What maybe causing this Chopper to short ?
  • SM-Piyes90
    • Feb 2014
    • 120
    • Morocco
    Hello everyone here .
    Am right now trying to repair a switching style power supply , this one converts low input current to pretty much 160 amps to be mainly used as a MMA welder .
    Anyways i checked it step by step , started with the primary side , the primary caps got 300 Vdc on them , now arriving to the chopper circuit witch consists of 2 power IGBTs , that are making the input signal chopped at a very high frequency with the command of a pulse width modulation chip " UC3842 " .
    So i checked the power transistors with a continuity tester , and they are both shorted , also found 2 shorted A3120 optoisolators , four 18 v zeners .
    I then changed them all with new parts , in the hope to save this unit but again all the parts that i' ve replaced have again fried .
    I guess something else is causing them to burn , i hope i get some ideas from people who encountered similar issue .
    Here is a Service manual of the SMPS welder :
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: What maybe causing this Chopper to short ?
    perhaps pictures of the board would help , take it you have ~220vac mains.
    Perhaps use the dim lamp trick - a 75watt filament bulb in line wth the + mains
    saves blowing up components
    • SM-Piyes90
      • Feb 2014
      • 120
      • Morocco
      Hi thanks for the comment , ireally don't know about the light bulb trick , but i got this in mind
      You can take a look at the PDF service manual , it contains schematic and picture of the PCB .
        • Jul 2011
        • 6046
        That very good manual most of them are not very good
          One thing can be that the U3845 (as shown in page 9) DR+ has the output stuck HI instead of turning those two Optos on and off.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Check the secondary side rectifiers?
            Muh-soggy-knee
            • SM-Piyes90
              • Feb 2014
              • 120
              • Morocco
              Thanks ths one is for professional servicing.
              • SM-Piyes90
                • Feb 2014
                • 120
                • Morocco
                I have changed that too , but still the boom occurs
                • SM-Piyes90
                  • Feb 2014
                  • 120
                  • Morocco
                  ALL secondary side rectifiers were good and still good after chopper short .
                  I see that you guys think in most of the cases capacitors are bad , but how about the transformer how can i check if its good or bad ???
                  also how about ESR check for small value caps like plastic non polarized ones ??
                    You need the ringer to test that power transformer, it may have shorted turn. The DCR of the transformer will be very low (<1 Ohm).
                    • SM-Piyes90
                      • Feb 2014
                      • 120
                      • Morocco
                      Hi again am back topic .
                      Thanks BUDM for the assistance there also all the other members , thanks for the suggestions .
                      I have a few questions about how the PWM ic performs .
                      - Do you know an adequate method to check the output signal of that PWM IC ?
                      - And what is the nature of the signal at the IC output , is is square or sine ???
                      - Also what is the minimum frequency that needs to be applied to the IC in order to monitor the output .
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        where do you buy your parts?
                        seen many repeat failures where counterfiet parts were the issue.
                        • senz_90
                          • Aug 2013
                          • 328
                          • Indonesia
                          squarewave signal on the output pin of 3842 IC
                          "There is no shortcut to be successful. No pain, no gain."
                          Best Regards
                          Rudi
                          Thank You
                          • SM-Piyes90
                            • Feb 2014
                            • 120
                            • Morocco
                            I buy them from a local electronics shop , but the transistor i used is a FAIRCHILD one took from another device .
                            After analysing the card more i found two bad plastic capacitors ( 0.1 uF 250 V-AC) that are directly connected in paralell to input mains , i was measuring only 3 nF on them , the main filter cap is a 68 uF , 400 V , measuring 56 uF and having a dissipation factor of 1.05 (DF) , these measurements were took with an LCR meter .
                            Any ideas ? could this be causing the chopper transistor to short ?
