Truepower 2.0 recap and repair
  • Kaine
    • Mar 2007
    • 55
    Hey guys. Got my hands on a dead Truepower 2.0 550W, opened her up and sure enough there's a bulged fuhjyyu 1000uF and as an added bonus a blown diode!
    Turns out pretty much every cap in the thing is fuhjyyu. what a nightmare.
    So far my replacement list is as follows:
    1x 1uF 50V 105c 5mm (Diameter)
    2x 1000uF 10V 8mm
    4x 4700uF 10V 150c 10mm*
    1x 470uF 25V Not sure on diameter doesn't really matter, it has space.
    2x 3300uF 16V 105c 10mm*
    These are most of the caps inside- all the ones i could reach and identify. There are some caps I just won't be able to get to because they're buried under coils or heatsinks. I could probably go the extra mile and get to them, any comments on whether it's worth it? Anyone know what values they are? The idea of exploratory surgery doesn't appeal to me. The caps marked with a * are the ones i haven't been able to source here in Ausland. All the others i can get from RS (mostly as Panas or Rubys). The Badcaps.net store has the 3300uF in 10mm (no room to move) but not the 4700uF. I must stress there is NO room to move with these. they have to be 10mm, max. (no pic at this stage, it's 3AM and my girlfriend is asleep) Can anyone help me?
    1x 1N4004 400V 1A
    I'm not absolutely sure this is right, can anyone confirm for me? It's pretty fried and i can't read most of the markings. I know a couple of Truepowers have appeared here, hoping someone can tell me. Would it be better to err on the safe side and use say a 600V 1A? (1N4005?) The 1N4004 diodes i bought look smaller than the dead one.
    Now some pictures, in no particular order.
    The burn mark from the blown diode on the solder side of the PCB
    You can see the bulging 1000uF in this pic
    The transformer that was next to the diode. I was worried it was cooked but a quick run over with the multi showed all connections ok. (phew)
    (Linked due to hugeness)
    This is the blown diode i removed. it's pretty cooked. Don't know if this pic will help anyone make a positive ID. That's basically all the markings that are left.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Truepower 2.0 recap and repair
    The 4700uF caps you will need to replace with 3300uF
    4700uF caps in D10mm do not exist from reputable brands (it's ok anyway because those crap Fukkhju caps prolly don't even deliver 3300uF when new!)
    Someone else will need to answer the other questions... However it should not be dangerous to increase the voltage of the diode, just good... (as long as you can fit it, keeping in mind lead-size)
    • Kaine
      • Mar 2007
      • 55
      well the 400V diode has thinner leads than the original one, so we'll see how i do. I'm not afraid to drill out the lead holes if i have to either. I think i'll go for the 600V, it should be a good fit with the current holes and the PSU should not have anything over 550V in it anyway, so it's the right number. Not like they're expensive.
      Just remembered too- i'm not sure i made a record of which way the diode was placed polarity wise. i should be able to work it out from my photos, but again, a positive confirmation on it would be great if anyone happens to have photos or a Truepower in peices atm.
      • gonzo0815
        • Feb 2006
        • 1600
        This diode does not seem to be a 1N400X diode. From the pic it seems to be rather large and with to big leads.
        The visible code does not indicate 1N400X either.
        I would assume, that this diode is something in the 6 to 8A region with that thick leads.
        If you lock at this
        http://pdf1.alldatasheet.com/datashe...I/UCC3818.html
        datasheet, you may find a basic application circuit for an 250w APFC stage.
        Most diodes are 6A one is 8A, so i think if no one could help you, with the detailed marking of the original type, i would certainly not start with a 1A rated 1N400x diode.
        A higher voltage would probably be far better, as from my point of view 400v for an 220v capable device is far to low for silicon devices.
        Sure, i am not an expert and not familiar, with any safety concerns, a higher voltage diode would imply.
        But i know from some stability tests, where an 2500v pulse is introduced at the line wile the psu is on duty.
