When recapping a switching power supply, space permitting, what are the pros & cons of increasing the capacitance of the output filtering caps?
Increasing capacitance
Re: Increasing capacitance
Some info here.Attached Filesif you find these attachements useful please consider making a small donation to the site
http://www.badcaps.net/forum/showthread.php?t=24809 -
The first one is more for DC-DC VRM than SMPS.
But usually the upper limit of capacitance is very far for ATX PSU, especially with all that other capacitive load (almost everything these days has its own VRM with input capacities) increasing it does not make much difference. You just cannot lower ESR too much, compensation may not like it if it's not designed for it (new PSUs using polymers from factory are).
Is there any particular PSU you ask about?Less jewellery, more gold into electrotech industry!
Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
It was a general question on switching power supplies vs linear mainly, but also came up when I recently recapped my McIntosh MS300 power supply with Panasonic FR's and a few Nichicons. It's a TOP249Y based 66 watt switcher powering an IBM PowerPC motherboard, a HD and a CD ROM. I resisted increasing the capacitance since ESR would be already be lower with the same size Pannys, and I know ESR can influence feedback/regulation. I figured I could always add caps to the 4-pin molex connectors going to the drives and to the 20-pin ATC connector later on if the pros outweighed the cons.
(the second pic with the switcher is before the recap)Attached Filesif you find these attachements useful please consider making a small donation to the site
Yeah FR have too low ESR, Chemi-Con KYA are much better suited for these old PSUs as they have high capacitance while reasonable ESR. That's why I have went for them. But as I do not work on such old stuff anymore, I am taking KYB next with slightly lower ESR.
Adding caps to cables (where you do not drain power from) is not a good idea, than the power will flow forwards and backwards, basically making oscillator. Filtration caps should always be as close to rectifier as possible with minimum ESR (but it must be of level which the circuitry accepts).Less jewellery, more gold into electrotech industry!
It can, but what you have up there is a discontinuous flyback PSU. Those will usually take very low ESR caps fine. You may get some high-pitched whining noises, though. Won't damage anything, but could be an annoyance for some people.
In regular PC PSUs and those that don't use a flyback topology, it's best to not go much lower in ESR. But choosing between staying with the same ESR or same capacitance, always choose same capacitance (or higher). In other words, never lower the capacitance just to match the ESR. PSUs are like the exact opposite of motherboards, where the ESR is more important.Comment
by JunkrepairI'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
I found this nice little description of the conversion:
Calculating capacitor ESR from Tan(delta)
https://forum.digikey.com/t/calculat...-from-tan/2633
It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...-
Channel: General Capacitor Questions & Issues
by dqtechhere the link for schematic - https://www.badcaps.net/forum/troubl...-the-bios-chip
board number LA-F312P ....laptop charging but not increasing percentage...charge rate very low on BATMON ....i try use another battery also same result...but when i try this battery and adapter to another laptop (dell latitude 7300) its charging normally and charge rate goes to 19k-20k mW... -
by Sparklingxwhat is the easiest way to measure the capacitance of SMD ceramic capacitors and its rated voltage?...
09-12-2024, 01:04 AM -
by AntonynlI have a tantalum capacitors with indicators EB 21 that measures only 22pF. See attached picture.
Since this is a windmeter that is normally in a very high mast I would like to get the correct replacement capacitor.
Is there somebody that can tell me what the capacitance and voltage of this capacitor are?
I don't feel confident that I can figure this out myself after searching around
Cheers!!2 Photos-
I have a K4200 GPU in my Z440 running Windows 10. Some time around October 28th, my GPU experienced a fault. My windows system BSOD'd with DPC_WATCHDOG_VIOLATION and restarted. On restart, the GPU drivers were rejected from loading due to an Error 43. There was some artifacting going on in both Windows 10 and Windows 8. The strange thing is, the artifacting only shows up in the Windows ecosystem. When the system is in BIOS, there are no graphical anomalies. I looked in the event viewer for some clues as to what was going on, and I noticed something new. The system was notifying that...11-06-2025, 07:40 PM
- Loading...
