Recapped PowerMac 8100 PSU and now unstable
    • Jul 2011
    • 6070
    Re: Recapped PowerMac 8100 PSU and now unstable
    Originally posted by stj
    not sure about that 2.2ohm one - it sounds high but i'd needto check a good one to compare
    I would second that
    • LaPorta
      • Mar 2021
      • 14
      So I pulled that cap and some of the blue ones and the other larger gray box one as well. My ESR meter couldn't read them because they are just too low capacitance (0.1µf, etc), but my DMM at least verified their capacitance to be good. As for the high ESR reading, that was in-circuit and it was misreading as the capacitance reading was off as well.
      Should I just shotgun replace some of these? I'll keep pulling the filter caps up to and including those around the massive ones.
        • 31304
        no, check the 2 big filter electrolytics next.
        i know you replaced them - but i dont know what with
        • LaPorta
          • Mar 2021
          • 14
          I’ll do that. One thing also to remember is this problem existed prior to my changing out the caps. The problem existed 20 years ago when I acquired the machine, I just never got around to it till now!
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Sounds like maybe the PSU temp is too high. (or a thermal sensor problem)
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • PeteS in CA
              • Aug 2005
              • 3586
              • USA, Unsure of Planet
              #26
              Re CX1, measuring its capacitance in circuit will include any other X caps in parallel with it. So, for example, if there's a .47uF that is also across the AC line your .1uF cap will measure ~.57uF.
              PeteS in CA
                • 31304
                caps across the line usually have a parallel discharge resistor too.
                that will make it read higher.
                • LaPorta
                  • Mar 2021
                  • 14
                  I took that box cap out and it tested fine. Now, I have removed the blue disc caps and tested them out of circuit with the DMM, and they all test within tolerance for their specified capacitance. They are all far too small to test ESR. I tested the large filter caps, both published at 680µf, both with 0.17 ohm ESR, one 601µf, the other 592µf, so all around good. I also took out and tested the thermistor within the circuit...It appears to be rated for 7 ohm (it is 15SP M007), and tests at 11 ohm.
                  I can test more ceramics as I go, but I m running out of ones to test at this point.
                    HP Compaq Elite 8100 SFF Compaq Elite 8100 i3-550 Specification for Upgrade or Repair
                    This specification for the HP Compaq Elite 8100 SFF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite 8100 SFF boardview and Compaq Elite 8100 SFF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-12-2024, 03:44 PM
                    by sam_sam_sam
                    07-01-2024, 06:34 AM
                  • phuzzyday
                    Sony KD-70X690E. Started with reset loops.. then it got more complicated. I'm at wits end!
                    by phuzzyday
                    First of all, thank you everyone who helps others in here! You guys are treasures! Please bear with me, this may be long. I have tried a LOT.
                    First, my wife said the TV was turning off and on. When cold it would be fine for several minutes, then it would start resetting.
                    I opened it up and noted there are two main lines coming out of the supply besides the backlight., The T-Con 12V line and the main 12V line.
                    TRIED 1 - I scoped power coming from Power Supply while it was all still connected. I noted that just before it reset, the 12V line going to the T-Con was going...
                    03-26-2025, 05:53 PM
                  • shamsudeen
                    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                    by shamsudeen
                    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                    i know that in linear power supply the noise will be very low comparing to SMPS supply....
                    07-19-2025, 07:14 AM
