What maybe causing this Chopper to short ?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5064
    • New Zealand
    Re: What maybe causing this Chopper to short ?
    You could just change them and see what happens.
    But if you want to get into repairing SMPS or anything that uses them, you really should have an ESR meter. There are many designs of basic and cheap ESR meters all over the internet, you should be able to make one easily, just make sure the test frequency is 100kHz.
    -David VanHorn
    • senz_90
      • Aug 2013
      • 328
      • Indonesia
      Yes, sometimes the regulation problem on SMPS could be caused by secondary caps or feedback circuit. btw if I am remember correctly, my homemade ESR meter get a help from you agent24 that send me a vector design application
      "There is no shortcut to be successful. No pain, no gain."
      Best Regards
      Rudi
      Thank You
      • SM-Piyes90
        • Feb 2014
        • 120
        • Morocco
        I see a lot of designs , but i have hard time finding the analog display .
        Hi could you send your schematic ? and PCB layout if possible
        • SM-Piyes90
          • Feb 2014
          • 120
          • Morocco
          I remember some few days ago reading about a method to check ESR using an oscilloscope , i actually have one and i have also an LCR meter that also measures the Dissipation factor , here are some equations for that parameter :
          Maybe some one good at maths can help us out
          • Agent24
            I see dead caps
            • Oct 2007
            • 5064
            • New Zealand
            There are many eBay sellers in China with them, but I can't vouch for their quality.
            -David VanHorn
            • senz_90
              • Aug 2013
              • 328
              • Indonesia
              #26
              there are many esr meter design on googling. just try type esr meter on it and many of them are analog one. If you have budget, you could get a decent ESR meter likes Blue ESR Meter, ESR Micro, etc. Since I do this electronics thing just for hobby I don't buy commercial one If you are expert in microcontroller, also there some site share design with LCD panel display if you find hard to read on analog display.
              like this
              members.shaw.ca/swstuff/esrmeter.html‎
              ludens.cl/Electron/esr/esr.html‎
              Mine is just a copy of them since I'm not expert on electronic and couldn't make a good design, so I just make a little change to suit it with my VOM mA range. btw there are other design on this forum made by budm or tom66. you can try it too.
              If you don't mind you could try this
              http://electronics-diy.com/esr-meter...ance-meter.php
              I want really to build this but I couldn't found any supplier on my town has ICL7106/7 IC. If you found this really useful I will try to buy it via Ebay or my brother when he is going abroad. Im really curious for this one . thank you
              Best Regards
              Rudi
              Thank You
              • Agent24
                I see dead caps
                • Oct 2007
                • 5064
                • New Zealand
                #27
                There's quite a few digital ones too, if you can't get an analog meter. There's also this one: http://circuit-zone.com/?electronic_project=484 which uses the multimeter for a display.
                Myself, I built Bob Parker's BlueESR meter, it's really nice, but it is rather expensive.
                -David VanHorn
                • SM-Piyes90
                  • Feb 2014
                  • 120
                  • Morocco
                  #28
                  You know i actually got 10 of those ICL7106 but i guess they may work instead of 7107
                  You see the problem is only on the availability of parts , building is easier after testing the circuitry on breadboard
                  Thanks for this bro , i will add this to my other ANATEK ringer replica.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5064
                    • New Zealand
                    #29
                    That one with ICL7106 looks nice but test frequency is only 60kHz. Datasheets almost always spec their ESR at 100kHz. If you use this meter you will get an inaccurate result.
                    Either change the design so it's 100kHz or use a different design.
                    -David VanHorn
                    • SM-Piyes90
                      • Feb 2014
                      • 120
                      • Morocco
                      #30
                      This design is using a 555 timer as frequency generator , is there a way i can make it give 100 kH by variying some parameter , and would the tester work as expected ?
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5064
                        • New Zealand
                        #31
                        I don't recognize the configuration they are using that 555 in, but at a guess if you change C5 value to a little over half, it will probably run at 100kHz. Good idea to test it on a breadboard first, probably.
                        I don't know if the rest of the circuit will still operate properly, though.
