HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
  • adelfr2009
    • Aug 2025
    • ALGERIA
    I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
    After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes slightly warm.
    The 3V and 5V rails are working fine, but the short is present in the CPU and GPU area. I removed one coil connecting the VCORE line to the CPU, and when measuring the resistance on the load side, the multimeter gives a beep (short). I injected 1V / 1A into the output, but the CPU did not heat up.
    When measuring, I found that the drawn current is about 0.185A, and the voltage on the capacitors at the load side is about 0.57V.
    Diode mode measurements:
    3V coil → 0.438
    Large coil (GPU supply) → 0.051
    Another voltage coil → 0.415
    Coil near RAM → 0.414
    CPU coils → 0.006
    GPU coils → 0.003
    Coil near charging IC → 0.461
    I suspect the CPU is faulty. How can I confirm this? Do I need to remove all coils on the VCORE line to be sure, or is removing one coil enough?
  • DeXXter
    • Aug 2023
    • 105
    • Chile
    What resistance do u have on B+/19v power rail? 1ohm, 2ohm? from the main current sensor you can measure resistance to gpu and cpu coils to check if you have a short there or a shorted mosfet, also you can inject 1v on that same main current sensor and measure voltage on all the coils because you might have a current leak if that's the case you have to identify which phase, so then you start lifting/desoldering coils/inductors, ofc I guess you checked you didn't have some kind of hole or a burnt spot on the motherboard.
    • adelfr2009
      • Aug 2025
      • ALGERIA
      I injected 1V after the first current sense resistor and discovered there was leakage towards the CPU side, because when I measured the voltage at the CPU coil I found 0.5V. I then removed the coils and found there was a short on the side of one of the MOSFETs. The MOSFET is a dual MOSFET, and the short was on the high side — this was the cause of the leakage.
      Now I need to know whether the CPU (Ryzen 7535HS) survived or not. When I measured the resistance on the CPU side, I got 2.6Ω (with bip). Next, I have to figure out the root cause of the short that led to all of this.
      What do you think?
      • ERRA
        • Sep 2025
        • 25
        • Morocco
        What do you think?
        Repalce the faulty mosfet and do the injection test again (no more than 0.9v) !!
        • jm942
          Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
          by jm942
          My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
          I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
          I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
          I did voltage injection on the cpu with 0.7V and i have a current...
          07-11-2024, 05:11 AM
        • Robin21
          HP Victus 15-fa1024nt - DAG3PAMB8D0 Rev: D Model: G3PA
          by Robin21
          Hallo,
          Looking for schematic and boardview
          M/B: DAG3PAMB8D0 Rev
          Model: G3PA
          Thank you in advance!
          11-28-2024, 07:54 AM
        • tony359
          GTX480 short/vCore issue
          by tony359
          I have a weird issue with a GTX480 I am repairing for fun.
          Originally it would crash Windows when drivers were being installed. I checked with MATS and found a faulty RAM IC. I replaced it, MATS is happy but still the installation fails to install the driver - but no more BSOD.
          While testing I found something weird.
          What I think is the VCORE, is completely shorted. I read 0.4 Ohm to ground. I'm aware that low resistance is normal around a GPU but I don't think 0.4 is ok?
          If I check the inductors and all the mosfets,...
          04-24-2023, 03:15 PM
        • taxxin
          Zotac gtx-750ti 2gb vcore short
          by taxxin
          Dear Members,
          I would like some of you to share your experience with Vcore shorts to determine whether or not this card is salvageable.
          We have a 750ti here with a vcore short, it does not have an external atx power connected on this model so i can only assume that it is a 75w max from the pcie slot only.
          On the 12v rail there is a dead short, almost 0 ohms, i voltage injected it to confirm and yes whatever voltage you put into it is what is being directly fed to the GPU.
          Do you think that this GPU could still be operational if i repair...
          08-13-2021, 08:24 AM
        • Stephen
          MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
          by Stephen
          I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
          02-06-2025, 12:03 PM
