Powmax Demon 480w Power Supply
  • pdqwik
    • Jul 2013
    • 10
    • united states
    Greetings all,
    This power supply went up on me several years ago. I saved it to try to repair it for the experience and now I can use it for a machine that has a bad power supply. I recently tested with a Rosewill RTK-PST and it tested bad. I took the cover off and didn't really see anything wrong until I removed the screws and peeked under the board. There was some dust and a small piece of card board. Over by the primary caps there was some obvious electrolyte leakage. I cleaned it up and retested and it passed this time. I would like to replace the primary caps 470uf 200volt and 2 small caps in the front 470uf 10volt. Should I go with original specs or is there something better?
    or am I wasting my time? TIA
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Powmax Demon 480w Power Supply
    Powmax Demon? Sounds so hilarious!
    Powmax psu's are the worst ever, I sugguest you get a different one and trash this one. There is a reason why it is so cheap ... poor quality, and it will likely destroy the whole computer when it fails.
    Muh-soggy-knee
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      JEE caps are probably the worst brand alongside Rulycon. I recently got an old CompUSA PSU that was made in 2002 and had never been used and one of the JEE caps was bulging. There have also been some old PSU's I've seen with JEE caps and about 90% of them were bulging or out of spec.
      Regardless, Powmax makes junk and normally I would say improve it (Even if it was an Allied, etc.) but I think it would be worth getting a different PSU. It might have a couple parts worth scavenging, like a 30A schottky on the 5V rail and (if you're lucky) PI coils on the output. Can you post some more pictures of it, from above?
      • pdqwik
        • Jul 2013
        • 10
        • united states
        Yes I'll be all to happy to post some more pics tomorrow. Didn't understand everything you said but willing to learn.
        Apparently the ps stopped working because the electrolyte caused a short on the board after a little cleaning it tested good. I was hoping to put this back in service because it's the only extra bad one I have with sata. I thought some new caps might make it spiffy again since they are all obviously leaking.
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Unfortunately the ripple coming out of that thing is most likely severely shortening the life of the connected hardware. I would gladly send you some molex to SATA converters, I probably have over 100 of them sitting around.
          It also looks like that (can't tell from the angle) switching transistor or 5VSB transistor on the primary heatsink (to the left of the left JEE cap in the first picture) is really discolored or burned, perhaps that's why it isn't working as well as the failed caps, it's probably a wimpy 13007 or 3A standby transistor
          • larrymoencurly
            • Oct 2004
            • 960
            JonnyGuru.com once tested a 500-550W Powmax Assassin that looks sort of like that Demon. The first blew out at 277W, and the next two either blew out or shut down at about the same power level.
            • DJduck
              • Dec 2012
              • 229
              • Estonia
              Everybody here is right. There is no reason to waste money on this piece of shit.
              I can put text here?!
              • pdqwik
                • Jul 2013
                • 10
                • united states
                Yes as a matter of fact I did inspect that not knowing what it was. Figured it was heat related but that it was just the clip holding it to the heat sink. Good eye P4.
                • cheapie
                  null
                  • Jul 2010
                  • 849
                  Just chop some SATA connectors off of it and splice them onto a good supply. They fit nicely in place of a Molex (black to black, red to red, yellow to yellow). You don't even need to connect the orange wire, as only a certain set of 1.8" SSDs are even known to use it. I did this once before with an old Astec. I had a Dynex that was on its way out, so I put the SATA and ATX12V connectors from it onto the Astec. I don't think it liked the crossload towards 12V (it was an old 5V-heavy unit from 1999, and may have even been overloaded on the 12V), but it worked until I was able to get a new Seasonic.
