This is for car audio amplifiers but I doubt that matters. There are amplifiers that use the same make/series capacitor as a different manufacturer and they consistently fail in one brand. In the other they are OK. The amplifiers are from the same era. Is it possible that the heating profile used when flow-soldering the boards could be the reason for the failure? If not, any ideas on what the difference could be?
Capacitors of the same make/series that consistently fail in one amplifier while they rarely fail in a different make amp
Tags: None -
Exposure to heat during assembly could potentially affect lifespan, but circuit design and component placement would also have a significant affect. In general electrolytic capacitor failure (aside from defective manufacturing and seal failure) is caused by heat and ripple. So a capacitor in a "dirty" circuit with lots of ripple and/or next to a hot running component will generally have a much shorter life than that same cap that is well cooled in a comparatively "clean" circuit.This is for car audio amplifiers but I doubt that matters. There are amplifiers that use the same make/series capacitor as a different manufacturer and they consistently fail in one brand. In the other they are OK. The amplifiers are from the same era. Is it possible that the heating profile used when flow-soldering the boards could be the reason for the failure? If not, any ideas on what the difference could be? -
The primary-side filter caps can take a beating and those are the only ones that fail in some amps. Other amps have caps of various makes and series that fail throughout the amp, even in linear voltage regulators for the ±15v op-amp supplies. I'm sure that this is one of the questions that could never be answered definitively with so few specifics. I always blamed heating during assembly and wanted to know if is was ridiculous or something that could cause problems.Comment
It's not something ridiculous. Overheating during assembly can compromise the seal of the cap. And from that point forward, it's just a matter of time (and more abuse from the circuit) before complete failure.
Another thing to be considered is vibration. If the cap is installed in equipment that sees a lot of vibration and if the in question is not glued or held down to the board properly to minimize vibration, that too can cause early / premature failure of the bung seal.
So there are a lot of factors really.
In general, when it comes to non-Japanese caps, anything is possible in terms of failure.
You mention you see this failure in one amp brand but not in others. Just curious how many times this was so we could say the results have statistical significance. If it was just with one or two amplifiers, I'd say we need to see more cases to confirm the results.Comment
by Sus256Hi all!
HISENSE 65E7KQ PRO
RSAG7.820.13512 - chassis
MT9618BAATAB - cpu
RSAG7.820.12059 - power
HD650Y3U77 - panel
KLM8G1GETF - emmc
Replaced emmc.
Terminal log
UART
AC_ON
E-B
FDE enabled
layout pattern onebin by SAR7,0... -
My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...-
by jinu_jHi Folks
Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
Problem
I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
Any advice would be appreciated...-
by UserXPHi, people.
I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...-
Hi all you clever electronmic gooroos!
I was wondering if you could help me with the below issues Im having on a Sansui Integrated amplifier. I bought this unit as a project to repair as Im playing around with basic electromics.The unit has a faulty volume control pot. The service maual refers to a 150K Logarithmic pot (A) tapered stereo. Im struggling to find this value. Seem to be a jump from 100K to 250K. Im now trying a 250K pot. It works but the problem is that as the volume is turned up from starting at Min the Left channel will come on first just slightly before the Right...-
10-15-2025, 02:54 PM -
- Loading...
