fsp 700w blows fuse when powered on
  • techman2012
    • Aug 2012
    • 23
    • ph
    hi can anyone help me out on which part i should check on what is shorted out or broken?
    already replaced the fuse for the 1st time and
    1. power on switch on psu socket = fuse ok
    2. once psu is switched on via the power on 24 pin the fuse blows
    here are some pics taken
    what else do i need to check and how to diagnose
    thanks in advance for your help
  • mariushm
    • May 2011
    • 3799
    Re: fsp 700w blows fuse when powered on
    Post the images here as attachments. Click on Go Advanced and do it if you can no longer edit your post.
    Anyway, the pictures are probably too low quality to figure out anything.
    pics large size : http://img23.*************/img23/6877/img051lp.jpg and http://img341.*************/img341/489/img046rd.jpg
    check the bridge rectifier - it's at the end of the long heatsink. Put the multimeter on diode check and test it (with power supply unplugged)
    This video explains how if you don't know : http://www.youtube.com/watch?v=dqkT6hF0O3E
    You don't have to remove it from the circuit. ps. actually you have two bridge rectifiers there, the ones marked with B. better desolder them both and test them outside the circuit.
    • techman2012
      • Aug 2012
      • 23
      • ph
      noted currently removing the bridge rectifier
      will post update in a while
      thanks for the reply
      • techman2012
        • Aug 2012
        • 23
        • ph
        both bridge rectifier are ok
        • techman2012
          • Aug 2012
          • 23
          • ph
          currently checking the igbt removed the igbt 20n60c3
          seems something is wrong which one is faulty here?
          dmm set to diode
          G C+lead E-neg lead
          no reading
          but if
          G C- E+
          i get a reading of 0.490v
          one of the igbt when on these test gives out 0.007v
          http://www.scribd.com/doc/49954768/20n60c3
          as for the testing i watched this one
          http://www.youtube.com/watch?v=AfV7gYChILc
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            From what I can see, 20N60C3 is a MOSFET not IGBT, so the reading of 0.490 V you get when you put the (-) probe on C and (+) on E (that's actually D and S not C and E since it's a MOSFET) is normal.
            I'm guessing this power supply is either a single or double forward design so check the DRC (diode, resistor, capacitor) snubber network. It's also possible that the high voltage bulk cap on the primary may be bad - there actually have been a few cases here on badcaps.net where people reported those CapXon high voltage caps failing.
            To avoid blowing more fuses testing the power supply, once trick you can do is to wire an incandescent light bulb in series with the live wire going to the PSU. A 60W one is a good start. However, if you do that, you cannot connect a very large load to the power supply (i.e. you can't have it connected to a computer). The largest load you can have is maybe an old hard drive you don't care much about or a bunch of fans. If the light bulb becomes fully lit when you try to power on the power supply, the problem is still there. In that case, do NOT keep the power supply turned on for more than a few seconds to avoid burning out other components.
            Also note that if the hard drive/fans use a lot of power, the light bulb may still remain somewhat lit. In that case, you can switch the light bulb to a higher wattage one. 100 to 150W should be plenty.
            • techman2012
              • Aug 2012
              • 23
              • ph
              sorry my bad the one differs from the two everywhere i put probe the dmm beeps which means like shorted like when i put my probe + to - and it beeps
              anyway ill try to find a 20n60c3 and replace the 3 of them to be on the safe side also will make that dim bulb tester
              also if i will replace the capxon main cap
              for ex:
              320uf 600v original
              can i replace it with
              400uf 600v
              or
              320uf 650v?
              also is it possible a main cap has problem thats why the mosfets got shorted out?
                What are the ratings on the cap? 330uF 450V?
                • c_hegge
                  • Sep 2009
                  • 5219
                  He said 320uF 600V. Using a 400uF and/or a 650V cap will be fine in an APFC circuit.
                  • techman2012
                    • Aug 2012
                    • 23
                    • ph
                    thanks c_hegge for the reply
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      Yeah, that one is probably bad then. Just in case though, take it out of the PSU and check it again to make sure something else isn't bad either.
                      for ex:
                      320uf 600v original
                      400uf 600v
                      or
                      320uf 650v?
                      Are you really sure the original is rated 600V? So far, I've only seen 400V and 450V rated ones.
