Hbl htv-160c1
  • 3d0
    • Jan 2014
    • 159
    • BiH
    Hbl htv-160c1
    Hi guys, got this AC adapter with no output.
    The large transformer is making a strange noise, I think it's toast?
    What do you think, thanks!
    Re: Hbl htv-160c1
    I do not think the circuit is Oscillating. It that really a thermal fuse? it looks more like Thremistor. What is the resistance reading? If it is Thermal fuse, then you would have 220V at both end since Thermal fuse will have <1 Ohm resistance.
    • 3d0
      • Jan 2014
      • 159
      • BiH
      Re: Hbl htv-160c1
      Tried searching for a datasheet, didn't find much.
      The part is Aupo A3-F and the resistance is 1 Ohm?
        • 31161
        Re: Hbl htv-160c1
        if those voltages in the foto are rfom the board,
        then it's running.
        i'd say the big toroidal inductor is open-circuit.
          Re: Hbl htv-160c1
          You have to measure the primary voltage using AC mode on the meter to know if it is running or not, the circuit is just a high frequency self oscillating. It can also be that your meter cannot display high frequency (>30KHz) AC at the out put (it is not 50 or 60 Hz AC output). Also, what do you use for the Ground ref point for those voltage measurement?
            • 31161
            Re: Hbl htv-160c1
            board says 11.5v output,
            his foto shows 11.5 going into the choke - look at the underside foto again.
              Re: Hbl htv-160c1
              It is not 1:1 power transformer, that drive voltage of 11.5 on the primary side is way to low, those two large transistors (or MOSFETs) are running from the primary line voltage, you can see that one of the Collector pin has 162VDC, another Emitter has 230V, so primay is not driven by 11.5V.
              He needs to find out how many windings there are on that power transformer. He also needs to tell us which point he uses for the circuit ground ref point.
              "The part is Aupo A3-F and the resistance is 1 Ohm?" if one end has 220V and another end is showing only 9.9V that means the voltage drop on that 1 Ohms is 210V which is impossible.
                Re: Hbl htv-160c1
                Thermal fuse voltage drops reading error, need to verify circuit ground ref point. You can also see the error in reading of the two points (where I indicate the B+) that are on the same trace, one point show 228V, anther poInt next to it shows 230V.
                BTW, the B+ feeding the circuit is not clean steady DC (100Hz pulsing DC), as you can see, there is no large electrolytic cap for filtering.
                • 3d0
                  • Jan 2014
                  • 159
                  • BiH
                  Re: Hbl htv-160c1
                  I pulled out the transformer and tested it for continuity from the primary to secondary side, then tested the primary side for resistance it was 0.8 Ohms, the secondary was 0.5 Ohms that doesn't look good does it.
                    Re: Hbl htv-160c1
                    The DCR reading will be very low (that is typical for power transformer), but to the circuit driving it , the circuit will see at as high impedance.
                    You need ringer tester to find out if the transformer has shorted winding or not, I do not believe it does, otherwise the Thermal fuse would have blown up by now.
                    Did you test those two large transistors to see if they are OK? P/N as printed on the body of those transistors?
                    • 3d0
                      • Jan 2014
                      • 159
                      • BiH
                      Re: Hbl htv-160c1
                      Thanks budm, I used one of the primary ac inputs as a ref. thats why the readings are sketchy, sorry.
                      I'll post the new ones soon, no I didn't test them. They are BUL38DA.
                      Sorry to confuse you stj.
                      The DMM was set to AC.
                        Re: Hbl htv-160c1
                        OK, that explained the strange readings you are getting.
                        Can I also get better focused picture of the bottom side, and bottom side in sections (may be in 4 sections) so I can easily trace those copper traces on the board.
                        So those two transistors are NPN.
                        http://elcodis.com/parts/432008/BUL38D.html#datasheet
                          Re: Hbl htv-160c1
                          That one with 640V? That cannot be, that is the out put of the bridge rectifier circuit, non filtered.
                          • 3d0
                            • Jan 2014
                            • 159
                            • BiH
                            Re: Hbl htv-160c1
                            Checked it again, its 640V. I used the ref. point in the previous image you pointed out as ground? If I look at it now its D1 on the anode (+) side where I put the black probe. Using the cathode side as gnd. the readings are different, I measured the thermal fuse 229V on one side and 15V AC on the other.
                            The transistors tested good, also the small npn transistor C945 is ok.
                            Thanks for the guidance and explanations, much appreciated.
                            • 3d0
                              • Jan 2014
                              • 159
                              • BiH
                              Re: Hbl htv-160c1
                              I'm not sure how a CAT II device could survive readings over 640V without blowing up something internally, so I went out and bought a new auto range DMM, and all the readings up till now are false.
                              I feel bad for giving misleading info. Srry guys
                                master hoarder
                                • May 2008
                                • 12175
                                • Bulgaria
                                Re: Hbl htv-160c1
                                I'm guessing this PSU is for driving 12V halogen bulbs for a house lightning fixture?
                                I've repaired one similar to this design before (self-oscillating, no secondary feedback, and no controllers of any kind). On mine, two of the bridge rectifier diodes were blown and the two BJTs were OPEN. So I say pull your BJTs out and check them either for short or open circuit. Also test all small signal diodes for S/C and resistors for O/C.
                                  Re: Hbl htv-160c1
                                  BTW, How many wires are there for the power transformer? 4 or more?
                                  • 3d0
                                    • Jan 2014
                                    • 159
                                    • BiH
                                    Re: Hbl htv-160c1
                                    Yes momaka, it's a halogen lamp transformer.
                                    I've already tested all 3 npn transistors out of circuit, they tested good, might as well take them out again and double check with the new dmm.
                                    Only 4 wires on the big transformer.
                                    Thanks guys
                                      • 31161
                                      Re: Hbl htv-160c1
                                      meters giving stupid readings are caused usually by a flat battery.
                                      dont trust any "low battery" indicators - they arent worth shit!
                                      • 3d0
                                        • Jan 2014
                                        • 159
                                        • BiH
                                        Re: Hbl htv-160c1
                                        I replaced the battery but still get abnormal values. Tough I would like to know what fools one meter and not the other, it's beyond this topic for sure.
                                        It might be leaking diodes in the bridge rectifier, or just the unfiltered/rippling dc running at 100-120Hz not being filtered through a capacitor.
                                        Tonight I will have more time to investigate, and maybe with some help and guidance figure out whats really wrong with it.
                                        • cind12
                                          GTX 1080 TI Gigabyte Aorus low resistance on vmem
                                          by cind12
                                          Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                                          Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                                          The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                                          Resistance on 12V 4K ohms (Power present when on)
                                          Resistance on 12V PEX 4K ohms...
                                          12-08-2023, 09:09 AM
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
                                        • Nagy Daniel
                                          Lowest possible resistance on laptop motherboard rail - Guide Table request
                                          by Nagy Daniel
                                          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                          So, I generated a table with AI so I can...
                                          03-04-2025, 08:24 AM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
                                        • jshhh
                                          Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                          by jshhh
                                          Hi guys,
                                          I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                          How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                          Anybody know how to remove this type of fuse?
                                          (The fuse is toward the bottom of the image labeled F2)...
                                          06-17-2025, 01:35 AM
