Honli 480w PSU?.. yeah sure it is!
  • tazwegion
    • Jun 2006
    • 444
    I recently collected enough components to build yet another A64 PC, the only items retained were the PSU & case (offerings from Honli), after sorting out a dud DDR stick the system has run happily till yesterday when it began shutting down (of it's own accord)
    System Specifications
    Athlon64 3000+ s754
    Asus K8V/X-SE
    512Mb Transcend DDR-333 (limited manually in BIOS)
    Geforce4 Ti4200 64Mb
    LG CD/RW
    Generic 40x CD-rom
    80Gb IDE
    Realtek 10/100 NIC
    4 x USB expansion card
    Now to get it to attempt a power up, I needed to pull the AC mains cord out & reattach, powering up has really been a hit 'n' miss affair, with the BIOS hardware monitoring feature indicating a 11.985 ~ 12.305v fluctuating variance, with all other voltages remaining within 10% -/+ of tolerance, my trusty UNI-T multimeter is showing a variance but only of 12.06 ~ 12.32v measured @ the P4 motherboard connector.
    So far the symptoms seem to indicate poor capacitance somewhere and as the motherboard is a brand-spanking-new Asus K8V/X - SE populated with what appear to be Panasonics, Rubycons & KZG caps... I'm leaning towards this being a PSU issue (despite the apparent perfect [see below] appearance of the caps )
    Additionally, are those input capacitors (2 x KAC 250v 330uF) enough for a supposed 480w PSU? even the 'sinks' look a little light on in the mass dept. especially when compared to either my 430w Antec or 550w Codegen PSU's, would replacing them with my spare pair of Rubycons @ 250v 470uF have any real world benefit?
    Any feedback would be appreciated, I know virtually zip about this PSU's specifications let alone whether it has any PFC componentry, I'm in a little over my head when it comes to PSU design/function/layout though I can identify most of the components
    Thanks in advance!
    Viva LA Retro!
  • Rainbow
    • Aug 2005
    • 1375
    Re: Honli 480w PSU?.. yeah sure it is!
    It's crap. 250W PSUs use 330uF caps. Better 300W PSUs use 680uF... This is no way 480W.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      its a steaming pile.
      no way in hell it will hold up at it 480w "rating"
      • starfury1
        • May 2006
        • 1256
        well two hi recommendations there dump it LOL
        Yeah I had an old supply that would not fire up unless I unplugged it from the mains. (and left it for a few minutes)
        Think from memory it turned out to be a 1K resistor or a dry joint on it ...don't ask me where or what it was for I don't have a clue
        (Cant even recall what the supply was)
        Anyway a noob guess would be startup circuit, some how some way and most probably
        something that hangs off the constant +V thats suppose to be low or high when soft powered off but it dosen't happen.
        only gets to that state with a total discharge of the unit.
        Anyway sure someone here knows these unit and most likely components to check replace
        BTW do you know the controller chip?
        yeah caps....Humm well from my way NOT Expert opinion I cant see why not if you really want to put the rubys in
        but as has been pointed out here the bridge rectifier or diodes used will be under more current stress, as in higher peak current as the caps charge
        it is after all just an anolgue psu at the front mains end...
        (yeah ok a bit more to it now days)
        So you might want to check the diode specs,
        In short just a slightly bigger bucket for the psu to pull from which itsn't such a bad idea...I think anyway
        I would be looking for possible dry joints, I would check all the caps/replace around the chip too
        Resistors do fail or go high and even if they look ok
        From your pics it looks to be the standard type el cheapo that they throw half the components away with but not the expert on this
        Maybe check Pete S and the others FAQ's on it
        This link although a bit older psu may give you some ideas
        here
        Anyway sure some of the more experienced will give you better info
        Cheers mate...... not of much help I know
        Looks like its a TL494 controller chip but hard to tell
        You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
        • tazwegion
          • Jun 2006
          • 444
          Perhaps in a liquid nitrogen atmosphere?
