Jou Jye JJ-300AP 300w Fail
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Jou Jye JJ-300AP 300w Fail
    some sort of overvoltage to kill all the mov's like that.
    open neutral maybe?
    i saw that happen at computerfest at hara arena a few years back.open neutral in a power drop killed about 20 machines at once.sounded like july 4 with all the lytics exploding.
    stunk up the whole building for hours.lets all the smoke out at once.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      But the power supply looks like it was well made. It appears to have a nice thick heatsink, which many not-well-known brands don't have. It's constructed similar to an Antec SL 300.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        open neutral maybe?
        hopefully the apc he got will tell if there is a wiring fault. Shouldnt other appliances have been affected though?
        One thing to consider is that only one of the mov's is burnt. Is there a possibility that the one mov became off spec? should both have blown or is one normal?
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Same thing with the PSU I posted about... Only one Zenerdiode went kaput...
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            user installed the apc and replaced the psu with the fortron. now computer is working fine again.
            then if it was voltage surge lucky that the psu had that protection since no ups was installed at that time.
            interesting. actually i am learning a lot from this thread.
            • AK0R
              • Mar 2005
              • 204
              #26
              Would it be repairable if i salvage some varistors from another unit, or would there be more damage?
              Not advisable, since MOVs' damage is cumulative. So any damage that they took before would shorten their lifetime in the new application. Also, MOVs don't generally show any signs of degradation until failure. They fail by one of two means: either they open, in which case there is no visible indication, but they no longer provide protection, or they short, and the high current then blows them apart (which appears to be what happened here).
              Because the damage is cumulative, several small overvoltage conditions can cause just as much damage to the MOVs as one large one. Major appliances (refrigerator, stove, etc.) or those with motors are less likely to be sensitive to overvoltage conditions than those with sensitive electronics (microwave, PC, etc.). So, overvoltage conditions could have been occurring relatively frequently without his knowledge. One of the worst is the switching transient that results when an electrical substation drops off or comes on line, or if the transmission system senses a fault, and briefly de-energizes and then re-energizes the line to see if it clears. The switching times are in the millisecond range, but the transients can be huge (>1000v on a 240v line).
              • Sus256
                HISENSE 65E7KQ PRO - no boot
                by Sus256
                Hi all!
                HISENSE 65E7KQ PRO
                RSAG7.820.13512 - chassis
                MT9618BAATAB - cpu
                RSAG7.820.12059 - power
                HD650Y3U77 - panel
                KLM8G1GETF - emmc
                The TV does not turn on, the standby indicator is on. All voltages are present.
                Emms is dead. Not readable, not detected.
                Replaced emmc.
                But with another dump there is no launch
                Terminal log
                UART
                AC_ON
                RPMB key is not yet programmed
                HASH1_VERSION=0x00000000 64bit
                E-B
                FDE enabled
                layout pattern onebin by SAR7,0...
                06-01-2025, 02:11 AM
              • stormanimal83
                Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                by stormanimal83
                Hey....
                Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                01-18-2024, 02:15 PM
              • dragometin
                Hitachi 40HYC42
                by dragometin
                TV Model: Hitachi 40HYC42
                Power Supply: 17IPS71
                MainBoard: 17MB95M
                Panel: VES400UNDS-2D-NO3
                When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                Is there any variants on 17IPS71 power supply's?
                UART output pins 10 and 12 on scart connector:
                Code:
                12:24:04.595
                08-08-2024, 05:53 AM
              • ignacio.ino27
                Vaio DA0HK1MB6E0 MBX-247 Burning any EC
                by ignacio.ino27
                Hello to all.
                I have this Sony Vaio QUANTA HK1 DA0HK1MB6E0 MBX-247 that is burning the NUVOTON EC when you connect it to power supply.
                1) The +3vpcu line is going to a direct short after connecting the motherboard to power supply.
                2) I discovered the EC NUVOTON was shorted. After removing it the short gone out on that line (+3vpcu) but... (If i quit the EC the 3.3v are pressent on +3vpcu because the shorted component was quited)
                3) There were no shorts after soldering the new EC NUVOTON. But after connecting the board to power supply the EC keeps burning...
                05-07-2022, 05:24 PM
              • Perry Babin
                Capacitors of the same make/series that consistently fail in one amplifier while they rarely fail in a different make amp
                by Perry Babin
                This is for car audio amplifiers but I doubt that matters. There are amplifiers that use the same make/series capacitor as a different manufacturer and they consistently fail in one brand. In the other they are OK. The amplifiers are from the same era. Is it possible that the heating profile used when flow-soldering the boards could be the reason for the failure? If not, any ideas on what the difference could be?
                04-03-2024, 10:40 AM
