Capacitors of the same make/series that consistently fail in one amplifier while they rarely fail in a different make amp
  • Perry Babin
    • Apr 2024
    • 15
    • usa
    This is for car audio amplifiers but I doubt that matters. There are amplifiers that use the same make/series capacitor as a different manufacturer and they consistently fail in one brand. In the other they are OK. The amplifiers are from the same era. Is it possible that the heating profile used when flow-soldering the boards could be the reason for the failure? If not, any ideas on what the difference could be?
  • dmill89
    • Dec 2011
    • 2534
    Exposure to heat during assembly could potentially affect lifespan, but circuit design and component placement would also have a significant affect. In general electrolytic capacitor failure (aside from defective manufacturing and seal failure) is caused by heat and ripple. So a capacitor in a "dirty" circuit with lots of ripple and/or next to a hot running component will generally have a much shorter life than that same cap that is well cooled in a comparatively "clean" circuit.
    • Perry Babin
      • Apr 2024
      • 15
      • usa
      The primary-side filter caps can take a beating and those are the only ones that fail in some amps. Other amps have caps of various makes and series that fail throughout the amp, even in linear voltage regulators for the ±15v op-amp supplies. I'm sure that this is one of the questions that could never be answered definitively with so few specifics. I always blamed heating during assembly and wanted to know if is was ridiculous or something that could cause problems.
        master hoarder
        • May 2008
        • 12170
        • Bulgaria
        It's not something ridiculous. Overheating during assembly can compromise the seal of the cap. And from that point forward, it's just a matter of time (and more abuse from the circuit) before complete failure.
        Another thing to be considered is vibration. If the cap is installed in equipment that sees a lot of vibration and if the in question is not glued or held down to the board properly to minimize vibration, that too can cause early / premature failure of the bung seal.
        So there are a lot of factors really.
        In general, when it comes to non-Japanese caps, anything is possible in terms of failure.
        You mention you see this failure in one amp brand but not in others. Just curious how many times this was so we could say the results have statistical significance. If it was just with one or two amplifiers, I'd say we need to see more cases to confirm the results.
        • Sus256
          HISENSE 65E7KQ PRO - no boot
          by Sus256
          Hi all!
          HISENSE 65E7KQ PRO
          RSAG7.820.13512 - chassis
          MT9618BAATAB - cpu
          RSAG7.820.12059 - power
          HD650Y3U77 - panel
          KLM8G1GETF - emmc
          The TV does not turn on, the standby indicator is on. All voltages are present.
          Emms is dead. Not readable, not detected.
          Replaced emmc.
          But with another dump there is no launch
          Terminal log
          UART
          AC_ON
          RPMB key is not yet programmed
          HASH1_VERSION=0x00000000 64bit
          E-B
          FDE enabled
          layout pattern onebin by SAR7,0...
          06-01-2025, 02:11 AM
        • MrCommunistGen
          Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
          by MrCommunistGen
          My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
          I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
          07-12-2021, 05:11 PM
        • jinu_j
          How to test Subwoofer Amplifier with only a multimeter
          by jinu_j
          Hi Folks
          Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
          Problem
          I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
          Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
          Any advice would be appreciated...
          08-29-2024, 02:05 AM
        • UserXP
          Mackie CR4 amplifier no sound
          by UserXP
          Hi, people.
          I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
          Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
          10-17-2020, 05:06 PM
        • waspie
          Aiwa GX-770 Amplifier Protection Circuit
          by waspie
          I am by no means an expert on this type of troubleshooting but I can follow direction real well.
          I'm no stranger to using a meter and soldering iron so I'm looking for some help in fixing an old amplifier/system I got. This is part of a system "V-1200" by Aiwa where there are several components. My first problem seems to be the amplifier.
          It seems to be in protection. When first turned on I hear the inital relay coming on but never the second relay which is connected to the protection IC. I don't see any obvious bad components on the board. If I ground the...
          11-29-2022, 09:58 AM