          Yes I agree it's a steaming pile of processed foodstuff! but will upgrading the twin input caps increase performance, reliability, voltage stability etc? currently it's holding steady on 12.31v @ idle & 12.13v @ 100% load
          I replaced the 1000uF KAC's with some SamXon 1200uF 10v's & a panasonic 1200uF 16v I had lying around... actually I killed one of the panny's as I was domestically distracted briefly, installing it reversed to it's polarity so during the power up test it went BOOM! (see pic below)
          Stuff this...
          During bench testing the PC rebooted... so in went the (formerly recapped) Antec TruePower380w... the difference was immediately obvious, 12.07v idle ~ 12.04v 100% load!
          Back to running Prime95!
          Viva LA Retro!
          • gonzo0815
            • Feb 2006
            • 1600
            If a PSu has Sb power up problems, from my experience the 1000uF KAC's if there are the first i replace.
            In many cases, this fixed all the problems. (but anyway, i usuak´lly changed both KAC).
            My theory is, that the Topswitch will have problems to regulate it`s output voltage, thus it permanently keeps traped in an power on off loop (powering on, voltage to high or other problems due to to high ESR of first pi filter cap, shuting down and again).
            Most PSu take the Vdd for the SMPS controler IC from the 5v Sb line. Thus the psu won`t start up.
            Those KAC caps are very common in many psu, not only from the grey market vendors (e.g. Seasonic OEM SS300Fs -SS400FS, LC-Power nearly all series, etc.).
            • linuxguru
              • Apr 2005
              • 1564
              If it's an EI-33 main transformer, it's not likely to be over 150W-180W max. - this unit is similar to a Deer or Powmax variant.
              You can probably use it in a non-critical P1/P2 class machine after upgrading all the large secondary caps. The primary caps don't usually fail - there's not too much point in upgrading them, and it sometimes makes things worse, because the power factor worsens with a large capacitive load and higher peak/inrush currents may trigger overload shutdown on a UPS.
              • tazwegion
                • Jun 2006
                • 444
                Thanks for all the technical information, but I have yet another question now... sitting out of the case (powered up) it hovers on 12.38v or there abouts, but once I fitted it into my RAID0 server the 12v line exceeded 13.0v at times, what gives with that? is it because I used 1200uF capacitors in place of the original 1000uF units? or because the previous system power requirements dragged the guts out of it?
                I think I'll just 'gut' this PSU for it's fan & connectors (reclaiming my capacitors too!) 13.0v is just a little too high for my liking
                BTW I believe I found the system fault too, the AGP port required some tweaking in the BIOS which has resulted in over 4.5 hours of Prime95 CPU torture testing error/warning free without reboots or freezes
                Viva LA Retro!
                • linuxguru
                  • Apr 2005
                  • 1564
                  Probably means that the +5v is overloaded, dropping it to (say) +4.5v. The regulation loop will compensate by increasing the +12v - the cross-regulation is usually not very good on these units.
                  The other possibility is that the rectifier on +12v is on its way out - these are usually a pair of FR302 3A units, but run at higher currents (and forward drops) than the rated maximum. One or both may eventually short out on high loads.
                  • Sparky
                    High voltage
                    • Jan 2007
                    • 234
                    Honestly I wouldn't even keep messing with that PSU. I'd gut it for the fan and caps, then ditch the rest. It doesn't seem worth the effort to do anything else.
                    • Rainbow
                      • Aug 2005
                      • 1375
                      Caps? You don't want to use caps like that to fix anything else. Sell it very cheap.
                      • Sparky
                        High voltage
                        • Jan 2007
                        • 234
                        Well he put some SamXon and panasonic caps in it to try and fix it, so by pulling caps I meant retrieving those.
                        • tazwegion
                          • Jun 2006
                          • 444
                          Yeah, that's what I'll end up doing tonight when it cools down (37c @ the moment) the Pannys & Samxons are too good to waste! dunno' about the 1000uF 10v KMEs AFAIK they're just GP caps
                          Thanks linuxguru that makes the whole output mess a little clearer
                          Sparky... I note in your sig that the love affair with Antec PSUs is over, other than the installed Fuhjyyus their design & componentry is good, once you've recapped them they aren't a bad little PSU @ all IMHO
                          Fuhjyyu
                          Viva LA Retro!