        Most PSu`s have had no problems with this test, they simply shut of and come back after a restart.
        But a IMHO one APFC unit was dead after this test.
        It was a PSu test in the German C`t magazine.
        • linuxguru
          • Apr 2005
          • 1564
          My guess is that the diode is an FR307 or similar flyback rectifier in the auxiliary supply. You can use any fast-recovery or schottky rectifier with the appropriate current and breakdown voltage specs. The 1n4007 or similar probably won't be reliable, long-term, in this application.
          • Kaine
            • Mar 2007
            • 55
            thanks a lot guys, this is exactly the kind of info i needed. I'll get with the research and see if i can confirm what sort of diode i need.
            • Kaine
              • Mar 2007
              • 55
              The markings i can read off the diode are:
              P6KE2*** (can't read last 2 or 3)
              5369 - not entirely sure the second two digits are right.
              Google has been unhelpful. This diode is marked as D20 on the circuit board (irrelevant) and is connected in series with another 2 or 3 smaller ones alongside the yellow transformer seen above. Really hitting a bit of a wall as to what to replace it with.
              • linuxguru
                • Apr 2005
                • 1564
                Then it's a P6KE200 or similar surge supressor - basically a high-voltage zener. That's often used in conjunction with a TOPSwitch power-converter IC in the auxiliary supply, to protect/snub the MOS switch device in the TOPSwitch.
                • Kaine
                  • Mar 2007
                  • 55
                  sounds like a winner. i'll see if i can dig one up.
                  *moments later*
                  we have a winner
                  I'm taking the 600W version over the 500W version, makes more sense since the PSU itself is rated at 550W (530W is actual max). Off to the aussie motorbike show in melbourne, will be back with an update later!
                  Thanks a heap linuxguru and gonzo, you've probably saved me a hell of a lot of time and heartache.
                  Now are we positive that i can use 3300uF 16V 10mm caps in place of the 4700s? I still can't find 10mm 4700uF anywhere.
                  • Sparky
                    High voltage
                    • Jan 2007
                    • 234
                    Is there room to cram a 12.5mm 4700uF in there? In the one antec I recapped the original fuhjyyu was 10mm but the silkscreen was sized for a 12.5mm cap so it fit perfectly.
                    • Kaine
                      • Mar 2007
                      • 55
                      fraid not. i'd take a photo but my camera has suddenly decided to pack it in =< go figure. They fill the marking on the PCB and to the best of my measuring abilities are 10mm (ordering some calipers tonight)
                      • Sparky
                        High voltage
                        • Jan 2007
                        • 234
                        If there is no way to stuff a 12.5mm cap in there the 3300uF 16V cap should be fine. Many of the truepowers I recapped had that size in them on the 12V rails. Only one or two antecs I did had the 4700uF 16V.
                        • Kaine
                          • Mar 2007
                          • 55
                          thanks man, i'll do that. just have to find a place in australia that sells the samxon 10mm 3300uF 16V now. I see them on the badcaps site, but no international shipping If i must i'll just wait until my mate has got a place over there and i'll send them to him to forward on to me.
                          • gonzo0815
                            • Feb 2006
                            • 1600
                            Contact Joe, AKA bigpope (a member of this forum). He will sell it to you.
                            • acstech
                              GrumpyModerator
                              • Jul 2007
                              • 1432
                              So wait a minute here, Antec used 10v caps on the 12v line? That doesn't make much sense.
                              A man convinced against his will is of the same opinion still.
                              • Kaine
                                • Mar 2007
                                • 55
                                looks like it. there's 4 4700uF and 2 3300uF. i'm guessing that's 2 caps per rail, except the 3.3v (not filtered? my power supply design theory is sketchy at best)
                                doesn't make much sense to me. Next on the chopping block is my OCZ which has a little more ripple on its rails than i'm comfortable with. or maybe it's my motherboard? questions i can hopefully answer once this PSU is done and i can replace the OCZ with it for a solid comparison.