                      • c_hegge
                        • Sep 2009
                        • 5219
                        A close up look at the picture suggests it's actually a 470uF 400v
                        • techman2012
                          • Aug 2012
                          • 23
                          • ph
                          @momaka already removed all the straight heatsink to test the other one seems to be like a diode is ok besides the 3 20n60c3
                          as for the main caps later i will check it out for the exact values.
                          thanks all for the reply
                          will comeback for the result/update
                          • techman2012
                            • Aug 2012
                            • 23
                            • ph
                            main cap is 470uf 400v
                            btw here is the pic of the blown fuse before
                            • techman2012
                              • Aug 2012
                              • 23
                              • ph
                              already replaced the 3 mosfets and the main cap
                              made the bulb tester and its still a short since it lights up brightly
                                When MOSFET shorted out, especially between Gate and Drain, that high voltage will go through Drain, Gate, and the output drive pin of the SMPS IC to ground which will damage the output drive circuits of the SMPS IC. The bridge is OK? If the output pin of the IC stuck high, it will keep the MOSFET on instead of swithcing on/off, that will cause the MOSFET to draw a lot of current due to low DC resistance of the transformer, but if it is switching at high frequency as it should then the Reactive resistance of the transformer winding will be high which will limit the current through the transformer winding as designed.
                                • kaboom
                                  "Oh, Grouchy!"
                                  • Jan 2011
                                  • 2507
                                  The three MOSFETs are strictly for the PFC-boost. There's some SMT stuff driving their gates on the back of the board.
                                  The FETs avalanche when the cap dries out- energy stored in an inductor cannot disappear instantly. The current attempts to continue and a huge voltage is developed. When the cap is good, the current merely charges the cap...
                                  "pokemon go... to hell!"
                                  EOL it...
                                  All style and no substance.
                                  guilty,guilty,guilty,guilty!
                                  guilty of being cheap-made!
                                  • techman2012
                                    • Aug 2012
                                    • 23
                                    • ph
                                    so what do i do now? what do i need to check/how? thanks
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      When you have been removing replacing components have you been careful to replace any nylon/non conductive washers or sleeves if there were any.
                                      • techman2012
                                        • Aug 2012
                                        • 23
                                        • ph
                                        yes im carefull when i removed and replaced the parts, there were no washer nor sleeves present.
                                        after the test i havent checked if the replaced main cap or three fets have failed or not. will check it soon. btw while im testing it earlier with the bulb test, at first the light is dim then when i short green to black for psuon, the bulb glows full also the fan doesnt spin and i dont get any 12v/5v/3.3v reading . though it has a sound like a cap that is to bulge. but i didnt see any cap that bulge
                                        • BlackScreen_22
                                          Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                                          by BlackScreen_22
                                          Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                                          Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                                          I had no problems connecting mosfets and capacitors,...
                                          08-27-2024, 12:46 PM
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
                                        • dimis7
                                          LG 37LS5600 blows main fuse
                                          by dimis7
                                          Need some advice to troubleshoot this TV.
                                          PSU blow the main fuse F100, 3.15A.
                                          I replace the fuse with another 3A (but not ceramic) and blows it again after few seconds when i plugged in to the wall, with nothing connected to PSU, just the power cord.
                                          I checked with DMM for dead sorts but didn't found any.
                                          Checked bridge rectifier and seems ok.
                                          Also check main filter cap with transistor / cap / esr tester (the usual cheap transistor testers from ebay) and found ok.
                                          PSU p/n is EAX64405901 (1.6)...
                                          10-28-2022, 05:15 AM
                                        • Michale32086
                                          LG 60LN5400 Blows TCON Fuse
                                          by Michale32086
                                          I could have sworn I posted about this before, but I can't seem to find the post..
                                          To whit..
                                          I have a 60LN5400 that came in.. Backlights work fine.. No display..
                                          Traced the problem to the TCON board.. Blown fuse..
                                          Replaced the fuse.. Blows again.. Replaced the fuse again... This time it fries the marked part on the Main Video board...
                                          Got a new Main Video Board.. Replaced the fuse on the TCON..
                                          The fuse is fine and the backlights come on fine if I don't have the cellophane connectors from the TCON to the...
                                          10-30-2019, 09:21 AM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