                  For reference, if you want to do any connector modding, here are the different wire colors:
                  Yellow - +12V (on multi-rail supplies, some of these may have colored stripes to indicate rail assignment)
                  Red - +5V
                  Orange - +3.3V
                  Brown (If present) - +3.3V sense (should be connected to an orange wire, used to sense voltage at the ATX connector)
                  Blue - -12V
                  White (no longer part of the ATX spec, but some older supplies still have it) - -5V
                  Purple - +5VSB "standby" (has 5V all the time, even when the computer is off)
                  Green - /PS_ON (connect to ground to turn supply on)
                  Gray - PWR_OK (indicates supply has finished starting and voltages should be stable)
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    only service that thing is good for is a rifle target.
                    even the sata drive power leads are likely subpar.
                    you might get away with it if you dont load it heavy with 10k drives,ect.
                    some of those leads are 28ga.if it were mine...
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      Another one of those divided-by-2 PSUs!
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Or sledgehammer bait...
                        sigpic
                        (Insert witty quote here)
                        • c_hegge
                          • Sep 2009
                          • 5219
                          Or tossing in a fire and watching the caps explode
                          • lti
                            • May 2011
                            • 2548
                            He tested the Demon too.
                            http://www.slcentral.com/powmax-demon-580w-psu/
                            • pdqwik
                              • Jul 2013
                              • 10
                              • united states
                              Here's some more pictures Pentium4
                              You all have ragged my power supply so hard I'm almost afraid to try to do anything with it. I don't believe it ever harmed any equipment. I had it running an Asus A8V which I still have in my spare room doing web surfing and basic printer duties. I replaced the Demon with an Antec BP500U and it just keeps on chugging. So I'm still looking for advise as to what to change out. I know the 4 capacitors are bad.
                              • Pentium4
                                CapXon Be Gone
                                • Sep 2011
                                • 3741
                                Your computer will be much happier with the Antec. I was expecting a little worse...but it still isn't good. If you plan on using it in a low end system, I would replace 100% of the JEE caps, even the small ones as they dry out. The heat sinks are actually decent for a Leadman... I would also remove the minimum load resistors on the output rails. It probably has a crappy Powmax fan which are annoyingly loud and have insufficient oil in the bearing, I would replace that. You can use any old 80mm fan.
                                I'm also curious to know the specs of the silicon, aka all the parts connected to the 2 big heat sinks, you would want to replace any fast recovery rectifiers with schottky rectifiers. I have had good look doing this in old PSU's.
                                Also recommend replacing those fake Y caps with certified Y caps, they look like regular ceramic discs. The ones I am talking about are located at the bottom right of the last picture next to the Line and Neutral wires
                                All that being said, I wouldn't use it in a computer that needs more than 150W if you want it to be in spec and not blow up and start a fire
                                • pdqwik
                                  • Jul 2013
                                  • 10
                                  • united states
                                  Errr, I'm going to have to do some reading I see. Shottky's look the same as fast recovery rectifiers to me. Wiki calls them both diodes and I have no idea what a real y cap looks like let alone a fake one. This is going to be good fun. Thanks for the info P4 and everyone else for your critique I knew it was a piece of shite and appreciate the humor.
                                  • Pentium4
                                    CapXon Be Gone
                                    • Sep 2011
                                    • 3741
                                    It is indeed a crappy power supply but for the sake of learning, experimenting, and practicing on, it is perfect
                                    • pdqwik
                                      • Jul 2013
                                      • 10
                                      • united states
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        • Romania
                                        Real Y caps are blue and have safety markings on them. The reason this is stressed is because safety certified Y caps never fail short. Cheap ceramics almost always fail short when they do fail - which could create a potentially lethal situation as they are connected between neutral and earth, live and earth. If the computer you plugged the outlet in isn't earthed properly, the cap connecting to the live fails short, and you happen to touch the case, you'll be touching the live line of your mains outlet. That'll hurt.
                                        I don't recommend removing the minimum load resistors, they are there for a reason. You may, however, replace them with higher wattage ones with flying leads (there won't be room for bigger ones), so that they don't get that crazy hot and don't harm the caps.
                                        A working TV? How boring!
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                        • CMCM
                                          Russound CA4 Power Supply Repair
                                          by CMCM
                                          Hello Everybody,
                                          Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                          Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                          The outputs marked 12v and 20v are all measuring only 1v.
                                          The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                          The capacitors physically look clean (no bludgesor leaks) and...
                                          07-03-2025, 01:12 PM
