ZD desoldering station pump rebuild
    • 31163
    just did one.
    works great.
    so here's the discoveries.
    the pump "modules" have 4 parts, the main body, the outside bit, the inside bit - screwed to the main body, and the diaphram.
    the failure is the inside bit, it has a rubber coating for some reason that becomes tacky and breaks down - contaminating the diaphram.
    so you need to clean everything to get rid of all the tacky black stuff.
    then reassemble it.
    *BUT*
    you must put the 2 screws into the assembly only finger-tight.
    if you tighten it properly the valves dont work.
    use the link pipe to test the 4 valves by blowing/sucking - you will see.
    i had to finger-tight the screws with blue-locktite to make the 4 valves work.
    then put the bellows back with new cable ties and put the shell back anf it's all good
    • Jul 2011
    • 6059
    Originally posted by stj
    just did one.
    works great.
    then reassemble it.
    *BUT*
    I have also found that the vacuum pump on the desoldering gun station has the same issue I think this due to the flux in the solder and you have to take it apart and clean it the disk washer has to be very clean as well for best results and the area that the washer sits on also needs to be very cleaned and while you are at cleaning the vacuum pump clean the piston cup as well and do not put anything on the rubber cups because you will not have the suction that you need for it work correctly
    I have cleaned several of them before I figure out the best way to do this process and get very good results
      • 31163
      it wasnt flux - i have extra filters.
      the inner hard cup that the bellows goes onto has that shit rubber coating they put on cheap powertools.
      thats what is turning sticky and slimey.
        • Jul 2011
        • 6059
        I did not know that this was done when it was manufactured oh really not cool that this was done
          • 31163
          i cant see why they did it.
          unless it was maybe to stop the bellows slipping off before they added the cable tie anyway?
          • armini
            18VDC PSU completely dead - ZD-915 desoldering station
            by armini
            Hi everyone!
            Three years ago I got a ZD-915 desoldering station which failed just after a few months of light use. During a short desoldering session, the station simply shut down, and since then it has been completely dead and unresponsive. The failure was silent, without any pops.
            Due to a lack of time, I set it aside and didn't look at it.
            Yesterday, I took it apart and did some basic measurements. The 18v terminal shows 0v. In addition, there is no visible damage to the board itself.
            According to replies in 18VDC PSU has dropped to...
            04-25-2023, 07:49 AM
            07-01-2024, 06:34 AM
          • rippergr
            Desoldering station ZD 915 no indications, no heating
            by rippergr
            Hello all,
            I tried to power on my desoldering station ZD915 today and altough the LCD has power and it's on I don't have any indications on the screen and the gun is not heating at all.
            I open it up and I don't see any visual fault anywhere.
            Does anyone has any clue what should I check?
            10-24-2023, 11:46 AM
            03-31-2024, 02:12 PM
            HP Station de travail Z2 format tour G4 i7-8700 Specification for Upgrade or Repair
            This specification for the HP Station de travail Z2 format tour G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Station de travail Z2 format tour G4 boardview and Station de travail Z2 format tour G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
            09-12-2024, 02:20 PM