                        -David VanHorn
                        • senz_90
                          • Aug 2013
                          • 328
                          • Indonesia
                          #32
                          Yes, indeed ICL7106 would work. But I couldn't found anyone sell this ICL7106 or ICL7107 on my town. thank you, please inform if you build it successful. By the way, I am too build ringer replica from anatek . It looks like not a problem since I don't sell it, I am using it for myself to servicing CRT TV and Monitor.
                          Best Regards
                          Rudi
                          Thank You
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5064
                            • New Zealand
                            #33
                            You could try eBay - but beware the Chinese sellers, there are many fake parts.
                            -David VanHorn
                            • SM-Piyes90
                              • Feb 2014
                              • 120
                              • Morocco
                              #34
                              What is normal ESR for a 400V 470 uf , i don't see esr values for high voltage ratings on online charts .
                              If results accuracy is a negligeable then its not a big deal for me .
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5064
                                • New Zealand
                                #35
                                They don't show ESR in those sheets because it's not a 'Low ESR' capacitor. However, I did measure a couple of 200v 470uF caps the other day and they were 0.06 and 0.08 ohms ESR, and as far as I know, not faulty. So if you measure some and they are significantly higher than that, they may be bad.
                                I don't know how much difference it will make. The datasheets almost always specify ESR at 100kHz, and 60kHz is almost half that. It may mean your readings would end up about half (or twice) what they should be, which would be rather useless.
                                -David VanHorn
                                • senz_90
                                  • Aug 2013
                                  • 328
                                  • Indonesia
                                  #36
                                  Btw, is there any way to recognise fake parts or items?
                                  Best Regards
                                  Rudi
                                  Thank You
                                    Nearly none, aside from carefully comparing known originals and the supposed replacements -- but that can be wrong, as manufacturers can change parts over years, and fakes can also look very good!
                                    Just have to buy from honest suppliers who buy direct from manufacturers.
                                    • SM-Piyes90
                                      • Feb 2014
                                      • 120
                                      • Morocco
                                      #38
                                      oH , that makes a difference then .
                                      So better build a 100 KHz one , i hope i can find one using ICl71xx
                                      • senz_90
                                        • Aug 2013
                                        • 328
                                        • Indonesia
                                        #39
                                        So it looks like we hope from luckiness, my experience is less on ebay. hahaha
                                        Best Regards
                                        Rudi
                                        Thank You
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 5064
                                          • New Zealand
                                          #40
                                          If it comes from China and they cost half the price of a genuine part, or you can buy ten of them for the price of one genuine one, you're probably looking at a fake\knockoff\other dodgy part.
                                          They don't usually sell outright fake chips (eg: lumps of metal coated in plastic) - too many people would complain and eBay is biased towards the buyer - but they may be clones with lower power ratings, worse specifications, or genuine 2nds that were supposed to be dumped, or used chips cleaned up to look like new, or some other dodgy version.
                                          As always, you get what you pay for.
                                          I do buy some cheap crap from there, like LM1117 regulators, got 20 for $1.50 or something - they seem to work OK but I'm only using them for prototyping etc and not running them at full capacity.
                                          -David VanHorn
                                          • DynaxSC
                                            Extreme High Current & Low Voltage Short Killer ??
                                            by DynaxSC
                                            Hi Folks
                                            I'm looking for a extreme high current short killer solution for a reasonable cost.
                                            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                            After taking off the socket, the shorts dissappear again.
                                            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                            10-15-2024, 10:13 AM
                                          • Stephen
                                            MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                                            by Stephen
                                            I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                                            02-06-2025, 12:03 PM
                                          • adelfr2009
                                            HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
                                            by adelfr2009
                                            I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
                                            After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
                                            09-28-2025, 10:21 PM
                                          • Victor Moreira Silva
                                            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                            by Victor Moreira Silva
                                            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                            Well, my decice specs are the following:
                                            Model: Acer Nitro 5 AN517-54-55T5
                                            CPU: Intel Core i5-11400H
                                            GPU: NVIDIA GeForce GTX 1650
                                            Motherboard: GH51G LA-L181P Rev:1c
                                            The symptom:
                                            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                            05-26-2025, 10:49 AM
                                          • spleenharvester
                                            Reverse engineering of DoCreate DHJ567 handheld spot welder
                                            by spleenharvester
                                            Hello everyone
                                            I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
                                            Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting...
                                            05-08-2025, 02:52 PM
