms.
            per https://www.badcaps.net/forum/showthread.php?t=4461
            As I did not power up the PC and mobo that came with this PSU
            in its original configuration (as was), I find it unlikley, it would have had enough
            current delivery given the problem cap, to power the mobo effectively.
            Of course, the genesis of the PG and 5V rail problem may have been
            as a result of this as may be indicative of the s/c's.
            Perhaps that is why I acquired this lot! I'll need to find this short.
            • JEWilson
              • Sep 2007
              • 369
              I tried putting a HDD on this PSU as a load.
              So far as the go/no-go tester formerly beeped with no load
              and I surmised the +5V rail out of regulation caused this,
              with one and up to three HDDs as load removes the beep alarm
              but the +5V rail remains at 5.3V.
              Seems I was premature stating a s/c exists, my mmeter was
              set on continuity and gave me the incorrect indication - sorry..
              So..
              Am I looking at a duty cycle issue with this PSU so far as it
              requires a load to behave correctly? Furthermore, this PSU
              probably has no o/v protection being as it is very cheap - could
              be a red herring...
              I need a scope - that would help
              • Big Pope
                Approved Vendor
                • Dec 2005
                • 426
                Originally posted by Sparky
                Fuhjyyu now changed with another brand name called "Asia'X", be care any PSUs with "Asia'X" caps.
                My SAMXON Capacitors Database HERE!!
                X-CON is a new brand for SAMXON's Polymer Capacitors.
                • gonzo0815
                  • Feb 2006
                  • 1600
                  Most PSU`s need a minimum load for good regulation. Cheap ones may be burn if powered up w/o load.
                  This is normal behavior, expensive PSU`s circumvent this problem by providing a minimum load via a few power resistors.
                  I think 5.3v is not that big issue, i would try it out with a real load. It should be safe to doe this, at least considering the 5.3v o/p.
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    sounds more like this thing deserves some bullet holes more than new caps.
                    pics?
                    might save you the time of fixing something worthless or even dangerous.
                    crs=cant run shit?
                    • starfury1
                      • May 2006
                      • 1256
                      Does that mean KC8 to use the "ultimate fix it good tool"
                      Guaranteed to "never" work again
                      • JEWilson
                        • Sep 2007
                        • 369
                        Hi
                        So far as I expressed doubts with the +5V rail reading on this
                        PSU - and forum members expressed sentiments of do not pass
                        go - go staight oto PSu hell! I tried the same HDD load as with
                        https://www.badcaps.net/forum/showpo...57&postcount=5
                        The voltage in this CRS PSU has come down to 5.2V at least,
                        that is, on the LCD readout of the go/no-go tester. But
                        PG remains low at 250ms.
                        I have seen comment expressed PG below 270ms is a problem
                        that requires component level diagnosis.
                        Would this be the view endorsed by forum members?
                        I acknowledge the sentiments of forum members in the
                        specific matter of this PSU, very bad as it is but am looking to
                        sound out the observations of members re - fast and/or
                        timing issues found in ATX PSU.
                        • Nagy Daniel
                          Lowest possible resistance on laptop motherboard rail - Guide Table request
                          by Nagy Daniel
                          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                          So, I generated a table with AI so I can...
                          03-04-2025, 08:24 AM
                        • Victor Moreira Silva
                          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                          by Victor Moreira Silva
                          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                          Well, my decice specs are the following:
                          Model: Acer Nitro 5 AN517-54-55T5
                          CPU: Intel Core i5-11400H
                          GPU: NVIDIA GeForce GTX 1650
                          Motherboard: GH51G LA-L181P Rev:1c
                          The symptom:
                          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                          05-26-2025, 10:49 AM
                        • lefetylorant
                          Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
                          by lefetylorant
                          Hello Everyone,
                          Long story short, I got this unit for very cheap.
                          I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
                          I've performed some measurements:
                          - 20V rail perfectly...
                          09-14-2023, 05:05 AM
                        • bimole
                          Weird behavior on 3.3V rail of a CORSAIR CX600
                          by bimole
                          A colleague gave me an apparently ill CORSAIR CX600.
                          He told me that he heard a banging noise, and smelt the magic smoke.
                          After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                          I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                          It's another story on the 3.3V rail...
                          I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                          02-13-2025, 04:49 AM
                        • joshAU
                          Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
                          by joshAU
                          Hi all.
                          This notebook was showing no signs of life.
                          I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
                          However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
                          If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
                          I tried replacing the MOSFET with a new one, but again no voltage on the...
                          05-29-2024, 12:33 AM
