ph-500atx 400w psu rebuild help
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: ph-500atx 400w psu rebuild help
    what resistor would be suitable?
    -brown black brown gold
    or
    -green brown black gold
    or
    -brown grey brown gold
    or would an ntc 5d-11 do it? thats a thermistor right?
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Depends on the speed you want. Try each resistor in series with the fan, and see which airflow you like the best.
      For most average PSU fans (rated 0.12~0.18A), you can get a decent range of different speeds with a resistor between 10 and 100 ohms, with 10 ohms making the fan run at almost full speed and 100 ohms at around half speed.
      The resistors you have are 100 ohms, 51 ohms, and 180 ohms.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Bookmark this: http://www.dannyg.com/examples/res2/resistor.htm This way you won't look like an idiot when talking about resistors.
        Btw, i wonder why you got banned again.
        A working TV? How boring!
        • c_hegge
          • Sep 2009
          • 5219
          He won't be able to answer that question, since he's banned permanently afik. I think it might have been in relation to that apology thread.
          • brethin
            • Dec 2008
            • 1907
            Christmas came early this year! Thanks Santa (Topcat)!
            • Waffle85
              Fujitsu Lifebook E756 vPro Bios Repair/Rebuild help
              by Waffle85
              I got a Fujitsu Siemens Lifebook E756 vPro with a corrupted Bios after flashing. Device wont start anymore, only Blackscreen.
              Dumped the Bios and attached it. Maybe someone can help me repair/rebuild the bios?
              Thanks in advance...
              11-24-2023, 12:26 PM
            • mferna14
              Bin Files rebuild for HP Pavilion 17-cn1003ca
              by mferna14
              Hi, I am working on a hp 17-cn1003ca laptop., board # VLAD10-6050A3261101-MB-A01(A1).This laptop had gone to another repair shop & for no reason at all they just removed the BIOS chip (Chip missing). Checked the photo with identical board & no BIOS chip on mine & missing chip on these tracks. I downloaded the BIOS files from the Hp site for this model. The Model # is 17-cn1003ca & Serial # 5CG21832ZY. Can someone rebuild the Bin file for this Model & S.No. I have uploaded both, the 8MB & 16MB bin files, I think 16MB is required for this motherboard. Thanks in advance....
              09-12-2023, 09:18 PM
            • IDElectroRep
              HP Pavilion 24-r111ne bios rebuild
              by IDElectroRep
              Hi
              I need help with a corrupted bios. The pc doesn't power on with the original file. I downloaded new file from HP and the pc works but I get the "Manufacturer setup" display. I would really apreciate if someone could help with adding the missing data from the original to the new file. Thank you!
              SN: 8CC8240QTT
              post moved...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
              05-07-2025, 10:28 AM
            • retrooo
              asus ga503q need bios rebuild asistence
              by retrooo
              good day to all, i have one asus ga503q that wont turn on only cps key blink for 3 seconds , i have one file from asus site but only gives me light on keyboard ,anyone can helpme to rebuild my original dump please
              any help will be appreciated
              thanks in advance...
              02-02-2023, 08:23 PM
              ZD desoldering station pump rebuild
              by stj
              just did one.
              works great.
              so here's the discoveries.
              the pump "modules" have 4 parts, the main body, the outside bit, the inside bit - screwed to the main body, and the diaphram.
              the failure is the inside bit, it has a rubber coating for some reason that becomes tacky and breaks down - contaminating the diaphram.
              so you need to clean everything to get rid of all the tacky black stuff.
              then reassemble it.
              *BUT*
              you must put the 2 screws into the assembly only finger-tight.
              if you tighten it properly the valves dont work....
              08-21-2024, 05:59 PM
