older than time PSU for automotive test machine
  • scampo77
    • Dec 2010
    • 233
    i have a gas analyzer that measures hydrocarbons in tail pipe emmisions for cars."Sun DGA 1000" i cant buy a new one of these machines so i am really hoping i can fix this one. the info i can get off of the exterior are
    moretec
    mode: MPU-200PE
    NO. 96070532
    input 115 5A
    230 3A
    output
    +5v -5v +12v -12v
    i cant seem to find -5v and for the 12v all i can measure is 11v. i cant tell what voltage goes where because nothing is marked and i cant find a diagram anywhere. i checked the caps with a ESR meter and they all seem ok.
    any advice or diagrams would help me out a lot
  • rogfanther
    • Jul 2006
    • 458
    • Brazil
    Re: older than time PSU for automotive test machine
    Do you have any pictures of the inside ?
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      moretec
      mode: MPU-200PE
      NO. 96070532
      input 115 5A
      230 3A
      output
      +5v -5v +12v -12v
      sounds like your basic AT power supply.
      you have options if you want to replace it with a newer (still old if you like ) PSU.
      what you could do:
      option 1. find a GOOD AT psu and if the connectors are different, splice on the the connectors from the old unit. splice/short the on/off leads if your unit has no on/off switch to the psu.
      option 2. find an older ATX psu. make sure is a good unit. it has to be older since ATX revision 2 dropped the -5v requirement. splice connectors. connect your on/off between (or short) the green wire (pwr on) and a black (ground)
      either way if you want to replace, the standard colors that even the old unit may use are:
      yellow- +12v
      blue- -12v
      red- +5v
      white- -5v
      black- ground
      green (ATX only)- power on (short to ground to turn on unit)
      especially with the AT units, computer PSUs were used in a lot non-computer roles... arcade games come to mint (quarter eaters).
      some pictures may help (plugs used, not just guts). if it happens to use standard connectors, then it could be a simple drop in... otherwise, you either have to fix the old one or splice on plugs to a different PSU.
      EDIT-
      I looked uo the model... probably a modified AT or ATX psu, lots of A-power ish fakes claiming to be "refurbished" units with the same model no. you may be best to mod a better psu (delta/hipro for example) since the stock one looks to be junky quality.
      sigpic
      (Insert witty quote here)
      • scampo77
        • Dec 2010
        • 233
        the colours i have are
        orange .2v
        red 5.2v
        yellow 12.12v
        blue -10.8v
        if i do go looking for a power supply will it have a big AT or ATX on it to denote the -5v i need? because his power supply doesnt have one.
        i looked at old computers i have laying around here and non have the -5v.
        there are x4 TO-220 cases bolted to heat sinks. would a good first step be to pull and test these? since my caps "seem" to be ok?
        • kc8adu
          • Nov 2003
          • 8829
          • U.S.A!
          how about some pics.sounds like an at supply to me.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            sounds like an AT to me as well. orange is supossed to be 3.3 v, but 3.3 was not usually on AT supplies (if it was, it was an aux plug).
            since you might not have a -5v, i'd find a beefy (read: heavy and solid) ATX supply and rig a ground wire and the green pwr-on wire to the on/off switch sice only late and specialty AT units had the orange 3.3v line.
            sigpic
              master hoarder
              • May 2008
              • 12160
              If possible, please post some pictures of the inside and outside of the power supply as others have suggested - that way we know what we a dealing with. Most power supplies are basic enough to figure out without a diagram or schematic if you post good pictures.
              You could, but I think they are likely fine.
              Again, without pics, I can't tell you exactly what's what, but generally on PSUs of this vintage:
              there are 2 NPN BJTs on the primary (high-voltage side) driving the main transformer and then the other 2 TO-220 devices would be the schottky diodes for 5v and 12v on the secondary side (likely mounted on a heatsink closer to the output wires).
              In most cases, the -5v and -12v rails will be derived from regular silicon diodes near the schottky diodes on the secondary.
              Occasionally, though, the -5v rail is derived from a 7905 linear regulator off of the -12v rail rather than from silicon diodes.
              As you can see, there's more than a few possible combinations, which is why pictures are helpful.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                No 3.3v rail - it's an AT.
                Not that I like this brand..... But they do still make them.
                http://www.newegg.com/Product/Produc...82E16817338010
                [And the old ones weren't >70% efficient.]
                For 15 bucks I'd get the Athena and do a preemptive recap.
                Mann-Made Global Warming.