                                • acstech
                                  GrumpyModerator
                                  • Jul 2007
                                  • 1432
                                  I dont know how similar it is, but I have a Truepower 2.0 430w that I have already recapped. It had the same caps as your 550w. From looking at the wires and circuits under the board, it looks like the 2x 3300uf 16v caps are on the 12v rail, and 2 of the 4700's were on the 3.3v rail, and the other 2 4700's were on the 5v rail.
                                  When I recapped mine, I put 3300uf 10mm 6.3v caps back in for the 4700's, and it's been working fine. Now I had to use Panasonic NHG (not recommended due to being GP) but it has been working fine. I figure they cant be worse than Fuhjyyu's. The two 3300uf 16v replacements I used 12.5mm caps, which I did manage to cram in there.
                                  Here's a pic, if it helps:
                                  http://i231.photobucket.com/albums/e...tech/TP430.jpg
                                  • Kaine
                                    • Mar 2007
                                    • 55
                                    thanks man, that makes more sense. I should've picked it by looking at the board. oh well.
                                    Looks like we have essentially the same board layout. In fact i reckon they use the same board and just up or down-spec the components as required. I have less room around those caps because the coils are a bit bigger. That area of the board is pretty cramped. props for the pic.
                                    • Kaine
                                      • Mar 2007
                                      • 55
                                      Thread resurrection!
                                      Ok so i'm so close to finishing this i can feel it. There was a problem with the dispatch of the last batch of caps i needed so it's taken aaaaages but they're finally here. Now i just need to find a replacement fuse
                                      far as i can tell it's an M205 12A 250V ceramic (i broke it getting it out, so no pics)
                                      Can anyone confirm for me if it would be a slow blow/fast blow, if i will have any problems with a glass replacement and whether i could get away with 10A in a 550W supply? 12A fuses are like hens teeth here, particularly in the ceramic cartrige variety. The only place i've been able to find an exact replacement is at a specialist fuse dealer but minimum buy is 30 at a cost of about $35 with tails
                                      • Per Hansson
                                        • Jul 2005
                                        • 5895
                                        • Sweden
                                        10x110v = 1100w
                                        Need more clarification? :P
                                        • asr
                                          Finding replacement diode iPad Pro 3rd gen A1701
                                          by asr
                                          Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                                          Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                                          07-09-2024, 06:24 PM
                                        • unimatrix93
                                          TV backlight zener diode
                                          by unimatrix93
                                          Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                                          So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                                          Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                                          The led strips has 9 6V leds.
                                          02-10-2025, 12:13 PM
                                        • Baste
                                          MBR3045CT and SR3045LCT Schottky diode testing help.
                                          by Baste
                                          Hello experts,
                                          Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
                                          Aneng ST182 Meter.
                                          Diode mode.
                                          MBR3045CT:
                                          Diode mode
                                          Pin 2-1 - 0.150v
                                          Pin 2-3 - 0.150v ...
                                          10-21-2025, 06:14 AM
                                        • NicRac
                                          monowheel repair,Is the diode the problem?
                                          by NicRac
                                          Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                                          First of all, I am new here. Therefore I will shortly introduce myself.
                                          I am Nico and currently I study Physics.
                                          In my freetime I like to build and repair stuff. Especially big battery's.
                                          A few years ago I got myself an electric unicycle, monowheel or however you call that.
                                          The battery bms was broken so I replaced and resolder that. Nothing big.
                                          I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                                          07-26-2024, 06:13 AM
                                        • dennis_elx33
                                          NO BODY MARKING Diode
                                          by dennis_elx33
                                          Hello Everyone,
                                          I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
                                          While compared to the reading of another diode from the next channel it won't read at reverse bias.
                                          Now the problem is; it does not have any body marking.
                                          So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
                                          What do you think is this diode?
                                          Can you please suggest what part number can i use to replace this faulty diode instead?
                                          Hoping that you...
                                          06-14-2024, 12:36 AM