                          • starfury1
                            • May 2006
                            • 1256
                            Well Taz some good info for U...better then Mine
                            should mention if you read Taz's post about himself, else where on these forums.
                            He does try to recycle rather then add to land fill good one Tazzie
                            so guess thats why he is having a bash to fix it.
                            Does help the learning curve too.
                            I've learned a bit more from the posts too...
                            Did think there was some possible "let the buyer beware" with using the ruby's but didn't know, recall what the possible down sides where from previous posts on that.
                            I thought Id mention it but didn't...thanks all
                            (probably erased it when editing post doh!)
                            Do Capacitors go to Silicon Heaven ?
                            or is there a separate heaven for
                            passive components
                            Cheers
                            • Sparky
                              High voltage
                              • Jan 2007
                              • 234
                              Fuhjyyu
                              Yeah they are well built units, couldn't ask for more tightly regulated voltage and low ripple, I just don't understand why they put crap caps in there with an otherwise well-designed unit
                              A couple days after ordering a new PSU I realized I should have just gotten replacement caps and just fixed it (would have been much cheaper too!) but too late for that. I may still recap it and either sell it that way or keep as a spare (if money allows for that)
                              starfury1, recycling is a good thing, but I think sometimes there is only so much you can do until things just have only one place to go I would have tried too, but he's done that and it still acts up so at that point is when I would say forget it. Just ask my dad, I horded all sorts of stuff for the longest time in several boxes full because I hate to throw anything out
                              • kc8adu
                                • Nov 2003
                                • 8832
                                • U.S.A!
                                this post brought to you by many recycled and rebuilt parts.
                                most were free.
                                most costly part is the $30 dvd writer.
                                os is a freebie too.
                                <$50 in a server grade box=priceless.
                                • starfury1
                                  • May 2006
                                  • 1256
                                  Sparky
                                  just thought Id add that for those passing that may be wondering why Taz would bother
                                  But true, at some point you just got to say its not worth the time and effort
                                  (except maybe if you are just trying to lean a little more or would just like the satisfaction of saying "there I fixed you")
                                  Like you, I too have more junk then I care to think about
                                  "One of these days something off that pcb will be useful
                                  (I say to myself)!"
                                  and you know which day that will be?
                                  The day after I throw it out
                                  Cheers mate, all
                                  • tazwegion
                                    • Jun 2006
                                    • 444
                                    Yeah, I think that's more like it...
                                    * WWE pose/stance *
                                    "all fixed now, who wants some?"
                                    BTW just as a final note on the original PC reboot/freeze issue (drama)... it turned out to be a less-than-perfect AGP interface, stepping down to AGP x4 fixed the issue, pretty darn sad when you consider the POS Asus board is brand new & populated with quality capacitors!
                                    Viva LA Retro!
                                    • AJ847.63e
                                      Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                                      by AJ847.63e
                                      Hi Folks,
                                      Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                                      I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                                      The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                                      05-06-2025, 10:37 PM
                                    • bauto601
                                      KDM 480W PSU upgrade succes! (opinions?)
                                      by bauto601
                                      Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                      A "nice" YoungYear unit? - Badcaps
                                      The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                      12-26-2023, 03:05 PM
                                    • RukyCon
                                      Modding Two PSUs to Output 12V
                                      by RukyCon
                                      Hello again, this might be a bit of a far-fetched question, but is it possible to modify a 36v and a 48v power supplies to output 12v? Both power supplies appear to use the same topology, they both also have a dedicated 12v winding wired to the control chips, meaning that as soon as i change it so the main output is 12v, then the dedicated windings will not be able to output 12v, meaning it will not start up. However, if i were to then take the main output and tie it to where the dedicated 12v output would go, then it should be able to run fine?
                                      Anyway here is a quick overview of...
                                      02-22-2021, 01:33 AM
                                      Corsair CX750M [Model 75-002019] - burned output toroid inductor
                                      by momaka
                                      Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                                      So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                                      09-19-2021, 08:44 PM
                                      KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                                      by momaka
                                      For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                                      http://www.rmac.kingwin.com/products.../abt_650MM.asp
                                      I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                                      What mostly drew me into buying it is its 2x PCI-E power connectors...
                                      03-29-2022, 11:34 PM