                            • SM-Piyes90
                              • Feb 2014
                              • 120
                              • Morocco
                              UPDATE :
                              I have changed the two main's 0.1 uF capacitors , and the unit got working again , but i get small problem on the two output sections :
                              First section is 5 v and 3.3 v given via voltage regulators, and they are outputing the right voltages .
                              Second sections is outputing 5.8 , 12 , 14 , 38 V dc , but i get higher results , for example the 12 and 14 v outputs gives me 22 v , 38 v output gives 65 .
                              Any one familiar with this scenario ??
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4981
                                • New Zealand
                                I can't see 14v or 38v rails on the schematic - do those rails have a feedback circuit? Perhaps there is something wrong with it.
                                -David VanHorn
                                  " i found two bad plastic capacitors ( 0.1 uF 250 V-AC)" What are the caps designator as shown in the diagram, I see C1 (1uF 275V X type) which is across the line. CI is the line filter cap, the unit will still function without it but it will inject the noise into the AC line.
                                  "the main filter cap is a 68 uF , 400 V" the schematic shows two (C3, C4) 680uF 400VDC caps.
                                  • SM-Piyes90
                                    • Feb 2014
                                    • 120
                                    • Morocco
                                    Sorry if i have mislead you , but am talking about another card witch i use for tryouts , It has the same problem as the one i mentioned earlier ; So when i replace the switching transistor , it shorts again.
                                    what i did next is checked the two interference suppression capacitors , and changed the main filter cap with another one but i doubt it was bad , what am sure of is that those two 0.1 uf suppressor caps were giving only 3 nF and after re[placing them the unit started to work , but i only get two correct outputs : 5v & 3.3 v , the other ( 12,14,5.8,38) voltages give respectively ( 22,22,7.6,64) , is there a possibility those outputs were meant to be regulated on another terminal ?? this card BTW belongs to an old satellite receiver .
                                    Here is the second card :
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4981
                                      • New Zealand
                                      Probably better if you start a new thread for this other PSU. But have you checked the output capacitors? If they are dead, bad regulation problems can occur.
                                      -David VanHorn
                                      • SM-Piyes90
                                        • Feb 2014
                                        • 120
                                        • Morocco
                                        I need ESR meter for that .
                                        I guess there is no need to start another thread .
                                        Thread can be closed .
                                        • DynaxSC
                                          Extreme High Current & Low Voltage Short Killer ??
                                          by DynaxSC
                                          Hi Folks
                                          I'm looking for a extreme high current short killer solution for a reasonable cost.
                                          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                          After taking off the socket, the shorts dissappear again.
                                          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                          10-15-2024, 10:13 AM
                                        • Stephen
                                          MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                                          by Stephen
                                          I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                                          02-06-2025, 12:03 PM
                                        • Victor Moreira Silva
                                          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                          by Victor Moreira Silva
                                          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                          Well, my decice specs are the following:
                                          Model: Acer Nitro 5 AN517-54-55T5
                                          CPU: Intel Core i5-11400H
                                          GPU: NVIDIA GeForce GTX 1650
                                          Motherboard: GH51G LA-L181P Rev:1c
                                          The symptom:
                                          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                          05-26-2025, 10:49 AM
                                        • spleenharvester
                                          Reverse engineering of DoCreate DHJ567 handheld spot welder
                                          by spleenharvester
                                          Hello everyone
                                          I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
                                          Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting...
                                          05-08-2025, 02:52 PM
                                        • evilkitty
                                          Flux causing high resistance short?
                                          by evilkitty
                                          Now that my de-soldering gun is working i was able to remove this panel i made about a week before i noticed a issue the F segment of digits 2 and 3 would go out, digit 2 would go before digit 3, but would come back after the humidity got down from running the ac (note the weather outside is 30.5 / 74%; panel data is from a BME280)
                                          Temp is on the left humidity is on the right
                                          i noticed when the humidity got up one or 2 of the center digits on the right panel would loose a segment
                                          The pin out looking down from the top is (note this is common cathode)...
                                          07-17-2024, 09:38 AM
