2Wire psu BT 2700HGV router
  • Sylvester
    • Nov 2006
    • 67
    Router is a rebadged 2wire, no lights on hub, psu has faint squealing from it when plugged into router, DMM shows 5.1v but no idea what happens when plugged into router.
    Opened psu case and saw 3 bulging 1000v 16v rifeking caps, so decided to change them but ran into a problem, I had 20mm x 8mm caps but they are too tall by a few mm and the pins wouldn't go through the small pcb holes 1.2mm?
    So I'll need to find some caps that'll fit, anyone had these psu's fail?[/URL][/IMG]
    [/URL][/IMG]
    [/URL][/IMG]
    [/URL][/IMG]
    [/URL][/IMG]
  • PeteS in CA
    • Aug 2005
    • 3579
    • USA, Unsure of Planet
    Re: 2Wire psu BT 2700HGV router
    Actually, what's difficult with that part is the 8mm diameter. With Nichicon, the only low impedance series that has a 1000uF, 16V part in 8mm x 20mm is the new HW series. That looks like a good series, but it is new and availability may not be good. IF you can make 10mm x 20mm fit, you've got lots of options with Nichicon - the HE, HV, PA and PW series, and possibly the HD series, have 1000uF, 16V part in a 10mm x 20mm case.
    PeteS in CA
    • Sylvester
      • Nov 2006
      • 67
      I've got panasonic FR series 8x20mm but as you'll see from the photo they are taller than the originals, not a lot of space for them, as mentioned, I'll need to widen the holes for the panasonics to fit. So far haven't found a 18mm or so tall 8mm cap.
      [/URL][/IMG]
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        You can use 10v and even 6.3v caps in that since it's a 5v supply. This should open up more options.
        A working TV? How boring!
        • Sylvester
          • Nov 2006
          • 67
          I can't believe someone has over specced the caps on this psu, or is it the originals were so far out of spec!
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            They likely just had a few thousand of them lying around and thought they'd put them to some use. This kind of thing is common in routers and switches, i see 16v caps often on rails that run at 3.3v or lower... and yes i see them failed.
            Some people say that higher voltage caps last longer in a given application, sure, if they're good quality to begin with. Higher voltage crap caps are still gonna fail because they're just a different kind of crap.
            • Sylvester
              • Nov 2006
              • 67
              I've got some 1000uF 10v panasonic FM's which should arrive tomorrow, 16mm tall
                I fixed a lot of these, some use 1000uf 10V, some use 1000uf 16V. I use 10V PANASONIC FM series.
                http://s807.photobucket.com/user/bud...?sort=3&page=1
                • jetadm123
                  • 2169
                  Actually, in your first post, last photo, the heatsink on the right appears to be taller than the original caps. If the new FR's are the same height as the heatsink you might be alright. Dry fit a new cap and see if the plastic cover clears it.
                  • Sylvester
                    • Nov 2006
                    • 67
                    I'll have another look at the FR's but think they stick a little above the heatsink, failing that its the FM's.
                    • LLLlllou
                      • May 2011
                      • 201
                      Either will be more than adequate and should last a couple decades, at least.
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        last one i fixed i used 1000@6.3 mbz as thats what i had in my road kit.
                        this dsl modem will be in the recycle bin before those give up.
                        • Sylvester
                          • Nov 2006
                          • 67
                          Update on this,
                          finally fitted 1000uF 10v FR's, psu is now working, router is now alive. The 16v sat just above the heatsink and would be in contact with the case.
                          What do you guys stick the case back together with, I thought some solvent glue would stick them together but it doesn't melt the plastic?
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            I always use superglue/loctite.
                              I use PVC pipe glue, super glue gel works well too.
                              • Sylvester
                                • Nov 2006
                                • 67
                                PVC/solvent glue doesn't work on this cover, I'll try superglue, plastic can be a problem.
                                • SeanB
                                  • Jun 2013
                                  • 41
                                  • South Africa
                                  I have been using for the last few cases a Pratley product called Wonder bond, a flexible 2 part epoxy. 2 part rsin and hardener available in white and black, which adheres well to almost any plastic after you degrease it with a solvent, and fills gaps well. Use a small spatula ( cut a piece of plastic card to mix and apply it with) to mix it and apply it. Small beads from the tubes and hold the case together with a clamp or some PVC tape while it cures for 24 hours and you have a like new join. Can be opened for rework but does well in filling gaps and such.
                                  • Sylvester
                                    • Nov 2006
                                    • 67
                                    I've used a 2 part loctite epoxy before to repair difficult plastic, grey when mixed, just find it messy to use, also tried another loctite product which was an activator brushed onto plastic before using superglue but it didn't seem to be any better than using superglue on its own
                                    • double_DD
                                      Why does my ISP router hate my "homemade" power supply??
                                      by double_DD
                                      It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                                      So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                                      For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                                      07-12-2025, 03:09 AM
                                    • shadow666
                                      Router Xiaomi M4A Gigabit
                                      by shadow666
                                      hello
                                      i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
                                      Mi Router 4A Gigabit Edition
                                      ROM CHIP is 16 MB
                                      i attached picture of motherboard​...
                                      11-30-2024, 03:49 PM
                                    • EasyGoing1
                                      UPNP, "Standards" and hardware that implements it
                                      by EasyGoing1
                                      I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
                                      One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
                                      So I decided to implement UPNP...
                                      07-16-2022, 07:12 PM
                                    • hinisa
                                      Xiaomi router freezes at boot after re-capping
                                      by hinisa
                                      I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                      When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                      After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                      Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                      07-08-2023, 05:58 AM
                                    • spleenharvester
                                      Synology MR2200ac mesh router, UART connection - login details?
                                      by spleenharvester
                                      This particular unit powers up, LEDs behave normally, but broadcasts no SSID, will not mesh with any other routers. Plugging in an ethernet cable from a Windows laptop results in "unidentified network" with an autoconfigured IP address and no response to pinging 192.168.1.1.
                                      I was able to log into serial/UART by connecting the 6-pin header to the GPIO on a Raspberry Pi Zero W (GND to GND, TxD to RxD, RxD to TxD, no connection between +3.3V as it is supplied on both sides) using Minicom, command:
                                      Code:
                                      sudo minicom --baudrate 115200 --device /dev/ttyS0
                                      09-02-2024, 01:19 PM
