Silverstone ST1500 (+5Vsb shorted)
  • new2019
    • Aug 2014
    • 49
    • Srilanka
    Hello everyone , I have some problems with my psu.
    The psu is not powering on (no green light or fan not spinning)
    I opened the psu and found short on +5Vsb , I removed all caps in that line and still short is there (its not a full short , its a lil short like 23ohms not 1 or 2 ohms)
    Also I found another short in primary circuit its also about 34ohms .
    I examined all components and didnt find any blown caps or blown diodes.
    Board has zero burn marks its fresh . Also this psu has a short circuit protection , when it finds a short it will shutdown and wont come up until short is gone .
    please tell me where I can start my testing procedure from now ?
    Thanks for your help!!!
    Re: Silverstone ST1500 (+5Vsb shorted)
    GOOD, CLEAR Pictures and test points where you see all these low resistance readings will help us to help you.
    • new2019
      • Aug 2014
      • 49
      • Srilanka
      Ok I took the pics , il upload it now .
        • 31161
        probably a load resistor or a shorted diode / ceramic cap
        • new2019
          • Aug 2014
          • 49
          • Srilanka
          I have marked the shorted points . other than those places I dont find any short .
          il upload more pics later , it takes alot of time to upload.
          ps: the short goes up to the small secondary board (the one I have showed in single line red , which has many pins in a straight line ) .
          How can you check if the load resistance in gone ? I checked the resister that is connected between live and neutral wire , it has about 200kohms , also there are two filter caps connected to it ( all these stuff are out of the board ) these are present near the power socket.
            • 31161
            you see all those resistors that say "201"?
            those are 200ohm and they are in parallel - that's your 25ohm
            your actual problem is something else - maybe startup capacitors.
            what small 4.7 to 47uf caps are on the top?
            • selldoor
              Slow Learner
              • 7870
              Picture from the top straight on and acouple from each side?
              • new2019
                • Aug 2014
                • 49
                • Srilanka
                @stj thanks for clearing my big problem , I thought that line was fully short .
                so 10 200ohms resisters in parallel is about 20ohms that makes it correct ( because the multi would read some what higher than real ) .
                can you pin point on what area I should look for start up caps ?
                Also I connected this to power got a small fluctuating voltage like 0.01v - 0.02v.
                thanks mate
                • selldoor
                  Slow Learner
                  • 7870
                  Just a couple of points - can we assume you are trying to start it with a jumper on green to ground?
                  Some supplies need a load to start so can you attache something the 12v- Hard drive?
                  car lamp? and something to 5v
                  • new2019
                    • Aug 2014
                    • 49
                    • Srilanka
                    here they are !!!
                    @sji : can it be the short thats on the primary circuit that I have shown in yellow ? I checked the rectifier and I didnt find a problem with it .
                    Can I suspect any transistors ?
                    Also In the primary circuit I found two resistors shorted ( fully short )
                    • new2019
                      • Aug 2014
                      • 49
                      • Srilanka
                      I shorted green wire to ground and connected a dvd rom , also tried a sata harddisk .
                      Nothing comes on . But I hear a sound near the filter capacitor near the power socket , then I removed it and tried to turn on but still nothing.
                        • 31161
                        that's packed in so tight i cant see anything!
                        i'd just replace all the small caps with FR or FC series and see if the standby voltage starts.
                        • new2019
                          • Aug 2014
                          • 49
                          • Srilanka
                          do you mean the outputs secondary caps ? what are FR and FC series ?
                          Will it be related to caps ? I find a short in the primary circuit about 32ohms .
                          I cant figure from where it comes.
                            • 31161
                            panasonic FR and FC series caps - very high quality stuff.
                            i'm not really talking about the output caps, i'm refering to small ones - under 100uf probably that are related to the actual control circuits.
                            most psu chips have what we call a "startup cap" that is responsible for kicking it into action when the power is applied.
                            because they are small, they dry up inside - the official minimum life on such small caps is only 1000hours.
                            1000/24 = 41 (days!!!)
                              • 31161
                              about that 32ohm, is it on the ac side of the rectifier, or the dc side?
                              is it the same with the meter wires the other way around?
                              • new2019
                                • Aug 2014
                                • 49
                                • Srilanka
                                I ordered this stuff: here
                                ok il replace all those caps , what do you think about the ceramic caps ?
                                its a shame to have such low life .
                                Its on the AC side thats what I meant by primary side ( im sorry for mis typing)
                                Even though I change the poles of the multimeter wires it keeps the same.
                                On the 10th post 3rd pic , can you notice two big green caps (which looks in box shape and has a black wire) can it even cause a issue like this ?
                                one more thing: I got a buzzing noise when I connected to power in this part: here
                                then I ordered this , up to now I didnt install it , will the psu power on if I install this ? also why do they call this a relay ?
                                thanks mate
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  If you have ordered it is too late but we dont often recommend ebay for caps - many fakes around. That seller also has feedback on those caps -sent inferior ones.
                                  Also the startup and small caps are often 50v did you get 10v from the caps you are replacing, and another thing, they are 11x8mm - will they fit?
                                  • new2019
                                    • Aug 2014
                                    • 49
                                    • Srilanka
                                    but its a $ , I bought it because when I removed one of the 470uf cap one leg broke off , so I thought this would do the job it was also a 10v 470uf cap , I have small question about replacement cap , as a replacement cap it should have same capacitance but it can have higher voltages right ?
                                    Where can I get good ones ? I normally use ebay for all electrical stuff , because I cant find anyone who ships worldwide .
                                    If anyone could fix this psu I can pay for work and parts . Because I spend over 250$ few months ago to buy this , I cant waste any money on new psu so im kinda trying to wake this up.
                                    or il try to fix it my self with all your help .
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      Yes its a $ but look at the work involved in fitting it. So you only want to do that once!?
                                      Yes you can use a same uf higher voltage ( usually one step)
                                      You can also often use 1 step higher UF.
                                      NEVER use lower uf or lower voltage (unless you really know what you are doing)
                                      I dont know where you can get good make caps in Srilanka and I have not seen many
                                      Srilankan members on this forum. International sellers are Digikey Mouser RS components , Maybe Farnells and there maybe some in Australia that ship to Srilanka
                                      'What are the part numbers on the controller chips on the riser board?
                                      • new2019
                                        • Aug 2014
                                        • 49
                                        • Srilanka
                                        lol I didnt read about size , also I dont have a caliper to check the sizes of the caps ,
                                        I have to see how its going to fit , but next time I'm going to order stuff after checking all compatibility .
                                        The numbers that I see are:
                                        one the big chip: PS232S
                                        B08641A1F
                                        on the small chip: WT7518 S144
                                        916 J29AB
                                        Both of these chips are there in the same riser board .
