Re: Sumvision KY-450ATX 350W P4 PSU - recapped
Check your 12V rectifier first! Needs to be capable of at least 10A. IIRC, mine had a 12A one. But it was an ultra-fast, meaning high Vf and lots of heat dissipation.
Hehe, me too.
https://www.badcaps.net/forum/showthread.php?t=39222
FX5200: about the same or less. Most times you can tell by the GPU heatsink - if it's small-medium and fanless, it's probably in the 20W range at most. Small-medium with a high speed fan or medium with low speed fan - probably 20-50W.
If the other caps in the Delta were okay, then this one might be just okay too. But since this PSU likely runs hotter than the Delta, I wouldn't expect it to last as long as it did in the Delta.
I never tried that, so I can't say if it's a good idea or not. It might function like a PPFC coil, or it might overheat and/or cause something else to go wrong in the PSU. So, this would be purely experimental if you install it.
Meh. WEI is a waste of time. It will probably say my Pentium 3 PCs are useless, and they are not.
Hehe, me too.
Half of the computer problems is caused by bad contacts
