Hbl htv-160c1
    Re: Hbl htv-160c1
    BTW, you may want to read the PDF, your circuit uses fullwave bridge without fiktering cap so you will know what expected voltage reading should be. Is your new meter True R.M.S?
      master hoarder
      • May 2008
      • 12175
      Re: Hbl htv-160c1
      Probably a long shot here, but I looked at the bottom side pictures again, and some of the joints look very very cloudy and could possibly have micro-cracks. Since these things tend to run miserably hot, I suggest reflowing all of the joints just for piece of mind.
      Also, when I fixed my inverter, I tested it with a single 12V light bulb. So I'm thinking, doesn't this thing need a minimum load to oscillate properly?
      • 3d0
        • Jan 2014
        • 159
        • BiH
        Re: Hbl htv-160c1
        No, I wish it was. Could that somehow explain the readings on my previous dmm?
        Thanks for the link, I enjoyed reading it. Simple enough for me to understand & the illustrations are great.
        • 3d0
          • Jan 2014
          • 159
          • BiH
          Re: Hbl htv-160c1
          Yes, the soldering is bad, cant really tell from the pictures. Lot's of small cracks on the joints.
          Not sure about the minimum load, it could be possible. I'll try it after testing the diodes, resistors etc. something had to go wrong.
          • cind12
            GTX 1080 TI Gigabyte Aorus low resistance on vmem
            by cind12
            Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
            Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
            The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
            Resistance on 12V 4K ohms (Power present when on)
            Resistance on 12V PEX 4K ohms...
            12-08-2023, 09:09 AM
          • corrize
            A funny fuse story – Lumix LX100 II
            by corrize
            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
            10-19-2023, 09:58 AM
          • Nagy Daniel
            Lowest possible resistance on laptop motherboard rail - Guide Table request
            by Nagy Daniel
            Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
            I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
            I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
            So, I generated a table with AI so I can...
            03-04-2025, 08:24 AM
          • jesterace
            Samsung UE46ES8000 Blown fuse but no other signs of short
            by jesterace
            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
            09-11-2024, 03:14 PM
          • jshhh
            Help replacing fuse on my Mimaki CJV300-160 vinyl printer
            by jshhh
            Hi guys,
            I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
            How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
            Anybody know how to remove this type of fuse?
            (The fuse is toward the bottom of the image labeled F2)...
            06-17-2025, 01:35 AM
