This 300W PS is full of G-Luxon. None show any problems (after about 3 years) I am somewaht surprised with the cap values. None are greater than 1000u. Most other power supplies have 2200u even 3300u. I am thinking of swapping the caps out and increasing the 5V rail caps to 2200u. Anybody had experience with this PS model?
L&C B300ATX with G-Luxon
160Gb WD SATAII Server grade
Nvidia 8500GT 256Mb
Samsung 18x DVD writer
33 way card reader
Windows XP Pro SP3
17" Benq FP737s LCD monitor
HP Officejet Pro K5300 with refillable tanksTags: None -
Re: L&C B300ATX with G-Luxon
That's one of the over-rated Deer/L&C models - about 180W is the right spec for it. They have multiple issues, including under-rated rectifiers, caps, missing RFI components, marginal +5Vsb, etc. It can be upgraded, but with significant investment of time. -
Thanks Linuxguru. Well it looks like increasing the capacitance value is a step in the right direction. It is only powering a Duron 1300 system with on board graphics. An ECS Mb with OST caps in every part of the VRM (OST ugh!!!!). Amazing the whole rig has survived three years. Probably because it a very low duty cycle as a home computer.Gigabyte EP45-DS3L Ultra Reliable (Power saver)
Nvidia 8500GT 256Mb
33 way card reader
Windows XP Pro SP3
HP Officejet Pro K5300 with refillable tanksComment
You really should not be using those powersupplies, they are IMO not safe
There are multiple threads here about them and why not to use them...
Buy a used Delta or something on eBay, that system should be fine with something in the 230-250w range"The one who says it cannot be done should never interrupt the one who is doing it."Comment
I would rather use a PSU found on the sidewalk or in a dumpster, even if it was rated for just 200-250W, because major brand computers tend to come with very high quality PSUs, except for maybe the Bestecs found in some HPs. But don't plug in a Dell PSU if it has fewer than three orange wires on its 20-pin connector or it may cause your computer to go BOOM!Comment
even the cheap cases are coming with half-decent looking 430w these days.Comment
eMachines, too. Nasty little buggers, but not the worst.
I believe that as of 2000 or 2001, they began using standard ATX wiring. Before that, it'd plug in, but the wires were wrong. Good reminder though, something to keep in mind.You know there's something wrong when you open up a PSU and are glad to find Teapos.
Why I don't buy cheap cases!
I found that my Dell Dimension 8200 has a standard ATX PSU (Dell-branded Hipro 250W), and it's circa 2001. (I initially thought it had a LiteOn
) I discovered this when I was working on my PSU: I had an eMachines/Trigem Lomita board and I was going to test the unit. Absentmindedly I plugged my Dell Hipro into it... and it worked fine! :gasp:
I guess I won't need to buy those "Dell Compatible" PSUs after all.
The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
I'll probably be the only person going to SteamOS once it gets out of beta (ha ha.)Comment
Hold up on that last post... I just read somewhere that Dell has another proprietary trick up their sleeve - the case of the PSU itself. While it is an otherwise regular ATX PSU case, the cable input is on the left, and there's no room for a power switch. (Of course, that's what a hacksaw is for...
Damn Dells anyway...The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
by dqtechhere the link for schematic - https://www.badcaps.net/forum/troubl...-the-bios-chip
board number LA-F312P ....laptop charging but not increasing percentage...charge rate very low on BATMON ....i try use another battery also same result...but when i try this battery and adapter to another laptop (dell latitude 7300) its charging normally and charge rate goes to 19k-20k mW... -
I have a K4200 GPU in my Z440 running Windows 10. Some time around October 28th, my GPU experienced a fault. My windows system BSOD'd with DPC_WATCHDOG_VIOLATION and restarted. On restart, the GPU drivers were rejected from loading due to an Error 43. There was some artifacting going on in both Windows 10 and Windows 8. The strange thing is, the artifacting only shows up in the Windows ecosystem. When the system is in BIOS, there are no graphical anomalies. I looked in the event viewer for some clues as to what was going on, and I noticed something new. The system was notifying that...11-06-2025, 07:40 PM
by dqtechearly problem this laptop is short 19v...after replace short capacitor (PC6005), this laptop does running okay...but the problem is battery percentage not increase...charging orange light is normal when insert adapter...
i have try replace 2pcs new battery but also same result...on status it saying "charging" but percentage not increase...this laptop also running okay with only battery (got 27% left)....
schematic/boardview link - https://www.badcaps.net/forum/troubl...ets-and-mobile... -
by Anooc7Hi,
This particular TV (LC-42LB261u) flickers more as I increase the backlight from ~10% onwards. Please find the attachment. Is it the backlight leds? I changed the 3 capacitors shown in figure, but still the issue remains the same. When it blinks I can hear a buzzing noice from the big o/p transformer. I checked the two led lines with backlight testet and both showing ~ 25.xx volts . Any inputs?
Thanks... -
Good evening all
I have a bit of a doozie, I've looked all over the internet but cannot find a similar case as mine, and am starting to get frustrated.
Link to video showing my problem: https://www.youtube.com/watch?v=e4rFDu2U8_M (pardon the camera work
So the main problem I am experiencing is horizontal green and red lines spaced out equally.
Secondly ( as seen at 0:48 a bit) is the ever increasing amount of white on the left of the screen with a vertical bar or two. There is a portion of the screen at the bottom that doesn't have... - Loading...