                - Dr Seuss
                  master hoarder
                  • May 2008
                  • 12160
                  Why would you do that, though? You can modify just about any ATX power supply to have a -5v rail.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    or find an old one WITH -5. I know there was a 300w AGI Atx 1 unit that had -5 (I have one in my fileserver).
                    also, there was a delta made 300w Compaq unit (early p4) that came in the presario 7000 with -5 (have one too).
                    ironically, the Ultra V of doom (or at least the 500w) had a -5 as well (gutted a couple of them already, ).
                    you are looking for a white wire in the pigtail for the ATX plug or one of the AT plugs.
                    that all assumes it really is a -5. I looked it up- AT's orange wire was the "power good" wire. so this psu may use nonstandard colors (or its ATX, which means the orange is a 3.3v line)
                    about the athena- I think those need more than caps... they are beyond gutless (as in flat plate heatsinks without fins, tiny 4 diodes, jumper wire everywhere, etc.). the only way to fix an athena is a sledgehammer, firearm, or e-waste bin.
                    sigpic
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Because it's $15, it's easier, and probably even cheaper than a mod.
                      Also makes no sense to me to have a 3.3v rail in there with no load on it at all.
                      - Dr Seuss
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Yeah right. It's Athena that doesn't know anything.
                        http://www.newegg.com/Product/Produc...82E16817338047
                        - Dr Seuss
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          athenas are gutless. the absolute worst i have seen.
                          if i were the OP i would find an old delta or newton unit with -5V and start from there.
                          sigpic
                          • 370forlife
                            Large Marge
                            • Aug 2008
                            • 3112
                            Athena's server power supplies are typically decent FSP. But their other stuff is Sunpro and Topower.
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              As the 300w is replacing a 200w [which presumably also a 'gutless wonder'] the fact that the Athena is a 'gutless wonder' makes exactly -ZERO- difference and the Assertation that in might is inherently stupid.
                              The efficiency on an old AT like that is probably around 65% which means even if the system pulled all the PSU had [which is very unlikely] it would only be using 130 watts.
                              A 300 watt 'gutless wonder' would be OVERKILL.
                              And yes, I figured all that out BEFORE I suggested it.
                              - Dr Seuss
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                You haven't seen much then.
                                - Dr Seuss
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  didn't know they made server stuff.
                                  all I had seen were a bunch of sunproish gutless junkers and $5 PSUs with thin wire for sale online.
                                  still feel uneasy about them.
                                  I still think one could do better with a cheap used delta/newton.
                                  sigpic
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    I certainly wouldn't choose that one if the actual load was over 200 watts, but it isn't.
                                    - Dr Seuss
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Here's a better one.
                                      http://cgi.ebay.com/ASTEC-250W-Power...item439cd2639e
                                      ASTEC is not well known as they only ever did OEM but their units are usually very high quality and very often they have all jap caps as original.
                                      Some pics.
                                      http://www.recycledgoods.com/zoom.aspx?productID=17904
                                      - Dr Seuss
                                        master hoarder
                                        • May 2008
                                        • 12160
                                        I'd say it depends on the tools, parts, experience, and amount of time you have.
                                        7905 regulators are usually cheap and not hard to find. Just connect it to the -12v rail, add a 220uF cap and that's it - budget -5v rail on any PSU. You don't even need a dedicated PCB for this mod (although it's usually a good idea to have one ).
                                        A slightly more elaborate way is to connect two 2-3A diodes to the 5v AC output of the main transformer. Then wind a few turns of wire on the main output inductor, connect one side to common anode of both diodes, connect other to 2x 470uF to 680uF caps, and again you have -5v on just about any PSU.
                                        Better yet, just fix the old power supply - it's an AT power supply, how complex can it be ?
                                        Yes, that might be a problem on some power supplies. Some will care, some won't (most probably will have slightly weird voltages due to this). It all depends on the design.
                                        ASTECs are excellent.
                                        On the two units I have/still use, though, the fan controllers seem to be quite aggressive. Raise the room temperature just a bit, and they kick the fans on high. Don't know if that's an ASTEC thing or not.
                                        Topower is acceptable. Sunpro, however, is not in most cases, especially for their low end units - that stuff I consider a fire hazard. Raidmax RX-380K (Sunpro KY-480ATX) comes to mind as one of these.
                                          ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                                          This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                        • chth96
                                          How Can I test PWM DM0365R?
                                          by chth96
                                          Hello
                                          I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                          So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                          I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                          I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                          Yesterday, 04:14 PM
                                        • CG2
                                          Janome DC3050 Sewing Machine Pedal Resistance
                                          by CG2
                                          OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                                          Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                                          04-14-2023, 07:53 AM
                                        • Geomih
                                          CPU socket replacement soldering profile
                                          by Geomih
                                          Hi All - I am hoping someone can help with some pointers (complete noob here!)
                                          I have recently purchased a Scotle HR460 BGA reball machine (it's a bit old and I think the company no longer exists either), but as far as I can tell it is a competent and unmolested machine that should be good enough for my needs.
                                          My biggest problem is that it came with no profiles, and I must re-create all of them from scratch, something that is very scary for someone that doesn't really know what they are doing.
                                          The simple stuff like a small memory module isn't a big deal because there are
                                          12-11-2023, 11:07 AM
                                        • khelane
                                          test active pfc power with lamp test
                                          by khelane
                                          Hello
                                          I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                                          Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                                          Is there a way...
                                          06-03-2025, 01:00 AM
