2 power supplies killed by lightning
  • goodpsusearch
    • Oct 2009
    • 2848
    • Greece
    The first psu is a variable voltage power supply (3V, 4.5V, 5V, 6V, 7.5V, 9V, 12V).
    The bridge rectifier consisted of 4 smd 1A diodes "M7" and 2 of them failed shorted. Then, the 1A 250V fuse blew. I replaced the diodes and the fuse and the psu is now working. Photos attached:
  • goodpsusearch
    • Oct 2009
    • 2848
    • Greece
    Re: 2 power supplies killed by lightning
    The second power supply is a noname 12V 1.0A unit.
    Again, 2 of the 4x 1A diodes are shorted, the glass type fuse blew in a catastrophic way and a Y cap also blew. I already replaced the diodes and the fuse, but I need some input about the blue cap replacement.
    Its values can be only partially read and I don't know what caps are considered to be compatible with the blown one. I attach a photo of the cap. Any help would be welcome
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      looks like the cap wasnt even safety rated..... when you replace it make sure the new one is.
      Follow the white rabbit.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8672
        Chances are, the cap had "222 1KV" printed on it, a 0.0022 microfarad capacitor. The other possible values are not common and therefore more expensive (which this can't be). But yes, make sure it's Y-rated, you don't want it to fail as a short (is it shorted now? If it is, that's what you DON'T want happen...)
        • goodpsusearch
          • Oct 2009
          • 2848
          • Greece
          I thought that the color stated if the cap was Y-rated or just ceramic.
          Blue color = Y cap
          Any other color= ceramic cap
          Was I wrong?
          Edit: It failed open.
            It can be any color, it should have X/Y printed on the body. That cap is used to reduce the noise to pass FCC test. The value will be every low since you do want too much AC leakage current, .001~.0047 will be fine, the unit will still function without this cap.
            For example:
            http://www.mouser.com/ProductDetail/...y0Q2bAiJDDg%3d
            • PeteS in CA
              • Aug 2005
              • 3578
              • USA, Unsure of Planet
              Cera-Mite Y caps (and X caps, too) are or have been orange. Color means approximately nothing. Look for the "X" or "Y", and for the safety agency marks. Like eccrrOr said, that blown cap was 2200pF, probable 1KV (you can see the second capacitance digit and the multiplier digit, and you can see the "KV" from the voltage rating). Definitely get a real Y cap!
              PeteS in CA
              • goodpsusearch
                • Oct 2009
                • 2848
                • Greece
                I fixed it!
                I used a cap from a dead computer power supply, the cap was on the same position, across the main transformer.
                Thank you for your help!
                • Kiriakos GR
                  Banned
                  • May 2012
                  • 940
                  • Greece
                  I used to bring in life many fax machine which was failing apart due HV voltage in the telephone lines due lightning (collected by the telephony pols).
                  Yes Mains voltage is just one of the doors which the lightning can enter in your home.
                  The other is the telephone line.
                    master hoarder
                    • May 2008
                    • 12164
                    • Bulgaria
                    Now that is a proper Y-rated safety cap!
                    The adjustable power adapter looks nice. Can be pretty handy for testing breadboard projects that may require some odd voltage.
                    • caspian
                      What Zener Diodes on a Linear Power Supply
                      by caspian
                      Dear members,
                      I have a linear variable power supply with unknown brand name that I used for voltage injection.
                      Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                      In addition, I discovered that its zener diodes are defective.
                      I can replace the burned transistors.
                      But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                      Therefore, I cannot replace the zener diodes.
                      I do not want to test the zener diodes in a test circuit to discover their model or value.
                      no schematics are available...
                      05-26-2025, 12:38 PM
                    • corrize
                      A funny fuse story – Lumix LX100 II
                      by corrize
                      Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                      I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                      The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                      There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                      And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                      10-19-2023, 09:58 AM
                    • SluggerB
                      Panasonic TH-50PX80 killed by lightning strike, help me save her!
                      by SluggerB
                      Yes it's a 17 year old Panasonic plasma!
                      I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
                      06-04-2025, 07:02 PM
                    • jesterace
                      Samsung UE46ES8000 Blown fuse but no other signs of short
                      by jesterace
                      Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                      09-11-2024, 03:14 PM
                    • jshhh
                      Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                      by jshhh
                      Hi guys,
                      I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                      How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                      Anybody know how to remove this type of fuse?
                      (The fuse is toward the bottom of the image labeled F2)...
                      06-17-2025, 01:35 AM
