Converting 12v smps in to 15v
  • sunil21
    • Feb 2014
    • 9
    • India
    For my new application I need a 15v/1amp supply. The place where I live I cant find one. What I found was a 12v/2amp supply.
    This 12v one is with a TL431 on secondary. What I am trying to do is to convert this in to 15v(1amp). No intention to use more than 1amp but will be happy if I can get up to 1.5amp. Capacitors on the output side are rated 16v , I may have to change it
    I have a few questions.
    suppose normally if without TL431, if I change the secondary turns ratio to increase (or decrease) output to 15v(1amp). 12v/2amp is 24wats against 15v/1amp is 15watts.
    will it work fine?
    Is it okay to change the resistors around TL431 to change the output voltage to 15v (transformer turns not changed) and then can my application consume 2 amps ?
    With this same thing, ignoring the components on the output side, I replace the transformer with another one to change output to, say 12v/3amp or 15v/2amp (suppose) do I need to change anything on the component side from ac 230v input to the primary winding of the transformer. what I am asking is that the circuit up to primary winding is good and have good rating and no need to alter?
    one more question - Transformer calculations may be complicated - simply asking - Transformer (Ferrite smps ones) are usually rated in watts ?
    or (the amps etc) will it go up/down according to the switching frequency ? duty cycle ?
    just asking
    • 31304
    Re: Converting 12v smps in to 15v
    i did his once, i changed a resistor related to the 431 and the optoisolator led.
    i cant remember the details, but i was trying to use a tv supply as a battery charger
    just make sure the output caps are rated higher than 16v - unless you want them to blow.
    btw, the tl431 is the reference for the optoisolator feedback.
    that sets your output voltage.
    if you change the transformer it wont change the output because the 431/opto will just ajust the drive to compensate.
    draw the circuit on the led side of the opto including the 431 and the related resistors.
    maybe a good time to learn the magic of eaglecad
    http://www.cadsoftusa.com/eagle-pcb-...e/?language=en
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Too complicated for me can you get the 12v one for free? as if you buy it and
      'have to buy parts to modify it, is one of these too expensive?
      http://www.ebay.in/itm/Laptop-Adapto...item25951dcf7b
        • 31304
        that's another way.
        what is 550Rs (Rupies?)
          http://danyk.cz/at_atx_en.html
          http://polonai.se/smps/tosh/
          • ammarben
            • May 2013
            • 63
            • algeria
            you have 2 resistors change the one connected to the output
            not the one connected to the ground
            i have done this many time
              • 31304
              great first post!
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                Originally posted by stj
                that's another way.
                Its around £5-£6 so quite cheap for us but I dont know how it relates to what is affordable in Kerala .Anyway the op may like the challenge but just put it in
                as an easy alternative depending on what the conversion would cost.
                • sunil21
                  • Feb 2014
                  • 9
                  • India
                  Thank you guys for you suggestions.
                  As mr. Selldoor suggested there are adapters available on ebay worth buying. I already have an adjustable laptop adapter and a spare 19v adapter. One primary concern with this adapters are that they are mostly size - 7in x 3in or so.. and the unit is almost 1mtr away from the plug point and I may have to drag the unit sometimes. But with 12v/2amp etc it is like traditional adapters or like mobile chargers with everything in a box right behind the plug point, no concerns and only 1 or 2 meters wire to connect.
                  Also if we could alter things with changing 2 resistors or something and things work as we want; well - it is worth doing.
                  Okay I am asking one more question (so I don't have to start a new thread) - if I change the output to 15v by changing things around this TL431, can I draw 2amps of current?
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5096
                    • New Zealand
                    You probably could draw 2 Amps but it wouldn't be wise to do it for too long. If you increase the voltage you will decrease the current available, if you want to keep the components operating at what they were specified for and the operating temperature expected etc.
                    I don't know how you would calculate exactly how much current you could get away with at 15v though.
                    -David VanHorn
                      • 31304
                      it's probable that you couldnt do 2a at 12v - most ratings on psu's are lies.
                      DONT FORGET TO FIT 25V CAPS.
                      • learnmore
                        Help choosing replacement transformer for Levoit 600S SMPS
                        by learnmore
                        Hello Community,
                        I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                        Peace
                        LM...
                        11-04-2025, 09:35 AM
                      • sansonet
                        Converting 12VDC transformer to 12VAC
                        by sansonet
                        I need an AC transformer because the one I used is burned. Since I have some unused DC transformers, I wonder if it is possible to just remove the bridge rectifier from it to convert it to an AC transformer. I measured voltage before the rectifier on this one - it shows 13 VAC, and 16 VDC at connector without load. Rated 12VDC 1000mA....
                        06-29-2023, 03:20 PM
                      • Briesmith
                        Can High Side damage on an SMPS get across the Transformer to the Low Side?
                        by Briesmith
                        I have a blown smps and I am looking for some reassurance as to the amount of diagnosis I have to do. It blew the instant I plugged it in not under any load.
                        As you can see from the attached pix, the damage is located around the main or bulk capacitor (since removed for testing) and the resistor array/network that drives it (the bunch of SMD components to the left of the YAMAHA YC775 AMPS logo). The burn mark on the frame clearly shows the pins of the capacitor. And, for the avoidance of doubt, there is no way the board could have contacted the frame, it was correctly mounted on...
                        05-06-2023, 09:36 AM
                      • mikey5791
                        Is it possible for transformer substitution?
                        by mikey5791
                        Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                        Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                        My questions are
                        1. How do i test to see if the transformer is in good working condition?
                        2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                        Hope you guys understand what i was asking. My intention is...
                        11-03-2022, 02:11 AM
                      • PlayerOne
                        Velodyne SMPS, power transformer
                        by PlayerOne
                        I need help in finding a schematic or otherwise identifying the electrical characteristics of a transformer in a SMPS having the following marking:
                        042-010214-000ZR
                        ELY 1317
                        A photo of the transformer is attached. In particular, this is a PCB mounted transformer and I need the pinout.
                        I've tried Google searches of various portions of the part number with no luck, however managed to find posts with photos of this transformer having the same markings, except for the numbers following the “ELY” which leads me to believe they must be date code...
                        03-31-2020, 12:37 PM
